Question about Westinghouse SK-26H240S Television
Sounds don't align with lip movement
My sounds are offset from the lip movement. I can turn the tv off and back on and it solves the problem temporarily, then after a few minutes the sound is off from the picture again.
  • Mark Jeffress Jun 23, 2007
    thanks, good answer!
    Genius:
  • 1,074 Answers
If you are saying that your tv has no sound to match the lips movements then you will have to get a tech to repair your tv the problem is in the audio circuit could be a cap or the audio output ic.if you are saying that the tv has sound but it is not syncronizing with the lip movements have your tech check the sync circuit it is possible that the operating voltage is too small to allow the sync circuit to operate.good luck my friend.
Posted on Jun 23, 2007
I am not asking for specs i am asking were and do i turn to adjust my toe and camber issues in the rear of my van
rear end alignment is by means of eccentric mounting bolts in the suspension bushes
Ford uses a system of an off set washer under the head of the bolt that rubs against a stop so loosen of the nut and turn the head
that makes the washer turn and moves the setting of the alignment
It should only be done on a wheel alignment machine as very little movement makes a vast difference in the setting
true qualified wheel aligners will always check the rear alignment before doing the front as the back sets up the front for long tire life
Sep 17, 2016 | 1998 Ford Windstar
Tip
SERVICE MODE AND ERROR CODES CHECK
Viewing the Self Check Diagnostic List
1. TV must be in standby mode. (Power off).
2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
3. To exit Self Check display, turn the power off. Press [Menu] Exit.
Clearing the Self Check Diagnostic List
1. In Service Mode, press the Channel 8 Channel 0 .
RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
White Balance adjustment
1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
3. Set the Picture Mode to "VIVID" in the user menu.
4. Select the Component In input.
5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
Green", "Black Level Offset Blue" to average values .
"Cool " White Balance Adjustment
1. Select "COOL" from Color Tone in Service Alignments Menu.
2. Input 70IRE full white pattern signal into Component In.
3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
4. Input 25IRE full white pattern signal into Component In.
5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
6. Repeat steps 2 to 5 to achieve desired White Balance.
FOR MORE DETAILS CHECK THE FOLLOWING LINK
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
on Jun 30, 2015 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
Lip sync problems
that is a network problem nothing consumer can do about it .
Sep 29, 2015 | Televison & Video
How to adjust my camber on a 87 Plymouth voyger
one of the bolts holding the McPherson strut to the steering knuckle (the part that turns and has the hub on it) has an offset washer on it. loosen both bolts (don't remove them) and then turn the bolt that has the offset washer on it, it will move the steering knuckle back and forth to adjust it. once you get it to the proper adjustment, tighten both bolts holding the McPherson strut to the steering knuckle without moving the offset washer. Now, having said all of that. the average home mechanic does not have the equipment needed to properly adjust the alignment on any car. The proper fix would be to take the car to a good mechanic that does alignments.
Mar 22, 2015 | Plymouth Cars & Trucks
Panasonic VIERA TH-50PX25 DVD offset and blue color My DVD or VCR is offset on the screen ... ...
this Plasma TV working normally for 2 hrs & just stop &showing blackscreen display"chanel not available" I turn TV off & turn it back on again ,. now it have picture with no sound ...please help if any one know what is the problem is ...Thanks
Oct 08, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Picture scrolls and is offset
Oops, nevermind. It's right there up top.
First off, try a TV reset. Leave it unplugged for 5+ minutes then try again.
If this doesn't work, I would recommend contacting RCA. There is no way to contact them as far as I can find, except for an online form to their customer service (there may be a contact number in your TV's manual):
http://tv.rca.com/en-us/ContactUs.html
Good luck,
~Chris
Jul 10, 2009 | RCA HD52W140 52" Rear Projection...
Cant align the red cross with the white and blue crosses
Convergence amp ic are bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 02, 2007 | Toshiba 55H70 55" Rear Projection...
Samsung 42
This is an issue that has been going on for some time with Samsung. This is call Lip sync. To fix this problem you need a software upgrade. If you are under warranty, we will change the signal board.
Best regards
CircuitCity
Oct 18, 2007 | Samsung HP-R4252 42 in. Plasma HDTV
Televison & Video Logo
726 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
