Question about Olympus FE-140 Digital Camera
Its a fe-170
The pictures i take now come up with different tints of purple and red through it, kinda like a negative picture with colours.
  • 1 more comment
  • Mikeil Nov 12, 2007
    I have an FE-170. Similar problem. The colors are all wrong, very heavy on the reds and almost looks like a negative. The color is better on indoor flash but not outdoors.
  • bobbradley71 May 28, 2008
    my camera does the exact same thing....just started last weekend. Any solution yet?
  • Anonymous Jul 17, 2008
    Mine is an Olympus X 760 and it has just started to do exactly the same thing.
I have the same problem. Did anyone come up with a fix? Did anyone upgrade their firmware?
Posted on Jun 05, 2008
Have just encountered exactly the same problem with the same model! Looks kinda psychodelic!
Posted on Jun 18, 2007
Regza 5Toshiba) V55 TV - picture tinted red. First the picture went (sound ok), when I got the picture back by fiddling with contrast and colour settings, the picture was red. I've used the 'colour...
The fault is with its video output stage circuit. The fault is called "one color predominant' screen. In most cases, this might be to a loose solder terminals at the video output stage circuit board. This board can be located at the neck of the picture tube, will plugged on to it directly. If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic /Timeslide, can be selected by the drop-down list, by the top left of the display window, will make surf easy. You can also do a search, by type in the brand name / model number / IC used, in the search box at the top right of the display window.
Nov 05, 2013 | Toshiba 36A41 36" TV
Panasonic Viera PC-to-TV Via VGA has Purple Tint
Purple Panasonic PC>TV Problem:
The VGA cable uses three primary color RGB channels.
Red, Green, and Blue.
The picture is made up of pixels or dots arranged in a grid along the "X" horizontal axis and "Y" vertical axis.
The computer mixes the intensity of each color channel to create a unique color per pixel.
All RGB at 100% creates white.
R+G creates yellow.
R+B creates magenta, ie purplish.
G+B creates cyan.
So a purplish tint sounds as if your Green wire has no signal, which may indicate a faulty VGA cable or VGA socket.
Put another way, (R+G+B)-G=R+B=magenta.
So try another VGA cable, spray all socket pins with "Servisol " or similar contact cleaner.
0%<--------->100%
Cyan<------->Red
Magenta<--->Green
Yellow<------>Blue
All 0%=Black; All 50%=Grey; All 100%=White.
Jan 17, 2018 | Televison & Video
Red tint,double pictured red, kinda swirly
Replace Both of your STK ICS they will have Part number on them example STK392-110 if 110s use 150s Call Mats 1-800-628-1118
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Bluish green tint to television picture
Find out what board and circuit is responsible for the color and you have your answer.
Mar 12, 2017 | Panasonic PT-52LCX66 Projection Television
LCD FOR OLYMPUS FE-170 BROKEN CAN IT BE REPAIRED
my olympus FE-170 screen won't show any picture. All other things are fine and working the screen just won't show pictures taken or a picture i'm aout to take. the camera is about 2 years old i've had no problems with it till now. Can someone pleeeaaasssse tell me their is an easy solution to this.
Nov 23, 2008 | Olympus FE-170 Digital Camera
FE-170 Blurred photos
ccd may be going out.. try doing a reset thru the menu or else..repair
Aug 31, 2008 | Olympus FE-170 Digital Camera
Grey and white screen--lens won't open--beeps and shuts off
i have fe170 olmpus camera but the lcd display is dameaged ies the corrner of the display is colour is changed how can service this problem
May 01, 2008 | Olympus FE-170 Digital Camera
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Olympus FE-140 Digital Camera Logo
88 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
