Question about JVC AV-27530 27" TV
I have a JVC Mastercommand TV without remote and I am trying to program it to Dish Network. Their program channel in on Channel 60 instead of Channels 3 or 4. Can you help?
  • 140 Answers
SOURCE: jvc channel lock
The default lock code is "0000" Then you can go in and turn off the V-chip.
Posted on Sep 13, 2007
  • 556 Answers
SOURCE: Universal code for JVC-AV 27230
please try this web site you will get the solution
good luck.
Posted on Oct 17, 2007
  • 72 Answers
SOURCE: cable channels not working
auto search channels on menu. start at 1
Posted on Jan 04, 2008
  • 67 Answers
SOURCE: Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Posted on Mar 27, 2008
  • 4234 Answers
SOURCE: doesn't get all cable channels
With the menu set to cable signals, the autoprogram should catch all of the cable channels. The Cable Channel option allows you to use either channel 3 or 4 as the "cable" channel. This is when you have an external box that you use to tune in cable rather than the TV directly. The easiest way here is to autoprogram the TV while playing a VCR tape. That will insure that channel 3 is included.
Does the autoprogram fail?
Posted on Aug 20, 2008
Does anyone know the remote code for a sanyo tv model dp42647 on a dishnetwork remote
Remote Codes ' MyDISH ' DISH Customer Support
Remote Control Manuals · Program Remote to TV/Other .... remote, product type, and manufacturer below to see the current known remote codes you should try.
My Dish remote needs programming for Sanyo TV ... - Directly
My Dish remote needs programming for Sanyo TV, Model DP226649. My Dish ... Needcode. Alta asked this ... Dish Network • 16808 answers • 95% helpful. Code is ... Test volume control, if it works you're set ... try 590 it should work. tivosat.
How do I program my dish remote to work for my Sanyo TV.
Dish Network. How do I program my dish remote to work for my Sanyo TV. ... entercode 590 press pound then sat Then try to turn tv on and off then try volume.
How do you program a dish network remote to my sanyo tv? ' Ya
Jan 09, 2012 | Sanyo 42 in. LCD TV
Hi amielynn221, my name is Mike Houston of DISH Network and I see youwant to program the RCA remote to the DISH Network receiver. We do have thecodes to program our DISH remote to the RCA TV we do not have the codes toprogram the RCA remote to DISH Network receivers, I will send a link to helpwith these steps.
Apr 19, 2011 | RCA RCRN04GR Remote Control
What is the code for my hd 52786 jvc tv trying to program a dish network remote
Try these codes, the bold ones work the most often: 557, 558, 642, 559, 508, 649, 655, 667, 673, 676, 726, 735, 736, 737
If the codes don't work try the steps below:
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once. 3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network Customer Service
Feb 02, 2011 | JVC RM-C14G-1H Remote Control
Programar tv jvc con control remoto dish network
If I understand you correctly, you are having a problem with you DISH Network remote operating your JVC TV? What type remote do you have? If you look on the back at the top, you will see an 2 digit number; e.g. 3.0 ir. Please let me know what the model number is and I can provide you with code to try to program the remote to your TV.
Ray Calo
DISH Network
Jan 03, 2011 | DISH Network IR Remote Control
I need the tv codes for this remote, i have a jvc tv
robrivera17, you can find the codes on the bottom of this post, and just in case below is the steps to program the remote to the JVC:
1. Hold down the gray TV button until all lights on top of the remote light up.
2. Let go and while it is blinking enter the 3-digit code on the number pad and press #
3. Try the TV functions including volume/mute and power. If it works press SAT and you're good to go. If not repeat steps 1 and 2.
Link for codes:
Tommy Faust
DISH Network
Oct 31, 2010 | DISH Network IR Remote Control
DWIN tv, Marantz receiver and Dish system. Three different remotes needed to control. One for On/Off of the tv, one for the volume and the third for the Dish network. What is the best way to get to one...
Youdo have the ability to program your current DISH Network remote to all of yourcomponents. If you decide you would like to do so, I have included instructionsto assist you in programming your remote. In order to program your remote toyour DWIN television without the remote code, (I'm sorry unfortunately I wasunable to locate a remote code for a DWIN Tv L) you can complete what we refer to asa "Power Scan," to do this you would complete the following steps. 1. Withthe desired equipment on, press and hold the correct Mode button until all modebutton backlights illuminate, then release. (In this case the mode button willbe "TV") 2. Pressand release the Power button. 3. Pressthe Up button once a second while pointing the remote at the desired equipment. Note: If the code for the equipment comes up, theequipment will power off. 4. Pressthe POUND (#) button. If the codeentered is valid for the remote, the mode light flashes three times.
-In addition, you can also program the remote to yourMarantz receiver this can be done by pressing and holding the AUX botton inupper left corner of remote next to the SAT button.
-Press & hold AUX until all the other mode buttonslight up, then release AUX button, all the other mode buttons should turn off,only AUX button should be blinking now,
-While AUX button is blinking enter in the remote code742 for the Marantz receiver and then press the # key (pound key.) Afterpressing the # key on your remote, the AUX mode button should blink 3 timesmeaning the programming has been completed successfully. While still in AUXmode try any function on the remote, such as turning the volume up or down onyour Marantz receiver. The DISH Network remote should now be programmed tocontrol the receiver.
-If the 742 code doesn't program the DISH Network remotesuccessfully you can also try each of the following using the same procedures, 743,651, or 740. After completing the power scan to program the DISHNetwork remote to your DWIN t.v, & completing the AUX mode buttonprogramming, the remote should now work for your TV to powere on and off, theMarantz amplifier- to control the volume, and the DISH Network receiver. Hopethis helps! -Kirstie DISH Network
Oct 04, 2010 | DISH Network IR Remote Control
Programme remote to work with sony tv
To program your DISH Network remote to your Sony TV you will simply- press and hold the TV Mode button until all the other mode button back lights illuminate, then release.
-Now while the TV mode button is blinking please enter in the remote code 500 which is the remote code for your Sony TV after entering 500 then press the pound (#) key.
-After pressing the # key on the DISH Network remote, the TV mode button should blink 3 times and then turn off completely. This will mean the programming of the DISH remote to your TV has been completed successfully. While still in TV mode try any of the functions on the remote, such as turning the volume up or down on your TV or attempting to press the power button.
-The DISH Network remote should now be programmed to control your TV.
-If the remote code 500 doesn't program the DISH Network remote successfully you can also try each of the following using the same procedures, 000, 590, 640, 502, 002, or 567.
I hope this resolved the issue for you! Please feel free to contact us if you need any additional assistance.
Sep 16, 2010 | DISH Network IR Remote Control
I would like to control my dish network receiver 3100 with my samsung remote
If you are trying to use your Samsung TV remote, it will not work with our DISH receiver. Some universal remotes can be programmed to the receiver but you may not get full functionality with the universal remote. Our remotes are designed to allow for functionality for the TV if programmed to the DISH remote (volume, on/off). I hope this helps.
Ray Calo
DISH Network
May 07, 2010 | DISH Network 32 Ir 137180 Remote 5900 3100...
VCR codes and programming instructions for JVC MASTERCOMMAND RM-C676
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Jul 11, 2009 | JVC RM-C18G-1H Remote Control
Dish network remote with a element tv
Since you dont have a popular brand set you should try using the scan method. Here is a link with a video to help program your dishnetwork remote to work with your set.
Nov 23, 2008 | DISH Network IR Remote Control
JVC AV-27530 27" TV Logo
577 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
