Question about Ricoh Aficio Colour 3006 Color Copier
Error code SC510- suggests reset but comes on again.
We are a small charity with a 3006 machine with a fault code of SC510. It comes back again after a reset. Any help would be appreciated. We do have a competent person who could make use of your anwers. Thank you!
  • Anonymous Dec 03, 2007
    ERROR CODE SC510 KEEPS APPEARING
E 501
Posted on Oct 26, 2010
  • 62 Answers
This is a feed problem from the tray. This is an older machine so it is most likely a feed motor problem.If the code is constant it may be the I/O board, if intermittent it is usually the motor. hope this helps
Posted on Jul 05, 2007
  • 186 Answers
Make sure the paper is loaded properly in the trays. You can try using a different tray or not loading as much paper in the trouble tray.
Posted on Jun 22, 2007
Hi I need a list of error codes for an Angelo Po Combi oven. Model number is FCV101EDS
F0 - No Alarm Signal
The main control board in your oven has failed to communicate with the alarm. This is most likely a fault with the control board itself, which may need replacing.
F1 - Door Not Locking
If there is an issue with the door lock in your appliance you may see this error code. Check the door lock and the wiring and connections to it to get to the cause of the fault
F2 - Door Not Unlocking
The opposite fault to the above, this fault indicates your oven door won't unlock. Once again you'll need to check the door lock mechanism and its wiring and connections. This fault could also be down to the oven thermostat as this could be giving an incorrect temperature reading, preventing the door lock from being released.
F3 - Self Test Error
Turn off your appliance, unplug it for five minutes or so and plug it back in again. Doing so should clear the F3 error code. Easy as that!. If it does not clear the problem you are likely to have a fault so see the links to our diagnosis videos below.
F4 - Temperature Sensor Fault
If you see this error code you'll need to check your temperature sensor and the wiring and connections between the sensor and the main control board. You may need to replace the sensor.
F5 - Control Board Error
This fault suggests a problem has developed with the main electronic control board in your AEG oven. It may need replacing to bring your machine back to full working order again.
F7 - Mains Supply Issue
You'll see this fault if your oven has detected a problem with the power coming into it. This could mean your appliance has been wired in incorrectly. You'll need to check the mains supply connection to your oven to get to the bottom of this error code.
F8 - Power Supply Issue to Control Board
The main control board is not receiving power as it should. Check the wiring and connections to it. If all the connections are fine, you'll possibly need to replace the control board.
F9 - Processor Auto Resetting
As with error F3, turning off and unplugging your appliance for five minutes before plugging it back should reset and fix this fault code.
Oct 24, 2016 | Combi Ovens
How do I clear error code C3721
Since there is no 3721 in the service manual you mean 3751: Before I explain if this code comes back do not reset again these code deals with the fuser it can catch on fire that will ruin a perfectly good day
Lower temp on the fuser. To reset. On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens when you see the screen with the copiers on it to the left on the screen in the middle you will see a "." when that is displayed press 3. The code will come back but now press the Utility/Counter button, you should see a button that says Maintenance Mode press that, see Trouble Reset press that and the machine will again will go thru warm up procedure, you will see the "." DO Nothing! The machine should go to "Ready to Copy" if the code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 20, 2014 | Konica Minolta bizhub 350 All-In-One Laser...
C0500 error code
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset, you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
C-0500 code mean no power to the fuser inside mid cover front is a micro switch that provides the power to the fuser unit
Jan 11, 2014 | Konica Minolta Di3510 Copier
WHAT DOES C005 20 MEAN ON MINOLTA EP1052 COPIER
Fuser Unit error. GOT TO HOT! To clear remove the rear top cover small black switch on circuit board press while machine on if it comes back REPLACE the fuser unit. DO not reset again the machine is informing you that there is a fault!!!
Nov 09, 2012 | Minolta Office Equipment & Supplies
Minolta 6000 error c0610 solution
scanner fault the motor that moves the bright light , open the front door to your left upper small access cover remove a touch trouble reset if it comes back replace
Dec 15, 2011 | Minolta EP4000/5000 CS/PRO Copier
The machine does not heat. stops after few minuets and gives the error code F:09
if its a bosh then its famous the fault is a signal code sent to the heating element to shut of as the machine needs its filter cleaned out then you must bush the small red reset button on the back panal (removed) it will fire up again and work fine
let me know if you need further advice
Dec 28, 2010 | Dryers
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
Error Caode 5E - Machine not spinning
Can you get me the model number? Thank You!
Jun 19, 2009 | Samsung Washing Machines
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
Ricoh 3006
go to service program 5-810 ( sc reset) press on, turn off the machine an the turn on again. The service code should be gone, if it come back again check for a paper jammeed or wrapping the upper
fusing roller if this is not the case replace the thermistor;
Good luck
Vittorio
Dec 21, 2007 | Ricoh Aficio Colour 3006 Color Copier
460 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Inky Fingers
Inky Fingers
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
