Question about Epson Aculaser C1100 Printer
Paper jam and E547
Printer prints for a while and then the paper jams and then the printer keeps turning over without cease. It then displays the E547 error on the lcd panel.
  • 1 more comment
  • Karl Geppert Jun 16, 2007
    Thanks. The machine is nearly brand new - only printed 4000 pages so Epson will be getting a call on Monday.
  • Anonymous Feb 17, 2008
    err0r 527
  • Anonymous Mar 12, 2014
    wen i put on my printer, after a few minute she give E547
  • Epson Master
  • 705 Answers
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson.
Posted on Jun 15, 2007
    New Friend:
Thank you
Posted on Feb 11, 2015
Paper jam error without a paper jam
sometimes the printer keeps telling you one thing first you have to read again your instruction carefully or sometimes its just the position of your printer where the paper was
Apr 17, 2012 | Office Equipment & Supplies
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
When we hit the print button to print a page the paper will not feed into the body of the printer and the sign flashes for us to remove jammed paper and hit start button, when we do this it just keeps...
Paper jams
85% of paper jams are caused by worn rollers Chances are, when your tech arrives, he'll tell you that the jams were caused by worn feed rollers. The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease.
MP150 reset:
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Feb 11, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Message shows "Paper jam" but there is no paper jam
try turning off the printer for about 10 sec. to clear its memory and turn it back on.. then print again
Oct 19, 2009 | HP Photosmart C4250 Multifunction Photo...
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
Paper jam notification after printing one page, no paper jam
try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Nov 16, 2008 | HP PSC 2210 All-In-One InkJet Printer
Paper jam 11
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Nov 07, 2008 | Copystar CS-1815 Printer
Paper Jam
try this
alternative :
Sep 21, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Paper jamming
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Sep 05, 2008 | HP PhotoSmart 7760 InkJet Printer
E547
The E547 error relates to the feed motor: Service Req E547 Feed Motor Failure DRIVE ASSY FEED (Feed Motor) of the Feeder is not rotating at the specified speed. This is error is most often caused by electronic part failures rand is not easily rectified by the non professional user. Continuity needs to be checked on several parts of the harness as well as voltage and resistance tests to determine which part has failed. If the machine has warranty on it, you need to call Epson. Check my previous post on this item: http://www.fixya.com/support/t154259-paper_jam_e547
Jun 15, 2007 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 Printer Logo
1,354 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
