Question about Shuttle MV43VN Motherboard
Shuttle MV43V v7.3 front panel connections
Shuttle MV43V v7.3 front panel connections. This is the front header with the power switch, LEDs, reser switch
  • Tony Waldron
    Tony Waldron May 11, 2010
    Sorry will look for mor links as the 1s on the page listed do not work. Regards Tony
  • Shuttle Master
  • 3,606 Answers
Posted on Nov 16, 2012
2 Suggested Answers
SaintGene
  • 53 Answers
SOURCE: I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
http://eu.shuttle.com/download/Archive/Manuals/en/mv43p_n/mv43pen.zip
Good luck,
Don't forget to rate my solution, thanks!!!
Posted on Jan 17, 2009
Front panel connection to mother board Power switch pin
Hi careyfraser,
1. There are 8 wires from the front panel's casing, excluding USB connectors and front audio cable.
2. Just plug the front panel switch headers to the F_Panel main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note:The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Hopefully this information helps.
Thank you for using FixYa.
Sep 23, 2011 | Asrock G31M-S Motherboard
I need shuttle mv43v motherboard audio driver
Hi, you can download all the drivers from here:
http://global.shuttle.com/products/productsDownload?productId=588&osId=5&panelId=2
But there is only drivers for Windows 2000,Windows 98 / WinME
The file needs to be unziped before installation.
Hope this will help you.
Aug 20, 2011 | Shuttle MV43N Motherboard
I lost the connection's posisition of front power switch on my MS 7309, can you please send me a diagram of connections. thanks...
2. Just plug the front panel switch headers to the JFP1 main board connectors. 1 & 2 are positive, if the led do not light change polarity but Im sure it will.
Note: The mainboard provides a front panel connector for electrical connection to the front panel switches and LEDs. JFP1 is compliant with Intel® Front Panel I/O Connectivity Design Guide.
Thank you for using Fixya.
Aug 05, 2011 | Computers & Internet
New case and new motherboard, when trying to turn on computer, power button doesnt work
Carefully double check the connection header pins and the leads that come from the front panel for LEDS indicators and push button switches. The motherboard manual will indicate what the numbering scheme is for the header pins (which pin is #1, etc.) and where they are physically located on the board itself. You may have simply connected one or more switches and indicators to the wrong pin. Getting them straight should solve the problem.
Mar 19, 2010 | ASUS M2N68-AM SE2 Motherboard
How does the power switch and led plug up on a GT5428 motherboard?
This is Gateway Support, and Support Documents for the Gateway GT5428 Desktop PC,
http://support.gateway.com/s/pc/R/1009466/1009466nv.shtml
On this page left-click on Components.
Scroll down the page to the heading - Motherboards
Left-click on -
4006158R - Intel (Coryville) 945G Motherboard
Now Left-click on - Product Views
Lastly left-click on -
O - Front Panel Connector
This shows you a photo of the Front Panel header on the motherboard.
A connection on a motherboard is referred to as a Header.
The Front Panel of your computer is the plastic part where the Power On button is.
The Front Panel header on the motherboard is where the wires from the Front Panel connect to.
The above is not to offend you, or insult your intelligence. Just wanted to give you the exact names of the parts you'll be handling.
Looking at your motherboard with the Processor to the top, and the Ram slots to the right, the Front panel header is located in the very bottom right corner.
Looking at the Front Panel header on the motherboard, you will note the different colors.
There are also Pins that stick up out of the Front Panel header.
Every 2 pins is grouped into one color.
The Front Panel header is located parallel to the outside edge of the motherboard.
There are 2 rows of pins.
One row across the top of 5 pins.
One row across the bottom of 5 pins.
The pins are numbered, as well as grouped into colors.
Starting at the Right side, going towards the Left, on the Top row;
Pins 1, 3, 5, 7, and 9
Starting at the Right side, going towards the Left, on the Bottom row;
Pins 2, 4, 6, 8, and 10.
Pins 1 and 3 ( Yellow ) are for the Harddrive Activity LED.
The light in the front panel that flashes when the harddrive is actively being used.
Pins 2 and 4 ( Green ) are for the Power On LED.
The light in the front of the computer that shows when the computer is on.
Pins 5 and 7 ( Blue ) are for the Reset switch.
The Reset button on the front of the computer, IF, the computer came with one.
Pins 6 and 8 ( Red ) are for the Power On switch.
The Power On button on the front of the computer.
Pin 9 (Black) is for the +5 Volt power
Pin 10 is not used. (Not connected)
The reason I took you the long way, and did not just provide a link to the Front Panel header, is in case you need more information about your computer.
This way you'll have it.
Feb 26, 2010 | Gateway GT5428 PC Desktop
Shuttle mv43v v7.3 AGP card won't work
Go in the BIOS and disable the onboard video.
Feb 03, 2010 | Shuttle MV43VN Motherboard
Hi mrdcoe,
Good luck,
Jan 15, 2009 | Shuttle MV43VN Motherboard
DRIVER
goto this link and download.
http://www.downloadsource.net/408/Shuttle-MV43V-N-USB-20-Driver/
if it helps please rate this
thanks
daniel.
Jan 12, 2009 | Shuttle MV43VN Motherboard
MV43V motherboard by shuttle
Here are your MB specs:
MV43V/N - Supports Socket 478 Intel Pentium 4, Celeron with 400/.533 MHz FSB
- VIA P4M266A + VT8235 Chipsets
- DDR 200/266 SDRAM, 2 x 184 – pin DIMM, Up to 2 GB
- 2 x ATA 133
- 4 X AGP device, 2 PCI slots, 1 CNR slot
- Onboard AC97 audio two channels
- Onboard S3 Pro-Savage 3D Graphics
- Onboard VIA VT6103 10/100 Fast Ethernet (MV43VN only)
- 6x USB 2.0
- Micro ATX Form Factor
The your motherboard has an ethernet adapter all you need to do is download the drivers for the ethernet adapter and install them. here is the link : http://members.driverguide.com/driver/detail.php?driverid=206328 do a free subscription first. cheers
T
YE
Feb 16, 2008 | Shuttle MV43N Motherboard
Shuttle MV43VN Motherboard Logo
5,316 people viewed this question
Top Shuttle Computers & Internet Experts
Iqbal Husain
Iqbal Husain
David
David
Alun Cox
Are you a Shuttle Computer and Internet Expert? Answer questions, earn points and help others
