How do I copy AND enlarge a document on HP Officejet L7500?
I have a flatbed & need to enlarge the print when I make a copy of it.
  • jaspreetsing May 11, 2010
    Which Hp Model can use
You have scanned it and now you are wanting to print it larger?
All print drivers vary slightly, however, you should have an option after selecting "print" and depending upon the file type (Jpeg, PDF, Etc.) to select "Printing Preferences" or "Properties", and look for options like "Add/Change" custom settings", or "page setup" or something like that, and then there should be an option to enlarge, or maybe another option such as "finishing", and then "custom size". as I said Depending on the driver the "exact" steps can vary.
Posted on Feb 16, 2009
How does the HP Officejet 6500 enlarge? I have followed the instructions but prints regular picrure size, not enlarged.
You use the Copy button to get to Reduce/Enlarge. It will offer different sizes (i.e. actual size, full page 91%, custom 100%, etc.) you enter OK at the Custom 100%, then you can enter whatever % you want up to 400. I hope this helps.
Nov 20, 2010 | HP Officejet 6500 Wireless All-in-One...
My HP Pro 7780 has recently started making copies (through the feeder) with 2 large blank streaks down the middle of the page (lengthwise). I am worried that this is also happening when I send a fax as...
Does this happen when you print, or only when you copy? If you print out a configuration or user settings page, or print a page from the computer, is it also missing two vertical lines of print or is it only when you are copying?
If it happens when you print, you may need a cleaning, or you may need to replace the toner or drum cartridge. If it's an inkjet machine, there's a possibility there is some ink or grease on the encoder strip (a small belt-like plastic strip that goes through the print-head carriage).
If it only happens when you copy, test both the flatbed and the document feeder. If it happens on both then you may have a bad scanner. If it only happens when using the document feeder, you likely have some whiteout (or something) on the glass. When you make a copy in the flatbed, the scanner moves across your document. When you make a copy using the document feeder, the document moves across the scanner. In this case, if there is anything on the scanner glass (like whiteout) your copies will be missing a vertical line of print data (it could be white if there is whiteout on the glass, or it could be dark if something dark is on the scanner glass).
Usually you can lift the flatbed cover and look at the glass to see if anything is on it (usually at the left side of the scanner). Clean the glass, first with alcohol to remove the obstruction, and then with a little windex to remove anything the alcohol may have left behind.
Sep 23, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
Which HP printer can copy or scan legal size (81/2 X 14) documents?
You will likely need an Officejet model such as this one:
Officejet L7780
Here is another, but more expensive:
Officejet 8500 Premier
And...this one looked pretty reasonable:
Officejet L7680
These were the only ones I found with legal size flatbed scanning/copying.
Thanks for using Fixya.
Jul 02, 2009 | HP Office Equipment & Supplies
HP OfficeJet Pro l7500 won't print. Printer queue shows 5 jobs with error on first 2. I tried twice after rebooting the computer.How to print , or how to download proper driver? SB
Officejet Pro L7500 is giving me error message that it can see the black and yellow print head I have replaced it and it is still giving me the same error.
Is there a way to clean it with out having to have it taken in to be repaired?
Jun 10, 2009 | HP Office Equipment & Supplies
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Printing problems
Hi, Is this happening on the flatbed or the ADF?
Dec 03, 2007 | HP LaserJet 3390 All-in-One Multifunction...
277 people viewed this question
jasbo
jasbo
