Question about Linksys Wireless-G WRT54G Router
No output network
The hub connot adopt ant network from the raouter.
  • David
    David May 11, 2010
    Need better explanation.
  • 3 Answers
From what it sounds like is that you cant get a IP address from the Router? my advice is to reset it. Here is how.
  1. Unplug or turn off your DSL/cable modem.
  2. Locate, on the back of your Linksys router, the small button that reads Reset
  3. Press, and hold, the Reset button down for 30 seconds.
  4. Wait for your Power, WLAN and Internet light to turn on. (On the router)
  5. Plug in or turn on your modem.(if it is separate from the router)
  6. Open your web browser to see if you have an internet connection. If you still don't have an internet connection you may need to restart your computer.
P.S. sometimes the reset is on the back of the router.
Good luck! let me know if it works for ya!
-visanick
Posted on Jan 16, 2009
8ta 2gb sim package giving limited service error with zte mf820 lte usb modem. Same sim works on 3g in BB9810 mobile phone in same area. same in different telkom mobile areas. Modem works on 3g with Mtn...
You may need to upgrade to a newer sim card. There have been changes recently, esp. with the broader adoption of, and newer versions of LTE. LTE is a whole different radio system than 3g or even 4g. (It is actually 3g on super steroids) I think a sim upgrade should fix the problem.
Aug 11, 2013 | Lantronix LMR 8TA (LMR8TA-02) Networking...
Trying to download AVG anti virus program. Says "cannot open output file" HELP!!! Please!
Try downloading in safe mode with networking, power computer on and tap the F8 key, select safe mode with networking, try installing there. Click Here live tech support
Mar 04, 2013 | Microsoft Windows XP Home Edition
What is the output specification of the hub T1008c network hub
8 port 10 Base-T (10 Mbps) with a BNC for Coax cable connection.
Dec 04, 2012 | Compex Computers & Internet
No power,power indicator led won't lit.
Hello
That means that you have a problem with the power of your unit check the power adopter by a voltmeter if there is a 5 volts output if no voltage detected check the power source where your adopter is plugged. If there is an AC output on the outlet, check the output wire of the adopter. If the wire of the adopter have no problem on the connection check the socket where the output of the adopter is being inserted try to squeeze it while the adopter is being plugged to the AC. If the problem is still there look at the sticker of your unit if under warranty, if under warranty return it to the store where you buy it to avail the free service warranty. But if not under warranty you can fix it if you have a little knowledge in electronics. Because there is an internal damage on your unit either the power adopter of the unit or inside the unit.
If the adopter is only the problem you can open it by removing the one screw on the back of the adopter. See to it that the adopter is unplugged, then check the fuse of the adopter it is a small tube like component you can test it by a multi tester if there is a continuity it means the fuse is not busted but if no continuity it means you have to replace it with the same value. The second one is if there is a bulge capacitor. It means that if there is a capacitor that change there original shape, sometimes it blow sometime it just pop on the top of. Replace if there is a capacitor with look like that, Replace it with the value in farrad and in volts.
Hope this solution will help you
Sep 02, 2011 | KWorld TV BOX KWORLD|KW-SA220 1080I RTL TV...
How to setup my tl-sf1008d in my computer with other computer to play lan games with no internet..
ASALAM
CONNECT BOTH PC WITH CROSSOVER WIRE OR MORE THEN TWO PCS THEN ADD SWITCH LIKE TPLINK WITH STRAIGHT WIRE
LOOPBACK ADOPTER SHOWS LOGICAL CONNECTIVITY BETWEEN DIFFERENT COMPUTERTS WITHOUT INERNET
ON 1ST COMPUTER DO THE FOLLOWING !!
GOTO CONTROL PANEL
> ADD HARDWARE
>YES I ALREADY CONNECTED
>ADD A NEW HARDWARE(FOUND AT THE END)
>I MANUALLY SELECT FROM THE LIST
>NETWORK ADOPTER (CLICK NEXT)
>MICROSOFT
>MICROSOFT LOOPBACK ADOPTER
>GO TO NETWORK CONNECTION LOCATED IN CONTROL
>ASSIGN IP RANGE TO LOOPBACK ADOPTER
LIKE
IP 192.168.1.2
SUBNET 255.255.255.0
DEFAULT GATEWAY 192.168.1.1
DNS 192.168.1.1
ON THE SECOND COMPUTER PERFORM THESE STEPS
BUT WITH DIFFERENT IP LIKE SAME RANG 192.168.1.3
AND PING THE 1ST COMPUTER FROM THE SECOND
LIKE
ping 192.168.1.2 -t
TYPE THE FOLLOWING COMMAND IN RUN.
>IF YOU RECEIVE REPLY IT MEANS BOTH PC ARE CONNECTED TO EACH OTHER LOGICALLY.
>IF RECEIVE TIME OUT MEANS SOMETHING IS WRONG.
>PERFORM THIS STEP AGAIN FROM 1ST COMPUTER.
YOUR FILE SHARING AND GAMES START WORKING WITH NO INTERNET.
TO ACCESS FILES SHARING FROM PC2
\\192.168.1.3
REGARDS
MASSAM
WWW.BESTFASHIONSTYLE.NET
Mar 28, 2011 | TP-LINK TL-SF1008D 8-Port Ethernet Switch
Central home network
(add small 4 port hub) from cable router out to hub port 1.-take cat5 from central insert in port 2 of hub.- insert cat5 in port 3 of hub then other end in now open cat5 port
Jan 03, 2010 | CommScope 1000 FT RG6 QUAD/CAT - 5E 4 -...
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
Raouter canect to computer
hi frined
u have connect ur router in ur pc then after power on now
u have new router u have to configer ur router
go in ur internet exploer the router defolt ip is 192.168.1.1
type in ur address bar & press enter
then after loing screen come
user :- admin pw is admin
login ur router
&confuger its
Mar 31, 2008 | Blitzz Technology (BWA611) Router
How to solve the Power On Self Test in 3Com 610 Switch
This is the problem with power adopter. Please replace you adopter and let me know...
Rajeev
Dec 01, 2007 | 3Com SuperStack II 610 Networking Switch
Linksys Wireless-G WRT54G Router Logo
29 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
