Question about Insignia LCDTV26 26 in. Television
Flet screen tv insignia
We have insignia 26 after few minits it shot down by it self and i cant turn it on. please try to solve the probrem.
  • 2 more comments
  • Budman7557 Nov 11, 2007
    I have the same problem, tv turns off by itself and I cant get it back on. I tried unplugging it but did not work.
  • Shawn Pickelsimer Nov 15, 2007
    I have the same tv but kind of a different problem. The fuse in the power supply keeps blowing. Once i plug it in then BAM it blows.
  • Anonymous Nov 19, 2007
    I'm having the same issue except with mine doesn't shut down fully until about 3 min after the picture goes out. If I tap it the picture comes back on them goes right back off.
  • Bustoff Oct 25, 2008
    how do i access the power supply on this unit? i am a Computer Tech and am used to dealing wit the LCD's of LAptops as well as the size of Mainframes, but this thing baffles me LOL
    Jim
Check the caps. 2 big blue ones. They are prob bubbling on the top which indicates they are bad.
Posted on Aug 10, 2008
Why does my tv turn off by it's self after a few
Either a power board problem or something in the set is pulling the power voltages down---if under 26 inches it may not be fixable.
Mar 19, 2012 | Emerson Televison & Video
26" Insignia TV, screen is
Go to your menu and choose picture. See if your settings are normal or if the brightness is turned down. If it isn't then it's a problem with the T.V.
May 04, 2011 | Insignia LCDTV26 26 in. Television
Screen is gone really bright and turning down contrast or brightness doesn't fix problem. Insignia LCD 26 inch
try turning down the backlight option in your menu. You should be able to find that option under picture settings.
Aug 07, 2009 | Insignia LCDTV26 26 in. Television
26'' Insignia Startup Screen
This problem requires a service technician to check out you television for component failures on the power supply board and the main board. You have a failure in either drive voltage to power you video processor or a break down in the signal transferring components.It could be as simple as cold solder joints or a failure of capacitors in the signal processing circuits. They have a self healing components and will restore temporary operation for short periods of time.You could also have a failing video processor chip and chips that are being damaged everytime you turn your unit on.. These problems usually occurs from over heating going on inside you television. You need to get it checked out before it get worse.Here is the number for Insignia Customer service: 1-877-467-4289. Hope this helps you with your problem.
Mar 12, 2009 | Insignia LCDTV26 26 in. Television
26 inch insignia dvd/tv combo stuck in dvd mode and buttons and remote won't change or do anything
This is a long shot but, there may be a reset button on the back of the tv if not try unplugging it over night.
Good-luck
Rob
Dec 07, 2008 | Insignia LCDTV26 26 in. Television
Insignia tv 26 LCD tv/dvd combo problem
I have an Insignia 26' LCD TV with a built in DVD player and all I get on the screen is a box that says No Database.
Jul 26, 2008 | Insignia LCDTV26 26 in. Television
Parental lock
1) Try P-Lock and pasword "0000"
2) Turn TV off and unplug from wall outlet for 30 seconds
3) Check p. 9 and other relevant sections of your user manual.
4) Call Insignia at 1-877-467-4289
May 26, 2008 | Insignia LCDTV26 26 in. Television
Insignia FLAT screen LCD tv
It's more than likely over-heating. You can try a Battery BackUp with AVR (Automatic Voltage Regulation) built-in to see if possibly your electricity isn't coming in as cleanly as it should. If that doesn't do anything different for you then you'll have to take it to either a repair shop or back to Best Buy (if it's still under warranty).
Jan 03, 2008 | Insignia LCDTV26 26 in. Television
Insignia LCDTV26 26 in. Television Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
