Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Blinking green light and clicking noise AFTER bulb replacement
Lamp light was blinking every once in a of big would not come on (ugghh)...figured it needed a bulb since we had been warned for months, replaced bulb (bulb only replacement)*note, old bulb was definitely blown* and cleaned filter (first time ever-3 years), plugged tv back in and now we get a clicking noise and green light flashing after about a minute (flashes about 5 times and short pause then starts flashing again and continues cycle until you unplug...or reset and then it starts everything all over again. Did we do something wrong when replacing the bulb or cleaning the filter? We took back apart and everything is secure.....please help...Super Bowl coming up. :-)
  • 1,030 Answers
Do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Posted on Jan 15, 2009
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
The lamp light is blinking once every 5 seconds. The manual says that " Lamp will not light or light is abnormal"
Panasonic PT50LC13 lamp indicator blinks to tell you the lamp is faulty.
You need to replace the bulb or TY-LA1000 lamp assembly. This link displays all Panasonic TV Lamps and TV Bulbs. This page shows Panasonic lamp location and How to Replace TYLA1000 bulb. TY-LA1000 Bulb Replacement requires the use of a long Philips Screwdriver to reach screws within the lamp cage.
Unplug AC power before removing the lamp and re-install all doors, etc, correctly before starting the TV. Vacuum any visible dust or lint from air vents and lamp area. Do not used forced air to blow out dust, big problems may result.
The user's manual has a description of what the Blinking LED indicators mean.
Image of TYLA1000 lamp.
Apr 14, 2011 | Panasonic PT-50LC13 50" Rear Projection...
When the TV first went out there was no picture or sound so I replaced the bulb and had sound and pic for about 6 hrs total between 2 days of watching the TV. So I sent that bulb back and received an...
This tv have a board call the ballast board to help the projection lamp to ignite.U hear clicking noises mean the ballast board is dead,not doing it job igniting the projection lamp.
Jan 17, 2011 | Mitsubishi WD-57733 57" HDTV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
The screen went black. Last time I changed the bulb and it started working. This time the TV did not come back. The screen is black. The center Green light and the bottom red light blink. Samsung 567W
Make sure properly connected and tightly sure cover put on and screws in,if change projection bulb,still blinking "LAMP" LED indication light.But,if "LAMP"LED indication flashes and making clicking noise.Ur Ballast board also dead.Require replacement,this Ballast board help to ignite the projection bulb.
Jul 30, 2010 | Samsung HLN567W 56" Rear Projection HDTV
Mitsubishi WD-52327 TV won't consistently turn on, new lamp
the problem is in the power supply circuit
capacitor may be or so the click mean theres cap are leakink or get dry that why is so long to power on.
hope that give you a idea.
May 05, 2010 | Televison & Video
Panason PT-50LC13 TV won't come on, light blinks green then red
Ballast failure is more that likley the problem. Is the lamp light blinking,...once every 5 seconds? Discontinued part and can only be purchased used or rebuilt. Rebuilt units are available, check Ebay. Have a service type person confirm problem before throwing good money after bad!
Jan 03, 2010 | Panasonic PT-50LC13 50" Rear Projection...
Just replaced bulb and the tv still does not work? the green light flashes 9 times and the red light is solid
Double check the Lamp installtion. 2) make sure the Lamp DOOR is properly closed. 3) unpug TV from a/c outlet for about 5 minutes. pug back into a/c source.
Are you sure the green light is blinking and not the red light?
Good Luck, Big Irish.
Nov 22, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Flashing red light
I think this sounds like my problem (need to replace the projector lamp). However, when I hit the "on" button, my SXRD 50" blinks green for about a minute then starts blinking red. Can you confirm the bulb solution? I was very pleased with this sight when my fan malfunctioned. I got the fan in a matter of day's from Sony and it fixed that problem.
Oct 29, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
187 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
