Question about Texas Instruments TI-86 Calculator
How do I graph ordered pairs on a TI 86 plus?
I need help with graphing ordered pairs on my TI 86 calculator. How can I do it?
  • lmc2008 Jan 31, 2009
  • Texas Instru... Master
  • 7,993 Answers
Use the stat menu. Enter 1st member of a pair in List1, Enter 2nd member of pair in List2. Graph the data as a scatter plot in stats plots.
Hope it helps.
Posted on Sep 23, 2009
How to graph more than one equationTI-84 Plus Calculator
In order to select additional graphs, the Transformation Graphing Application will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the Application does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the Application.
• Press [APPS] key
• Select Transfrm from the menu
• Press 1:Uninstall
See cap images below
Apr 02, 2014 | Texas Instruments TI-84 Plus Calculator
Graphing cos 2x? i have a TI-86 but i think my problem is something that can be done on any TI calculator, i need to know how to graph cos 2x, all i get is a straight line
Your angle unit is set to degrees. If you do not change the Xmin and Xmax window dimensions to say -180 to -90 for Xmin, and 90 to 180 for Xmax you will not see much of the features of the graph; In the default interval Xmin, Xmax the curve is a staright line.
Sep 17, 2011 | Texas Instruments TI-83 Plus Calculator
Who invented this calculator and where it came from?
The first graphing calculator was invented by Casio Computers. of Japan in 1985 It was the Casio FX-7000.The lead engineer on the Casio 7000 development team was Hideshi Fukaya. About 5 years later, Texas Instruments introduced its first .
The Ti 84 Plus was introduced in 2004. Before the TI 84 plus there werer other graphing calculators by TI: 80/81/82/83/85/86/92/73
Aug 28, 2011 | Texas Instruments TI-84 Plus Calculator
Ti-86 Error Message--HELP!!
To restore memory on a TI 84 to factory settings follow the directions on pages 108 and 109 of the instructions manual (TI 84 Plus Silver). Otherwise look in the index for RESET MEMORY to get the right page. Be sure you read the precaustions!!!!!!
Dec 12, 2009 | Texas Instruments TI-86 Calculator
Whenever i try to link my calculator with other ones it always says error in xmit. no matter what i do
Read the following answer from the TI Knowledge Base.
Hope it helps.
How can I troubleshoot an Error in Xmit error message when transferring data between two graphing calculators?
The Error in Xmit error message is returned when a connection cannot be established between two calculators when attempting to transfer data. There are several factors that can contribute to this error message.
• The calculators being connected are not compatible for data transfer.
• The data cable is not firmly connected to both units.
• The receiving calculator is not in receive mode.
• The I/O port on one of the graphing calculators is damaged.
The procedure for connecting two graphing calculators is as follows:
• Connect the data cable to the I/O port of each unit. The cable will fit tightly in the I/O port and snap into place. If silver from the cable is visible, the cable is not properly connected.
• Access the Link menu on each unit
• Place the receiving graphing calculator on "Receive"
• Place the sending unit on "Transmit" or "Send" from the Link menu.
Once the data has been selected, the transfer will commence accordingly.
The data transfer protocols for graphing calculator is as follows:
• TI-73 - Link allows data sharing with another TI-73, TI-82, TI-83, and TI-83 Plus.
• TI-82 - Link allows data sharing with another TI-82.
• TI-83 - Link allows data sharing with the TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-83 Plus/TI-84 Plus family- Link allows data sharing with another TI-82, TI-83 family calculator, and TI-84 Plus family calculator.
• TI-85 - Link allows data sharing with another TI-85(To a TI-86. Not From a TI-86).
• TI-86 - Link allows data sharing with another TI-86 and from a TI-85 to a TI-86.
• TI-89 family- Link allows data sharing with another TI-89 family calculator and from a TI-92 family calculator.
• TI-92 family- Link allows data sharing with another TI-92 family calculator and from a TI-89 family calculator.
• Voyage™ 200 - Link allows data sharing with another Voyage 200 and TI-92 family calculator.
If the cable does not fit properly into the I/O port, or if the I/O port appears to be damaged (broken or separated plastic, obstruction inside the port), call 1-800-TI-CARES (1-800-842-2737) M-TH 8:00 AM - 7:00 PM FRI 10:00 AM - 7:00 PM Central Standard Time to speak to a representative or sending an email to ti-cares@ti.com.
Oct 22, 2009 | Texas Instruments TI-83 Plus Calculator
Error 13 dimension
You were lucky not to see the dimension problem with the TI83Plus.
To get rid of the message, reset you calculator to DEFAULT configuration. It will erase nay garbage in the registers and you can draw your graph.
Hope it helps
Apr 02, 2009 | Texas Instruments TI-86 Calculator
Graphing Issue
Are there funny arrows at the left of your Y= screen?
ti83oops_c.gif The illustration and solution are courtesy of Jesse Phillips, who cites this page from the Texas Instruments support site:
In order to select additional graphs, the Transformation Graphing App will need to be uninstalled from the TI-83 Plus Family and TI-84 Plus Family. Uninstalling the App does not erase it from the calculator, it disables it from interfering with the normal graphing modes. Below are the steps to successfully uninstall the App.
  • Press [APPS] key
  • Press 1:Uninstall
http://oakroadsystems.com/math/ti83oops.htm
Mar 19, 2008 | Texas Instruments TI-84 Plus Silver...
Graphing
The first solution will allow you to watch your calculator graph two equations simultaneously rather than finishing one before graphing the next; it won't solve the problem of having the calculator unselect one equation when you select a second. To fix that problem, try the following:
  • Press [APPS] key
  • Press 1:Uninstall
- doug garfinkel, Children's Day School
Jan 15, 2008 | Texas Instruments TI-84 Plus Silver...
TI-86 Calculator Problem
Most likely you're trying to graph a function while you have the stat plot turned on. Turn off the stat plot and try it again.
Oct 16, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
350 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
