Question about Sony Xplod (P589) Car Subwoofer
12" sony subs not working
I bridged my subs they worked for a while and then quite working after about a month.
i have 2 12" 1300w
with a 1000w sony amp.
i dont think they are blown because they dont move at all.
i dont kno what to do!!!!
  • 3 more comments
  • sillyerinfac Jan 16, 2009
    the fuse under the hood is still good and the power protection light comes on also.
    the green light comes on. and everthing is connected right.
  • sillyerinfac Jan 17, 2009
    i already unbridged it.
    i'm not the one who did it. it was my boyfriends friend.
  • John Larsen May 11, 2010
    does the amp power up?? and is the protection light coming on??
  • easyq
    easyq May 11, 2010
    I think the problem is nto your subs but your amp, did you check if that still works or if the fuse is blown?
  • 46 Answers
It could be the rca outputs on your deck...Try new ones
Posted on Jan 17, 2009
  • 3 Answers
Disconnect both subwoofers and a. get someone who has an ohmmeter to check speaker resistance which should be around 4 ohms or no meter B get hold of a D Dell battery 1.5v and connect across pos and neg speaker terminals cone should move in or out depnding on polarity pos to pos forward excursion if voice coil is not cooked or seized ...if speaker dead no movement wait 10 years till you can appreciate moderate bass and not duuf duuf then replace the speaker and you will have no further problems Most car speakers are rated in RAT Watts but in reality they perform like little mosey watts ataraxia
Posted on Jan 16, 2009
    Scholar:
  • 144 Answers
If all co0nnected properly and working except the woofers only thing to check is to disconnect the bridge and try to connect regularly one woofer at a time to see if it still works.
  • easyq
    easyq Jan 18, 2009
    OK, it seems your amp is receiving power but is not transmitting signals to your subs. You have to work this way out startingwith the cable between amp and subs. Check if it works and if it is connected properly. You can check it by connecting it to another speaker (prefereably a car speaker) and see if that produces any sound. To be sure it is not the cable, also connect that other speaker to the same connection on the amp with a different cable. If no succes in both tests, your amp is not giving any signal on it's speaker terminals.
    In that case you have to verify if the amp is receiving any signal.
Anyone know what the rms is per channel on xr-3693 1000w amp? Is it 250 apiece? And if i bridge sub..will that make it at 500rms?
I would assume this is 1000W peak-to-peak, so divide by 2.83 = 350 rms, or 88W rms per channel.
See link for bridging information:
Apr 20, 2016 | Car Audio & Video
What would be the best settings on a pyramid arctic 1000 watt amp for one JL audio w1 12
Your sub is a 4ohm woofer, running it in bridged mode + on right connection - on left connect as market on sub will give the best output. Your sub is rated at 75w to 300w and in this configuration will be getting just over 100w which about all the amp can provide with your sub/amp combo.
I don't know where they get the 1000w rating from either? the maximum the amp can possibly provide is 150w if running a 2ohm woofer in bridged mode.
Mar 08, 2012 | Car Audio & Video
I have a sony xplod 1000 watt amp, Worked perfect for a month, All of a sudden my subs stop working, But the power light on the amp is always still on. every great while my subs will work again, sometimes...
make sure ur running the right ohm load and if its two channel try bridging it. if already bridged unbridge another thing to check is rca wires i had the same prob with a 1000w explode 2 channel
Oct 12, 2010 | Car Audio & Video
Sony Xplod Amplifier Problem
First make sure you are using at least a 12 guage speaker wire for sub connections. Second make sure you have plenty of breathing room in your mounting position, these things need air badly. Third of all, Xplods are not very friendly if they are cranked all the way up on your dB boost knob. Only crank it about 3/4 of the way up, then use your equalizer settings to tweak the thump.
Oct 20, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
I have linertec LA-8 olx Amp
IF ITS A POWERED SUB,,JUST USE RCA JACKS TO THE SUB TO THE RECIEVER VIA THE PLUG THAT SAYS SUB
May 14, 2009 | Yamaha HTR-5850 Receiver
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod 1000 watt car amp quit working.
Almost all after market amps use 12v at very very low amperage to trigger the amp on. A temporary jumper from the battery plus terminal on the amp AFTER the battery and ground wires are attached should cause the amp to turn on. I would check to see if you have attached your speaker load correctly ESPECIALLY if you are bridging. Most of the blown amps that come into my shop are due to incorrect bridging loads from the speakers. Note that a 4ohm load bridged across both outputs of an amp will deliver a 2ohm load to each of the channels. When you parallel wire two 4ohm speakers together and then attached them to a bridged amp you will be putting a 1 (one) ohm load to each channel of the amp. Please don't make this mistake. It will fry your amp in about a month. Hope this helps. Good luck.
Feb 03, 2007 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony Xplod (P589) Car Subwoofer Logo
166 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
