Question about GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel
Jtp18ww2ww display is blank, nothing works
Display blank, replaced original RobertShaw control unit with Torisan ERC3H along with updated door latch. Still blank, oven light comes on because door is removed but that is the only sign. Bypassed both Fan Thermal Switch and Thermal Limit Switch. No change, display still blank. Help.
SOURCE:
Krazytech
  • 725 Answers
SOURCE: Oven not lighting
Hi The gas valve will not open until the ignitor pulls enough amps around 3.2 . so from the infromation you wroke you may need a new ignitor..let me know what you can find out..
Posted on Sep 03, 2007
  • 213 Answers
SOURCE: the touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Posted on Nov 21, 2007
SOURCE: GE Spectra XL44 Gas Oven, flashing "Locked Door". Can't use oven or close door
I had the same problem happen tonight. I have an XL44 self-cleaning gas range. We unplugged it for several minutes and pressed 'cancel' a bunch of times--neither worked. We finally lucked out--opened the oven door and pressed a black button on the upper left side of the front of the oven. It turned out the flashing words and unlocked our door. Weird. There was nothing in the manual about this...
Posted on Dec 28, 2008
mgprice
  • 744 Answers
SOURCE: GE oven functional code F1 appears.
Hello, I come across this problem quite often, The f1 error code does not always follow that it is a bad EOC (Electronic oven control) This could also be a problem with the touchpad. The way to figure which is bad is turn electric off, access the EOC and pull the wire harness/ribbon tape for the touch pad. Reassemble the range and switch power back on. If you are still getting the F1 it is the EOC..If the F1 clears then your problem is with the Touchpad. If you have any other questions please feel free to comment again. Good Luck!!! Mike
Posted on Aug 18, 2009
fixyourboard
  • 310 Answers
SOURCE: ge xl44 stove digital display clock stop working.
We see this failure due to two possible problems with the electronic control. Sometimes there is a failure that causes the display to shut off. Other times the display itself goes bad. The first case we can repair. If you send us the board we can check it out. If it is not repairable there is no charge. - www.fixyourboard.com.
Posted on Sep 30, 2009
I am working on a Frigidaire washer model LAFW3511KWO custmer say it stopped when she trys to start it door latch just hums? Bad board.or latch?
Thank you for your inquiry, Larry!
From the information you have provided your Frigidaire washer is humming when you attempt to start a cycle. This could be a possible issue with door latch or control board. Does the washer display any error codes? I would recommend checking for any damages or cracks along the door strike or door latch that could cause the washer to not show a connection between the two. If there is no damage, you would need to disassemble your washer and test out the control panel and door latch. I hope this information is helpful to you. -Matt
Aug 31, 2015 | Frigidaire Washing Machines
J SP420 NIBB GE oven Display reads FC locked door and oven will not work but stovetop works.
The "FC" error code means that there is a failure in the door lock circuit.
You may want to check the switches in the door latch first. Then check the wire harness from the door latch to the control board. If there is nothing wrong, replace the control board.
You may need to get an appliance repair person out.
Mar 18, 2011 | GE Ovens
Won't spin
I replaced the door switch/latch assembly. It works!
Sep 03, 2009 | Kenmore 43142 Front Load Washer
No display on Robertshaw 9600; unit seems dead/furnace works
have you checked to make sure you have a fresh battery in it
Jul 25, 2009 | Shaw Robert RS-9420 Thermostat
Oven wont come on -I get E1 F5 on display.
Self clean latch will not lock
If door not latched:
A. Disconnect power from unit.
B. Check wires and connectors from control to latch switch, then from latch switch to control. If no damage to wires and all connectors okay, proceed to step C.
C. Repeat steps A and B for door switch.
3. Measure door switch (door open = switch open small low voltage terminals). Replace switch if defective.
4. Measure latch switch (unlatch = switch open, CAUTION - oven light contacts are closed). Replace switch if defective.
5. If corrections are made in any step, reconnect power to control. Press and hold any key for 1 minute to clear R failure code from memory. F2 will appear. Press CANCEL and observe for 1 minute to ensure operation is correct.
6. If failure remains, disconnect power and replace control.
Jul 04, 2009 | Whirlpool Ovens
Control display blank
Probably low voltage transformer shot. Replace.
Dec 29, 2008 | Whirlpool GY396 Electric Kitchen Range
Beko WMA 765s washer, power works no display
If there is power and lights are showing, but the door will still not open, then it could be one of several things.
First and foremost the door lock could be faulty, or the door handle or latch mechanism could be faulty or broken, if the door lock is not getting power then it is probably the main cotrol unit at fault.
I feel you should get someone to look at it for you.
Dec 07, 2008 | Washing Machines
Display shows nothing, microwave cuts off
You need a couple of cheap microswithes that the door latches hit when you close the door and a new control for your display problem which sharp has had a problem with
Oct 30, 2007 | Sharp R-1405 / R-140 Microwave Oven
GE Profile 30" Self-Cleaning Freestanding Double Oven Gas Range - Stainless-Steel Logo
89 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
