Question about Texas Instruments TI-86 Calculator
How do you clear out information that you previously entered?
I have the TI-86 Plus & I was just wondering how you delete information that you previously entered, such as in a table?
I can't find a way to delete it or clear it out, so that I can start over on the problem.
  • Texas Instru... Master
  • 7,993 Answers
Press [2nd] MEM and select menu Reset, and follow instructions.
Hope it helps.
Posted on Sep 23, 2009
I have a TI-86, whenever i input - it shows Ans- and then it show that is an error. how can i fix it.
The - key is for subtraction, an operation that needs two numbers. If you press - as the first key on a line, the calculator assumes you want to subtract something from the previous answer, Ans.
If you want to enter a negative number, use the (-) key on the bottom row of the keyboard, just to the left of the Enter key.
Apr 05, 2016 | Texas Instruments TI-86 Calculator
How to factor
The TI 86 calculator does not manipulate algebraic expressions. If does not have a Computer Algebra System or CAS. Try the TI 89 Titanium, TI92/92PLUS, Voyage 200 PLT, TI Nspire CAS, TI Nspire CX CAS. In Casios you have the ClassPad series (300, 300Plus, 330 Plus and the latest 400. The ClassPad 400 has a color screen. It is also orientable portrait or landscape. Other Casios are the Algebra FX 2 and 2, and the FX 9860 G Plus/ SD. In HP you have HP 50G, HP49C, HP49G+.
Sep 11, 2013 | Texas Instruments TI-86 Calculator
What is the different between ti-86 and ti-83
The 86 has more memory. It also has some advanced calculus capabilities the 83 doesn't. However you're much more likely to see examples for the 83 in textbooks and other references.
TI-83:
http://www.ticalc.org/basics/calculators/ti-83.html
TI-83 Plus:
http://www.ticalc.org/basics/calculators/ti-83plus.html
TI-86:
http://www.ticalc.org/basics/calculators/ti-86.html
Aug 09, 2011 | Texas Instruments TI-86 Calculator
I deleted the information for my window for my ti 84 plus silver edition help
First exit out of any applications and make sure you are at the home screen. You can do this often by pressing "2nd" then "Mode" to quit or by pressing "Clear." Then, press the blue button titled "2nd" and then hit enter. The most recent thing you have entered in the calculator will appear on the screen. Doing this again will give you the second most recent, then the third and etc. Good luck!
Jun 01, 2011 | Texas Instruments TI-84 Plus Silver...
Does my ti-86 solve sq. root problems
Yes, your Ti 86 should solve square root problems. At the HOME screen press [CLEAR] [2nd] [x^2] which gives the (Square Root Symbol) to display at the Home screen. Then enter the number you want the square root of and close the bracket [ ) ] and, press the [ENTER] key.
You can even get the square root of complex numbers too. Select the correct complex format in the mode settings. For example: I'll do one in the rectangular form by enter a number as (a, b). I then will go to [2nd] [MODE] then [Arrow down] 3 times and make sure the RectC is highlighted and selected. Then quit out of the mode settings screen and enter [CLEAR] [2nd] [x^2] [ ( ] [9] [ , ] [ - ] [4] [ ) ] [ ) ] [ENTER], this displays the SQRT((9,-4)) equals (3, 2); The real part is 3 and the imaginary part 2.
Jan 09, 2011 | Texas Instruments TI-86 Calculator
Ti-86 Error Message--HELP!!
To restore memory on a TI 84 to factory settings follow the directions on pages 108 and 109 of the instructions manual (TI 84 Plus Silver). Otherwise look in the index for RESET MEMORY to get the right page. Be sure you read the precaustions!!!!!!
Dec 12, 2009 | Texas Instruments TI-86 Calculator
How to clear memory on my TI 83 Plus?
2nd +
delete
all
scroll to L1and L2
press delete or enter (i have an 82)
Feb 07, 2009 | Texas Instruments TI-83 Plus Calculator
How do I graph ordered pairs on a TI 86 plus?
Use the stat menu. Enter 1st member of a pair in List1, Enter 2nd member of pair in List2. Graph the data as a scatter plot in stats plots.
Hope it helps.
Jan 15, 2009 | Texas Instruments TI-86 Calculator
TI 86
Press "2ND" "MATH" "F3" to invoke the Angle menu.
Enter the number of degrees, press "F3", enter the number of minutes, press "F3", enter the number of seconds, press "F3", then press "ENTER".
Feb 15, 2008 | Texas Instruments TI-86 Calculator
Standard Deviation
Texas Instruments TI-86 Statistics How-To Information The following instructions should allow you to calculate the mean and standard deviation using a TI-86 calculator.
  1. Press STAT
  2. Select EDIT
  3. Enter data into a list: [2.32 ENTER 2.43 ENTER 2.39 ENTER, etc.] Continue until all data have been entered. (use arrows keys to go to the y value, if any)
  4. EXIT until you reach the main ("blank") screen. (If you try to calculate while you're in the data menu, it thinks you're still trying to enter data!)
  5. Press STAT
  6. Select CALC
  7. Select OneVa
  8. Select LIST, NAMES, xStat(F2), Press ENTER
  9. The calculator provides Max, Min, Mean, Standard Deviation, Sum, Sigma, etc. You will be primarily interested in the Mean and Standard Deviation (sx).
Nov 15, 2007 | Texas Instruments TI-86 Calculator
Texas Instruments TI-86 Calculator Logo
81 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
