Question about HP Color LaserJet 4550n Printer
HP 4550N - Vista Won't Communicate
Hello:
I recently got a Vaio Laptop and I have been attempting to print from my HP Color LaserJet 4550N printer. I have downloaded all HP drivers for vista, and have yet to make any progress. Unfortunately, I do not have wireless at my office, so this has to be connected manually. I can not be sure what I might be doing wrong, since I never had this problem with XP. Any help offered would be most appreciated.
Thank you,
CG
  • 3 more comments
  • cgomez347 Jan 15, 2009
    This is a 64-Bit laptop.
    Thanks,
    CG
  • cgomez347 Jan 16, 2009
    I am connecting it manually, but the problem is I am trying to use a usb to parallel cord, which I then connected to another cord so that it would fit the printer port. I then figured out that this does not work due to signal difficulties with the cable I was using. Is there any way to find a cable that would work between the Vaio VGN-CS190 and the HP 4550N?
    -I have used all drivers, and obviously it was the cable that was not working.
    Thanks,
    CG
  • Wayne Mineard
    Wayne Mineard May 11, 2010
    Is your operating system a 32-bit or 64-bit system?
    Right click on the Computer icon on your desktop and select Properties. It should have it on the window that opens.
    Comment back.
  • Wayne Mineard
    How are you connecting the Vaio to the printer? This printer only has a parallel connector plus the RJ-45 slot for networking, correct?
    (The previous question about all 3 drivers may or may not be anything. I just didn't think it was necessary.)
  • Wayne Mineard
    Next question: Which driver did you download? PCL5, PCL6, or PostScript?
    In your original post, you said you downloaded ALL the HP drivers. You didn't download and install all 3 drivers, did you?
  • 112 Answers
Http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Also try with another USB cable, If you are using a long cable, just try with a short one.
Posted on Jan 19, 2010
    President:
  • 1,901 Answers
You can probably find something at Tiger Direct or at Cables To Go.
Check this site out and see if the cable looks like the one you need:
USB to Parallel Cable
There are a couple of Zoom pics for a better view.
Hope this helps.
W
Posted on Jan 16, 2009
  • Wayne Mineard
    Wayne Mineard Jan 16, 2009
    I was just thinking another way to get around the problem would be to buy a router or wireless router and set up a small network. You would be able to connect the printer to the router and connect the computer to the router by an RJ-45 cable or wirelessly.
    I am not real experienced with networking so I will have to defer any expertise to others.
    Good luck.
    Wayne
Sometimes one of the 4 colors won't printed on paper. No error codes :(
Hi
Try running the inbuild clean print head programs and do alignment also remove the cartridges and check for any ink stains and clean them up your head might of gotten dirty
Peace
Nov 26, 2009 | HP Color LaserJet 4550n Printer
Error code 54.2 on a HP printer 4550N
54.2 is a carousel rotation error, could be loose toner that needs cleaning, a cartridge not seated properly, anything that can stop the rotating assembly from turning or sensing that it's turning.
Aug 27, 2009 | HP Color LaserJet 4550n Printer
Hp 4550n printer not printing
How is the machine connected to the computer?
Mar 14, 2009 | HP Color LaserJet 4550n Printer
PRINTER CONTINUES TO PRINT BLANK PAGES NON STOP.
I found some info regarding this at the HP site. Go to this link and you will find the error code descriptions:
Good Luck!
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl08400#A10
Mar 13, 2009 | HP Color LaserJet 4550n Printer
Printer wonk print when installing refilled cartridge to hpC5280
Try to work with option menu. (Ok, Cancel, Resume)
Kartridzh must on board have a chip otherwise will not work.
Mar 06, 2009 | HP Color LaserJet 4550n Printer
Printer prints blank pages.
 it a transfer belt issue....there is a test you can perform to confirm. When the first page comes out of the printer blank, open and close the back cover. If the next page comes out with print on it, then the transfer belt is the issue. One thing you can try is take the old belt down to a service station with a good air compressor and then use the air compressor to blow the heck out of the belt until no more toner comes out.
Mar 04, 2009 | HP Color LaserJet 4550n Printer
Color laserjet 4550n - printer will not print. It indicates that it is ready, however, it does not seem to accept print jobs that are sent to it.
try doing a self test print, if that works then you most likely have a communication problem between your computer and the printer. Try unplugging the usb cable and plug it back in see if you get any response.
Jan 30, 2009 | HP Color LaserJet 4550n Printer
HP 4550 PRINTER PROBLEM
Go to Control Panel\Hardware and Sound\Printers and add a printer. Select it as a network printer, and stop it searching (unless it finds it of course - which sounds unlikely!) Then click on "The printer that I want isn't listed"
Choose to add a printer using the IP or hostname, and click next.
Type in the IP address of the printer. This can be found by printing out the network configuration page from the printer. The port will be filled in for you. Click next.
The printer should now be added.
Dec 10, 2008 | HP Color LaserJet 4550n Printer
HP Color Laserjet 4550N
This is a common error code meaning that the printer does not understand a command. Redearch suggests that you try the following:
Be sure the printer does not go thru a power strip, but is plugged directly into the wall.
Check the printer cable, maybe swap it with another one.
Reseat the memory and formatter board.
Lengthen the power saver time to the maximum
Try printing from a different application
There have been cases where replacing the intermediate transfer belt has solved the problem.
May 09, 2008 | HP Color LaserJet 4550n Printer
HP Color LaserJet 4550n Printer Logo
Seeker5211
Seeker5211
