Question about Samsung PS42S5H 42 in. HD-Ready Plasma Television
No picture when i switch on the sound works fine but i do not get a picture
0 characters
1 Points
My Magnavox 42MF231D/37 TV has no picture
Call Magna vox tech support. Sounds like you need a new set. They may have you factory reset the set.
Feb 20, 2015 | Magnavox Flat Panel Televisions
Samsung 46 inch lcd no picture only sound
Could be backlight or the Invertor. While the sound is operating shine a flashlight into the screen and see if you can see the picture or not then let me know and I will assist you. But I will also need the model number of the set.
Feb 08, 2012 | Samsung Flat Panel Televisions
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
No picture but still has sound. switch off and picture comes back
i haven`t got a solution, however mine has just started to do the same. can you let me know if u got the problem solved. thanks
Jan 31, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
Switch on, picture for 5 sconds, then go black, sound fine
ime in the same boat man cant get nothing on mine
Jan 25, 2009 | Goodmans W280NS Television
Ps3 gets sound but no picture when using hdmi cord
you need an optical lead for the sound and hdmi for the picture
Dec 29, 2008 | Philips 23PF4321 23 in. HD-Ready LCD...
No sound through ps3 hdmi
I have sound on video 2, and when on a static channel but not on the usual channel 3 which is TV. Just stoppen working one day and cant figure it out... Please help!
Oct 19, 2008 | Flat Panel Televisions
Sound but No Picture
Perhaps your remote is set to video recorder?  Try that first, and if no response, try calling up a menu on your TV and look for the Picture Settings.
Good Luck.
Nov 03, 2007 | LG 37LP1D 37 in. LCD Television
Samsung PS42S5H 42 in. HD-Ready Plasma Television Logo
35 people viewed this question
Top Samsung Flat Panel Televisions Experts
xxxxxx xxx
Steve McIntosh
Level 1 Expert
Steven Wander
Steven Wander
Are you a Samsung Flat Panel Television Expert? Answer questions, earn points and help others
