Question about Brother MFC 420CN All-In-One InkJet Printer
Just brought new black cartridge installed 6 times,
Every time it says no cartridge open and reinstal
  • 298 Answers
Did you peel off ALL the contact-protective tape? Did you maybe touch the connector pads? If so, grab an eraser and scrub it clean (shiny) again. Fingerprints have oil and will mess up the connection.
Also, look into the printhead socket and make sure there is no dust, fluff or paper bits in there too.
Did you remove/reinstall new with power off? It HAS to be on ;-)
Did it automatically do a 'cleaning' to get the new ink flowing?
b/c it is an All in One. you will probably have to put the printout on the scanner glass (favce down) so the printer can realign itself to the new cartridge.
As a last resort (it is Windows, right??) Reboot the machine and it will FIND and TEST the printer status again
Posted on Jan 15, 2009
Printer not accepting new black ink cartridge
put that cartridge in and perform a head cleaning process, and allignment... follow the procedure (2 or 3 times if needed) and in the end, shut down the printer, disconnect usb cable (both end), then wait for some time, aprox. 20 sec. and then put both end in again, turn printer on and wait for ready signal or some sort of confirmation that all is ok... If not, replace or update the printer driver and software, or reinstall all printer software.
Apr 22, 2014 | Epson R1900 Printer
I am refilling the black ink of my canon printer using continuous ink container but the black color doesn't flow into the end of the hose and it didn't print at all, please help
  • Check the printer's power/alarm light. If it is flashing orange, count the number of flashes. Look up the flash code in your printer's user manual to diagnose the problem.
  • 2 Remove and reinstall the ink cartridges if the power/alarm light flashes 5, 7 or 15 times consecutively. This indicates that the issue is a cartridge error, an incorrectly installed cartridge, or an unrecognized cartridge. These errors can be fixed by reinstalling the ink cartridges. Make sure that you are using the correct ink cartridges for your Canon printer.
  • Turn on the printer and open the front cover. The ink cartridge holder should move to the replacement position.
  • 4 Verify that the colored ink cartridge is inserted in the slot on the right and the black ink cartridge is inserted in the slot on the left. Swap the cartridges and reinstall them in the correct slots if necessary.
  • 5 Check to see that both ink cartridges are level with one other and parallel to the top of the ink cartridge holder. If either cartridge is wedged at an angle, gently apply pressure to the cartridge until it clicks into the correct position.
  • 6 Close the front cover of your Canon printer and wait while the printer initializes the newly installed cartridges. This can take a minute or two.
  • Jun 12, 2011 | Office Equipment & Supplies
    I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
    hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
    Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
    Printer not working. The light flashes red six times.
    Error Condition Indicator Beeps Error
    Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
    Code
    Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
    Oct 01, 2009 | Canon S400 InkJet Printer
    Compatible ink cartridges not working
    either the cartridge circuit is damaged or there is a problem with your printer. To make sure, you will have to try the cartridge on another similar printer. If it works on another printer, the problem lies with your printer.
    May 23, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
    Canon PIXMAR MP150 E5 problem
    hi,
    CANON PIXMA MP160 All-In-One InkJet Printer
    has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
    http://www.canon.com/printer/prob676ijt65/solution
    toi-i-28
    Apr 10, 2009 | Canon PIXMA MP160 All-In-One InkJet...
    Black ink cartridge
    Usually a contact issue. Try wiping the contacts in the carrier as well as the contacts on the cartridge. I have even cleaned the cart. contact with a pencil eraser then wiped them. If this does not work try a new cart.
    hope this helps
    Mar 04, 2009 | HP DeskJet 970cse InkJet Printer
    Epson stylus photo 1290 'bk ink cartridge not installed properly'
    Ameter:
    Remove the black ink cartridge.
    Check the place where the new cartridge should go. Check for a round small piece like a bushing or a little piece of pipe, stuck at the ink entrance of the printing head. This is a piece from the old cartridge, that sometimes gets loose and remains in place,and when the new one is placed, it doesnot go down to the right place to make contact with the electric connectors in the printing head.
    If nothing solves...reinstall the printer drivers.
    Good luck and Merry Christmas
    Emiliosan
    Dec 09, 2008 | Epson Stylus Photo 1290 InkJet Printer
    Error 50
    Is that an error code "Cartridge Error 50C" ? If so, see below....
    Cartridge Error 50C: Your print cartridge has shorted.
    1. Power off your All-in-One and unplug it.
    2. Plug in your All-in-One again and turn it on.
    3. Uninstall and then reinstall your cartridges.
    4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
    Error: Black Cartridge Missing - The black cartridge is not installed. (Install cartridge PN 82)
    Error: Color Cartridge Missing - The color cartridge is not installed (Install cartridge PN 83)
    Cartridge Error: Complete the following instructions:
    1. Power off your All-in-One.
    2. Use both hands to lift up the scanner unit until the scanner support holds it open.
    3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
    4. Remove the color print cartridge.
    5. Lower the scanner unit until it is completely closed.
    6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
    7. Reinstall the color cartridge and remove the black print cartridge.
    8. Lower the scanner unit until it is completely closed.
    9. If the error message occurs again, replace the color cartridge.
    10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
    11. Lower the scanner unit until it is completely closed.
    12. If you receive the error message again, replace both cartridges.
    Nov 22, 2008 | Lexmark X5150 All-In-One InkJet Printer
    HP Officejet 6310 All-in-One ''Cartridge Error: Cartridge on ...''
    Hi for solution do this
    First put out of the printer the Ink Cartriges then
    press 4 + # + OK this send you a info menu
    with the nav. Keys go to CHECKSUM FOR RELOCK DATA IMPUT press Ok 5 times . Then Go out there by pressing Cancell Button ant there you go if this dosnt work at the 1rs time you need 2 o 3 times more to ensure relock data ok
    bye :)
    Nov 14, 2008 | HP Officejet 6310 All-In-One InkJet...
    Brother MFC 420CN All-In-One InkJet Printer Logo
    32 people viewed this question
    James Cagle
    James Cagle
    Samyfam
    Samyfam
    Jim Keysor
