Question about Bryant 462AJC021BA Air Conditioner
Furnace will not come on thermostat gives code of E2.
Tries to come on and trips breaker
David
    President:
  • 267 Answers
I am sorry to tell you that most of the time its a shorted compressor . you will need to call a contractor out , there is nothing you can do . sorry , good luck to you
Posted on Jan 15, 2009
Furnace runs awhile then breaker trips
Electric furnace I assume- check with amp meter, if amps are below listed on breaker, replace the breaker, [check both the breakers in the furnace and in the house pannel, even if only one is tripping right now, the other(s) may start doing the same thing after you eliminate the weakest link- don't be surprised!] electric furnaces are notorius for "eating" breakers- they overheat the breakers for years then the breakers get weak and trip too easilly... if gas, post more info and I'll try to help further.
Feb 20, 2013 | Heating & Cooling
My breaker trips when the outside unit tries to turn on. The inside furnace runs. I cut the inside unit off and the breaker doesn't trip. I manually turn on the outside unit by depressing the cont
Hello, there is a short to ground somewhere, check all the wiring from the inside un it to the outside unit and make sure nothing is touching metal.
Jun 10, 2012 | Goodman Heating & Cooling
Furnace keeps tripping the breaker changed breaker and wires all good up to the furnace still keeps tripping when i try to turn power on. nothing happened to the furnace and the wires were tested up to the...
Disconnect the black power wire where it is connected to the furnace with breaker off. Put a wire nut on it and then turn the breaker on. If it continues to trip, the problem is not the furnace and you will have to trace the power wire back to the breaker box to find problem. Next, disconnect the black wire from the breaker (with breaker off) and then snap breaker on. If it trips, bad breaker. If the furnace was disconnected and breaker did not trip, you have a short either on the P C Board or the transformer.
Mar 31, 2011 | Heating & Cooling
Honeywell MagicStat 3200 Fan continues to run--I flipped furnace breaker off for an hour, set stat to off, & flipped breaker back on. fan still runs. Fan control is on Auto.
Hello,If just installed the thermostat check that the wires are not touching anywhere.If not the case you have a open(tripped) HIGH LIMIT at the furnace and the blower will continue to run untill it is reset.
Oct 30, 2010 | Honeywell Programmable Thermostat Heater
THERMOSTAT HAS NO POWER
Hi, yes the thermostat feed does come off the furnace from the transformer. That's where it gets it 24 volt supply, 120 volts is stepped down to 24 volts for the controls. If it trips the main breaker, it may be a matter of the wires that feed the breaker are loose and this will cause the breaker to over heat and trip. Shut it off and tighten the wires.The breaker may also be weak. This is a high voltage problem. So, anything that runs off of this breaker can cause it to trip, like the blower motor may be drawing to much amperage. Make sure there is no lint build up on the motor or in the windings or on the blower wheel also. My guess would be the breaker is burned or wires are loose creating enough heat to trip it at times. This is where you will need to start. Keep me posted. If you have a amprobe you can check the rated amps on the data plate of all motors and see what they are drawing under a load. If not, you will have to see whats getting hot, breaker, motors ect. Keep me updated as you will be able to find the problem. Like I said, my bet would be the breaker is going. You can also kill power and pull the breaker to look for any hot or burned spots on it. Concentrate there first.
Best of luck, you should find it quickly.
Shastalaker7
May 24, 2010 | Heating & Cooling
Resettable fuse/breaker for TZ-4
The power to your zone panel is from the furnace or air handler. There is a 3 or 5 amp fuse on the circuit board inside the furnace or air handler. I hope this helps. Please don't forget to give me a Fixya rating.
Mar 13, 2009 | Honeywell Heating & Cooling
Put new thermostat on but now furnace still doesnt run
Did you reset the furnace at breaker? If so what did it do? Did it give you a blinking led code? If so what does the code mean on your legend on furnace door?
Dec 05, 2008 | Heating & Cooling
Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Oct 24, 2008 | Honeywell Programmable Thermostat Heater
Bryant 462AJC021BA Air Conditioner Logo
464 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
