Question about Krups XP7230 Compact Super Automatic Espresso Machine
No grinding of the beans nor not making coffe
My xp7200 machines is not grinding the beans so its not making coffee. Everything else is operating. boiler and steaming. Any suggestions!
    Genius:
  • 1,199 Answers
Yes! and I hope it helps you. There is a small metal shaft that you can see when you take off the bean grinding unit alot of times with repeated use the shaft will stick from small coffee dust particals and condensation buildup which forms a sticky substance on the inner shaft! get a small pair of pliers and grip the shaft and Turn clockwise 1 full turn, this may unstick it! unplug unit for five min then try again You may want to oil the shaft with some good high grade oil! if this does not work the grinding motor may be burnt out and needs replaced! also check your settings! please rate
THANK YOU!
Posted on Jan 15, 2009
  • towaho Jul 27, 2011
    I am sure that oil should not be used where it can contact foodstuffs!
  • 17 Answers
I think the electric brushes are worn. You can replace them. See a post on xp7240 how to get to the inner workings.
Posted on Aug 14, 2010
How do i fix my esam 3400 coffee grinder quantity?
I have change grinding from 7 to 1 ( it depends from coffee beans) and quality of coffee get much better (knob located inside the bean container).
Mar 09, 2016 | DeLonghi ESAM Coffee Makers & Espresso...
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
The nachine make all the steps, but only can get
One most posible reason is that the grinding coffee passage is blocked so the coffee is not moving up the the group piston and the machine brues without any coffee in piston and you receive only water.
We sugest to move all coffee beans from grinder by hand and the remaing with the help of vacum cleaner. Try to s.ck also everything that is inside the grinding like grided coffee which probably stuck bettween baldes.
Now udjust teh grinder to 2-3 steps more gross coffee and try the machine again. If it works then you should have coffee but not with good cream at top. So try a coplue of coffe more and if everything is ok then ajust back the position of the grinnder but one step at the time so one step back one coffee.
Goo luck
Mar 25, 2010 | Espressione Caf? Dolce Aroma
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
My meile does not make good coffe
Remove the Brew Unit from the maschine and clean it very well und running water. Thn go into the Main menu and switch back all settings to factory defaults. Then take a vaccum cleaner and put the pipe in the small hole where the coffe falls into the brew unit (knock a bit on the maschin inside). Put out the bean container and do the same with the hole where the beans go into the grinder. Then put everything back in and start a cleaning process for the brew unit (do it 2 times).
After that your Problems must be gone. The Problem is between the grinder and the brew unit. the grinded coffee has bee stuck and is not falling into the brew unit .... that happens when you use beans with lots of oil inside  .... or coated beans .... they "glue" the chute .....
Mr. cool
Jan 01, 2009 | Miele CVA4070 Coffee Maker
Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Coffeee beans won't feed into grinder
Push the coffe brew button again. It should take right off and grind again.
Jul 15, 2007 | Saeco Magic De Luxe Espresso Machine
Krups XP7230 Compact Super Automatic Espresso Machine Logo
709 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
