Question about Refrigerators
Marvel beverage refridgerator is not staying cold anymore
Our refridgerator used to keep the beverages cold, now they are slightly cold
  • 298 Answers
Make sure you have 3-5" of space all around, otherwise it keeps sucking its own hot air and reaches 'equilibrium' and won't get any colder. Ever
Posted on Jan 15, 2009
Can you suggest me the name of any best quality tumbler?
Quality tumbler are the one which will help you to keep your beverages as it is without the effect of temperature. I always prefer to use Yeti tumbler because this tumblers keeps ice 2X longer than plastic tumblers and are designed for maximum ice retention - and work just as well for hot beverages.It had a double-wall vacuum insulation which will keep beverages cold or piping hot longer. This tumbler have a Dimensions: 6 7/8 in high; lip diameter of 3 1/2 in. It is a BPA-free and have No Sweat Design to make sure your hands stay dry.
Sep 02, 2017 | Cars & Trucks
Why is my Beverage-Air refridgerator running all of the time?
Door seals torn, poor air circulation over condenser coils or evaporator coil, defective thermostat, not defrosting or low on Freon.
APPLIANCE 911
Dec 15, 2015 | Beverage-Air MT27 Beverage Cooler...
Gf 24 beverage air not cold
Call a technician. If you are unsure what a relay and start capacitor are there is no way you should be trying to test them. Stay safe!
Jul 02, 2012 | Beverage-Air BEVBM23 Commercial Beverage...
Beverage air dd58 kegerator won't stay cold
The unit is probably low on gas again. If it lasts a month the leak may be difficult to find, as it may be a small leak. Those units don't hold a lot of gas. Have someone do a nitrogen leak check and fix the leak. If no leak is found, have them install a UV dye to help find the leak. :)
Jan 12, 2009 | Beverage-Air DD58 Beverage Cooler
I have Marvel 6bar beverage refrigerator that suddenly stopped cooling- any suggestions on how to fix- I am trying to avoid paying a couple hundred dollars for repair thank you for your time
If light work but not running at all, then change the temp control (thermostat). If compressor and condenser fan motor are running but not cooling, then you have sealed system problem
Dec 01, 2008 | Marvel 6BAR-BD Beverage Cooler
Marvel 6bar-bd gets too cold - explodes soda can
I also have the same problem. Our Marvel 6BAR runs continuously until the beverages freeze. A technician came out and replaced the thermistor under warranty. It was a simple repair that anyone could do. This solved the problem for about another 18 months, but it has returned. I will now search for this part and do the repair myself. It only takes a few minutes to do.
Aug 30, 2008 | Refrigerators
Refrigerator Keeps running
Replacing the thermostat should correct the problem. Be sure to install the thermstat exactly as the one you are removing, assuming it hasn't been changed prior. Hope this helps
Jun 10, 2008 | Beverage-Air Beverage Air KR48-IAS 44.9...
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
