Question about Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System
Chamberlain garage door opener excessive closing force error 41
SOURCE: Hi there. I have a Chamberlain Whisper Drive
I just had that problem this morning and the cause was that the springs that help hold the weight of the garage door were broken. This caused the garage door opener to raise the garage door a fe inches and then drop again. We called in a professional and $200 later we had new springs and everything works fine now.
Posted on Dec 17, 2009
swolfinor
  • 504 Answers
SOURCE: door would not close all the way
DOES IT REVERSE OR STOPS BUT NOT TOUCHING THE FLOOR?
IF IT DOESN'T TOUCH THE FLOOR YOU EITHER NEED TO ADJUST THE DOWN TRAVEL OR LENGTHEN THE CONNECTING ARM.
IF IT REVERSES YOU NEED TO DETERMINE IF IT IS THE SENSITIVITY OR THE SAFETY EYES.
Posted on May 27, 2010
blanchettohd
  • 143 Answers
SOURCE: chamberlain silent 3/4 hp red led on side and hear
This beeping is actually the battery back up unit making this sound. It either means there is no power to the outlet and it is using stand by power or that something is wrong and the battery is not charging correctly or will not take a charge. You can order replacement parts at chamberlain.com. Thanks BB
Posted on Sep 03, 2010
blanchettohd
  • 143 Answers
SOURCE: Adjustment of a Chamberlain WD822KL
The opener is having a hard time operating the door. It sounds like the door is out of balance. The door should stay all the way up at half down and all the way down. You should be able to raise and lower the door by hand EASILY. The opener is only meant to lift10-15 lbs. Thanks BB
Posted on Sep 06, 2010
blanchettohd
  • 143 Answers
SOURCE: Chamberlain hd900d garage door opener
You will have to open the unit and look inside it. Unplug it first. It should have 6-8 screws to take off. You will see 3 white plastic adjustment screws. There is a carriage they sit in. Make sure they are in this carriage. If you would like stay back a bit and plug it in and watch it run to see how it works. It is a direct contact system, so when the middle screw touches the copper limit of the limit screw it stops. Thanks BB
Posted on Oct 11, 2010
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Jun 21, 2014 | Sears Craftsman LiftMaster Chamberlain...
Excessive opening force detected (code 42)
un hook the door from the rail manualy open door to see if it hangs up. if it does fix the door rollers or rail. if not find out what is binding. you may need to adjust the distance it stops
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Nov 21, 2013 | Sears Craftsman LiftMaster Chamberlain...
Forcing door to close. Very springy
It sounds like your door springs are not adjusted properly. Call in a door technician.
Nov 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
MY GARAGE DOOR KEEPS OPENING AND CLOSING. AND ONE OF MY SENSORS IS ORANGE INSTEAD OF GREEN. WHAT IS THE PROBLEM?
As I have mentioned in other post, re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Oct 23, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
The opener seems to want to continue closing the door once it hits the ground. Seems like the closing mechanism needs to be adjusted back closer the the garage door closer unit. This did not just...
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Jun 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My fixed garage door opener opens fine, but only closes if it is held down. My remote garage door openers do not work at all. I replaced the sensors and they appear to work fine. I tried to reprogram the...
If the sensor is working right, that leaves the downward force sensor tripping. First check for track obstrucions by manually moving the door with the lift disengaged. If door works without excessive force, then increase the force sensor of the lift a bit.
Jun 12, 2010 | Sears Craftsman LiftMaster Chamberlain...
My chamberlain model 7200 will close door but not open it
You probably have a problem with your door and not the opener. Try to operate the door manually. It should not take more than 10-15 lbs of force to lift. If it takes more force, you have a spring problem on your door.
Apr 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 hp door opener
replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 16, 2007 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 3/4-HP Whisper Drive Plus Evercharge Standby Garage Access System Logo
7,212 people viewed this question
Top Chamberlain Building Materials Experts
Joseph Hoffmann
liveone15
Are you a Chamberlain Building Material Expert? Answer questions, earn points and help others
