Question about Asko T781 Electric Dryer
Disabled neighbor was given an ASKO T780 dryer, but it doesn't heat up. What could the problem be so I might be able to fix it for him?
    Problem Solver:
  • 9 Answers
Most likely if the dryer does everything except heat up the heating element is bad if you take it apart it will be directly behind the holes inside the dryer
Posted on Jan 15, 2009
ASKO TL751 error messages ?
Asko dryers as model T760 or T780 indicate failure by error message (like "Overflow", "Sensor", "Thermistor", ...) while the model TL751 indicate failure by error code ("H1", "H2", ...)
Below you can see a list of error codes:
H1 error - Humidity sensor error
H2 error - Drying temperature sensor open/short error
H5 error - Heater overheated (ELECTRIC TYPE)
Heater disconnection check and H4/H6 error (ELECTRIC TYPE)
H3 Error - Flame Detector Open Defect (Gas Type)
H7 Error - Gas Valve Defect or Gas Blocked-off (Gas Type)
H8 Error - Igniter Defect or Flame Detector Short (Gas Type)
Mar 31, 2015 | Asko TL751 Electric Dryer
Where is the reset button on my dryer
The only reset on a dryer that I know of is your house breaker.
May 01, 2014 | Asko T780 Dryer
Keeps blowing 15 amp fuses
your dryer element is shorted to the element housing which is the same as ground and this will blow the fuses,remove the elements electrical connections and isolate the connections, and now if the 15amp fuses don't blow then you know the element is the problem
Mar 06, 2011 | Asko T780 Dryer
I was using the "dry" cycle and noticed the dryer stopped after 10 minutes. When I opened the door, very light smoky/steamy stuff was coming out the door and there was a slight burning smell. Now, it...
here are two sites, i would say the vent is clogged and that the thermo switch on the motor tripped but I am not an expert, just cheap charlie:
I prefer the last site, but that's just me. hope this helps Tim
Oct 17, 2010 | Asko T780 Dryer
Drum has a thump every 12 degrees in rotation
replace the belts tensioner pulley for the bearing has locked up
Jun 13, 2010 | Asko T780 Dryer
I have an ASKO T760 Dryer that continually overheats and then shuts down. I have had a service tech out twice - once to clean the vent and element housing and a second time to clean the "thermister" but...
Check the sensor inside the condenser unit "cage". I read that you can clean inside the little cage with a toothpick. I'm having the same trouble, and plan on trying this before I throw in the towel and purchase a new dryer.
Dec 30, 2009 | Asko T780 Dryer
My asko T760 dryer shuts down after a few minutes. It starts again after hitting reset button on back. I read a similar problem was fixed by cleaning the sensor behind the safety cap fixed the problem, but...
Remove bottom panel. The condenser unit is on the left side. Open the section by undoing the clips, and look inside the little "cage". That's the sensor. Remove any lint using a toothpick and you should be good to go!
Nov 28, 2009 | Asko T780 Dryer
My belt is broken and I can't find a replacement
In your town, a appliance repair shop would have it, on line
Aug 08, 2009 | Asko T780 Dryer
if i read everything there is another reset button in the center of the back of this model that needs to be reset.There are also 2 areas lint can build up. front lint trap and somewhere else. Good luck
Apr 11, 2008 | Asko T780 Dryer
Asko T781 Electric Dryer Logo
101 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
