Question about Ovens
My GE 326B1016P001 is beeping and the display says "F7" I press off and the beeping stops. Then the beeping starts up again in a few minutes.
My kenmore 326b1016p001 oven beeps when i try to preheat it
Posted on Mar 19, 2011
  • 23 Answers
Mine does the same thing. It's the keypad circuit board/heat sensor. They aren't happy with moisture coming from the oven. Mine it 12 years old and I'm replacing both.
Posted on Sep 01, 2009
E-mail Charlie Popeck @ He gave me great instructions on how to fix this! It was free and simple(I'm a girl who knows nothing about fixing thing) to fix!!! Thank you Charlie! you saved me lots of $$$$. My husband thanks you too! He could not believe that I was able to fix it!!!
Posted on Oct 21, 2011
GE Oven Model # JRS04B0W3BB is showing an F7 code, how do I fix it? I can stop the beeping noise by pushing the stop button, but the beeping returns after about 30 minutes. I have pulled the breaker for...
F1 Error indicates a bad control board and the control board (electronic control) should be replaced to solve this issue. Hope this helps...please post back for further assistance.
Aug 06, 2011 | GE 24" Built-In Single Electric Wall Oven
Oven beeps and shows F7.
These codes mean that the oven's electronic control has detected a condition it needs to check. When you see a code, follow these steps:
  • Press "Stop/Clear" to clear the display and stop the beeping.
  • Reprogram the oven.
  • If the code still displays, turn off the power to the oven at your breaker box and wait five minutes before turning it back on
Sep 29, 2010 | GE JGRP17 Gas Single Oven
Our JTP15 beeps and displays F7 is there a reset for it?
Yes, you will need to press the stop/cancel button, this will clear the error code and the display.
Nov 14, 2009 | GE JTP15 Electric Single Oven
Hi. My oven displays F7 in red and next to that
HI. This f-7 is indicating that the touch pad is malfunctioning. Follow the procedure below to address further.
Determine if the problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
NOTE( If your unit is equipped with an integrated touch pad, and control board, you will need to replace the entire control board in this case)
Nov 02, 2009 | GE Ovens
326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Jul 30, 2009 | GE JTP20 Electric Single Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
F7 error steady beeping
short inthe key pad, thinks a button is being preesed for an extended period of time youll need to replace the keypad/ electronic control
Nov 17, 2008 | GE JKP45 Electric Double Oven
GE JKP15 Electric Single Oven - Code F7
If possible i will need the letter that come next after the JKP15.
Aug 19, 2008 | GE JKP15 Electric Single Oven
Random beeps, oven almost starts itself
The touch pad may be defective. There is a membrane behind the buttons that will cause problems like that. The only cure is to replace the touch assy.
Sep 11, 2007 | GE Profile JKP18 Electric Single Oven
Ovens Logo
825 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
