Question about AT&T Blackberry Curve 8300 Smartphone
Hand held is locked
My password will not unlock the phone. I believe you should be seeing ***** during the entry- however letters are visible when typing
  • aldadanden Jan 15, 2009
    I have one more attempt before it deletes the data
  • Tim Babcock
    Tim Babcock May 11, 2010
    Has it gone over ten tries yet?
    Genius:
  • 1,487 Answers
Just use your PUK code to unlock blackberry curve 8300 password, type any password until your phone asking you to enter puk code. PUK code can you found from your sim card bundle if you don't have it just call your service provider, they will give it to you. That code will make your blackberry unlocked from your previous password so you can setup new password for your phone.
Posted on Oct 28, 2011
  • 2,794 Answers
Call your cell phone provider to get it reset. It doesn't delete the data from the phone but it will lock it from use until you call your cell phone carrier.
Posted on Jan 15, 2009
Phone is locked and I don't have password to unlock please help
usually if you just locked your phone for the first time it instantly uses the last 4 letters of ya cell phone # for your lock. it works for my lg slide. you can change it after that if you go to your lock settings. it also depends... is it a touch screen or what?
Jan 16, 2013 | Samsung SGH Cell Phones
Tip
DVD drive not found issue in windows 7
In some cases your DVD drive may not be found by Windows 7, even if it's visible in the BIOS and using the standard driver.<br /><br />The standard solution here is to run <span style="font-weight: bold;">REGEDIT</span>, and navigate to <br /><br /><span style="font-weight: bold;">HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\</span>, <br /><br />then delete both UpperFilters and LowerFilters in the right-hand pane (UpperFilters.bak and LowerFilters.bak entries can be ignored).<br /><br />If its not working you can try resetting the drive letter .To do that,<br /><br />Go to <span style="font-weight: bold;">Start</span>, type <span style="font-weight: bold;">Disk Management</span> and choose the <span style="font-weight: bold;">"Create and format hard disk partitions</span>" link. If your optical drive is visible here then right-click it, select Change Drive Letter and Paths, click Change and choose a new letter. If the drive is now visible in Explorer, then repeat the process to change the drive letter back; if it's still not visible, reboot and it should appear.
on Nov 10, 2010 | Computers & Internet
Tip
"DVD Drive Cannot Be Found in windows 7"
Solution: In some cases your DVD drive may not be found by Windows 7, even if it's visible in the BIOS and using the standard driver.
This might cause because of a registry hack aswell.
The standard solution here is to run REGEDIT, browse to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\, then delete both UpperFilters and LowerFilters in the right-hand pane (UpperFilters.bak and LowerFilters.bak entries can be ignored).
No change?
Resetting the drive letter has worked for some.
Click Start, type Disk Management and choose the "Create and format hard disk partitions" link. If your optical drive is visible here then right-click it, select Change Drive Letter and Paths, click Change and choose a new letter. If the drive is now visible in Explorer, then repeat the process to change the drive letter back; if it`s still not visible, reboot and it should appear.
on Jul 13, 2010 | Computers & Internet
I have a 2000 ford mustang. Suddenly my keyless entry remote stopped working. I replaced the battery and turned the off and on 8 times and the locks cycled. after which i pushed the unlock but nothing...
The keyless entry system is controlled by the (GEM) - generic electronic module .
Keyless Entry The electronic door lock system has two main components:
  • generic electronic module (GEM)(14B204)
  • keyless entry remote transmitter (15K601)
  • NOTE: Battery power and ground must be remove before disconnecting the GEM connectors to avoid setting false codes.
    Power Locks Operation The power locks feature allows the customer to lock and unlock the doors via momentary switches located on the driver and passenger door. When the GEM detects a momentary press of the driver or passenger lock button, the GEM will supply power to the driver or passenger lock actuators for approximately 250 ms from relays internal to the GEM. When the GEM detects a momentary press of the driver or passenger unlock button, the GEM will supply power to the driver or passenger unlock actuators for approximately 250 ms from relays internal to the GEM.
    Remote Keyless Entry Door Locks Operation The remote entry feature allows the customer to unlock the driver door, unlock all doors, and lock all doors using a valid remote transmitter as long as the ignition switch is not in RUN or START. The driver door is unlocked whenever the GEM detects a valid remote transmitter unlock transmission. All the doors are unlocked when the GEM detects a second valid remote transmitter unlock transmission within three seconds of the first transmission. All the doors are locked when the GEM detects a valid remote transmitter lock transmission. If the GEM detects a second valid remote transmitter lock transmission within three seconds of the first transmission, the doors will lock again, the horn will sound for 20 ms and the parking lamps will flash for 200 ms to indicate the doors are locked. If the GEM detects the driver or passenger door is ajar during the second lock transmission, the doors are locked again and the horn is sounded twice. If the GEM detects a valid remote transmitter lock transmission within three seconds of detecting a valid remote transmitter unlock transmission, the GEM will lock all the doors
    • The doors do not lock/unlock using the remote transmitter
    • Ignition switch.
    • GEM.
    • Remote transmitter.
    • Remote transmitter batteries.
    • GO to Pinpoint Test C .
    You followed the program instructions to the letter ? Programming -Keyless Entry Remote Transmitter NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
    NOTE: All previous transmitter identification codes (TIC's) will be erased when programming mode is entered.
    NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM)(14B204), perform the following steps.
    1. Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered program mode, it will lock and unlock all the doors.
    1. NOTE: The first TIC must be entered within 7.5 seconds of entering the program mode and additional TICs must be entered within 7.5 seconds of the first TIC. The programming mode is exited whenever the timing constraints are not met.
      Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
    1. If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
    1. Turn the ignition switch to the OFF position, or wait up to five minutes after step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
    1. Take an have the vehicle checked for DTC'S
B1396 Power Door Lock Circuit Short to Battery GEM GO to Pinpoint Test B . B1397 Power Door Unlock Circuit Short to Battery GEM
Apr 12, 2017 | Ford Mustang Cars & Trucks
What is my subsidy password?
The term Subsidy Password is used by Motorola and other handset manufacturers to refer to the 8-digit (or 16-digit code for newer phones such as the Motorola K1) unlock code necessary to remove the operator lock (also known as subsidy lock) from cell phones. You specified your phone is LG,LG Phone ask for Unlock code,but subsidy password request from a Motorola Phone,Ok you can get the Motorola Subsidy Password at Onlinegsmunlock and Unlock the Phone,You need to specify the network it locked now and Country,mobile Phone model....
Jul 12, 2011 | LG Cell Phones
1996 chevy corvette passive keyless entry light stuck on
This is an indication the passive reciever has been set to off. Press and hold the door button on the hand held passive remote for 2 seconds the door locks should cycle locked then unlocked. The passive indicator should go out and the system should see the remote when you walk away from the car (dors lock, horn blows). If nothing happens test the hatch button (if you ha a coupe) to see that the remote battery is good.
Mar 21, 2010 | 1996 Chevrolet Corvette
Some keys giving double letters cant enter password for windows
Good morning! possible that some of the keys (/letters) terminal point of your keyboard were locked/stucked-up during your cleaning. I suggest to use another keyboard then check the status of the keyboard if it is working properly thru Device Manager. best regards
May 08, 2009 | Computers & Internet
My remote for the keyless entry does not work.
does trunk button work? panic button?
here's 2003 info:
  • Driver door module (DDM).
  • Go To Pinpoint Test G .
SECTION 501-14: Handles, Locks, Latches and Entry Systems 2003 Town Car Workshop Manual
GENERAL PROCEDURES Remote Transmitter Programming
  1. Cycle the ignition from OFF to RUN four times within three seconds. The locks will then lock and unlock, confirming that the program mode has been entered.
  1. NOTE: When the first keyless entry remote transmitter is programmed, all other keyless entry remote transmitters are erased.
    Press any button on the transmitter to be programmed.
  1. If additional keyless entry remote transmitters are to be programmed, repeat Step 2 within 7.5 seconds.
  1. To exit program mode, turn the ignition to START or wait 7.5 seconds.
report back
Mar 22, 2009 | 2004 Lincoln LS
SIM UNLOCK CODE
*2767*688# not working with my E900 ,
Error = Incorrect entry
may be it worked on ur cell not mine ... anything updated about rest your SIM lock ? :(
E900
Nov 28, 2007 | Samsung SGH-E900 Cellular Phone
AT&T Blackberry Curve 8300 Smartphone Logo
97 people viewed this question
Top AT&T Computers & Internet Experts
Computer Repairing
Computer Repairing
Prashant M
Prashant M
Are you an AT&T Computer and Internet Expert? Answer questions, earn points and help others
