Question about Philips Magnavox DVD/VCR Dual Player
Connecting dtv box to vcr to dvd to the tv
I have connected the converter box to the tv- cables go direct from rear of converter to rear of tv. The areal is in the in and the out goes to the rear of the tv using the red white & yellow cables.Tv is running with new box and all channels are working.
I now need to add 2 more items.
- An "old" type vcr player push in the video and play-just has antena connection to the tv.
- A plain simple dvd player with rear connections yellow red & whits, connection for coax..
How to connect all of these to the rear of the tv.?
Looks like i need a divider out of the tv to connect all of the red white & yellow as well as the coax?
  • Anonymous Jan 26, 2009
    I am trying to connect the vcr to the dvd with the convertor box--how do i do this
    Genius:
  • 1,199 Answers
You can hook the cable box into the vcr and then out of the vcr into the spliter which will turn your tv red/white/yellow signel input into two inputs( you can get this at most radio shacks for about $7.00 dollors) this leaves you with one more input for the dvd player
Please rate my response and come back if you need more help!
THANK YOU!
Posted on Jan 15, 2009
How record tv chanels using the DTV converter box? The converter box determines the chanel of interes while the DVD recorder must remain on chanel 3 in my area. My DVD recorder is a combo with a VCR...
Can you connect directly from the DTV converter to the DVD recorder input using RCA phono connector cables? You'll have to select the input on the recorder menu as well.
Oct 21, 2009 | GoVideo Go Video DVD/VCR Combo
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
I have 2 DTV converter boxes - one for TV and one for VCR. The wiring is exactly as prescribed by manuals and FCC. VCR does NOT record programs from TV - altho it plays back pre-recorded tapes OK. I have...
Use only one box.
Connection should be:::Video Source(cable, antenne) connected to converter box:::::Converter box connected to VCR:::VCR connected to TV.
Try this connection and let me know how it goes.
Please rate this solution.
Lone99star
Mar 10, 2009 | Sony Televison & Video
Trouble w/ sanyo VCR after connecting DTV converter to TV
My garage door a craftsman 1/2hp 1999 Model. Opens without us opening it.we Donot have the Manual is there anywy we cn get it.
thanks
Patrick
Jan 18, 2009 | Philips Magnavox DVD/VCR Dual Player
I want to hook a system
you will only be able to get digital surround( dolby digital ) from your dvd player( by the coax or optical digital connections ) , the rest will only be in virtual surround
from the dtv box plug the yellow video jack(RCA) into the vcr video input , then plug the audio jack or jacks into the audio input on the vcr. from the vcr hook the audio out to the audio in on the reciever( tv/vcr/sat... input ) , then also connect RF out from the VCR to RF in on the TV .
for the dvd player hook the "s-video out" to the "s-video in" on the tv , then the audio L and R on same s-video input , then send the audio out connection on tv to L and R input on reciever dvd L and R input , then you will need to connect the optical from the dvd player to the reciever or coax connections for the dolby digital on the reciever to work
Jan 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Trying to make DVR work after 2-17-09
I have been able to record down converted HDTV shows on my Panasonic DMR-EH50 recorder directly to the unit's hard drive and/or directly to a blank DVD-R disc.
I do not know of any DTV converter box that can provide the proper codes to the Panasonic DMR-EH50 to allow recording and scheduling of shows using the unit's built in TV Guide menuing functions (the program recording codes are essentially VCR Plus codes in the USA and VCR Video codes in the UK, and this technology was previously owned by TV Guide/Gemstar but was purchased by Macrovision within the past couple of years.)
When the DMR-EH50 is hooked up to standard RG-59/U coaxial TV cable, the cable company provides the specific VCR Plus recording codes, as well as auto setting the time and date information required for the TV Guide recording schedule menus. The VCR Plus recording codes are sent via the cable company through the coaxial cable to the end consumer's recording device. Since Gemstar's VCR-Plus patents are now owned by Macrovision, I am not sure of how this works (or will work) for non-cable/non-satellite customers or if such codes will be made available by Macrovision to record shows when one receives HDTV signals (or down converted DTV signals) from an over-the-air antenna.
Though the DMR-EH50 recorder can only record at Standard Definition (SD) broadcast resolutions, I connect the DMR-EH50 to my High Definition TV using the three progressive scan YPBPR output cables and switch my HD-TV into the YPBPR mode when I want to watch shows from the DMR-EH50.
YPBPR are the analog video signals carried by three color coded component video cables. The green cable carries the Y signal; the blue cable carries the PB signal; and the red cable carries the PR signal. The added benefit of using the YPBPR hookup is that you can 'up convert' a standard DVD disc (non HD Blu-Ray disc) in progressive scan mode to somethin akin to 720p resolution using the DM-EH50 (or any other progressive scan DVD player) to get a better quality image on your HD-TV.
Visually speaking, the same appears to hold true for playback of programs recorded on the DMR-EH50's hard drive even though down converted via the DTV converter box, and when played back on an HD-TV using the YPBPR progressive scan cabling hookup.
I also been able to successfully record programs from the DTV converter box to the DMR-EH50 recorder in both 16:9 wide screen and 4:3 normal aspect ratios, but again only in Standard Definition quality.
For NTSC and PAL formats, the correct aspect ratios for any particular TV (the rectangular height and width of your output resolution for a TV screen) can usually be setup correctly for most any DTV converter box by going carefully through the menus on the converter box. Though the converted DTV often will yield 'better looking TV' than cable, it's certainly not high definition however, as the purpose of any DTV converter box is * not * to yield a High Definition digital TV signal but a lower quality Standard Definition signal for viewing on older SD-TVs.
We must remember that what is happening here is that (by NTSC USA standards), we are transcoding (i.e., down converting) an over the air 1920 x 1080p (progressive scan) High Definition digital broadcast signal, captured by your over the air antenna, back to a Standard Definition 720 x 480 resolution analog broadcast signal (the 720 x 480 resolution is a 4:3 aspect ratio.)
Hope this helps a little -
Greg Loveria
Conklin, NY USA
Jan 03, 2009 | Panasonic DMR-EH50 DVD Recorder
DTV Converter hookup
Is it possible to record TV programming on a VCR when using a DTV converter? h1 = document.getElementById("title").getElementsByTagName("h1")[0];h1.innerHTML = widont(h1.innerHTML); Hi,
I had the same problem and found this answer that worked for me. Hope this does the trick for you.
Simple stated, your VCR must be set to channel 3 also. Check it out.
woody
  1. You must have the VCR tuned to record on channel 3.
  2. You must have the VCR connected to output signal of the DTV converter box. In other words, the converter box must be connected between the antenna and the VCR. So, the likely configuration you would use with a coaxial cable is antenna to DTV converter to VCR to TV.
  3. You must tune the DTV converter to the channel you want to record prior to recording. The VCR won't be able to change channels on the DTV converter.
  4. You will be able to use the timed record function on the VCR but you must adhere to steps 1-3.
If this sounds freakishly familiar to recording on a digital cable or satellite set-top box, you are right. It is exactly like recording a signal from a digital cable box or satellite receiver. While it may be inconvenient to perform the steps above, at least the option still exists to record on a VCR while using a DTV converter box.
Disadvantage of DTV Converter: You will lose the ability to watch one program and record another with the DTV converter. Sorry for the bad news.
The reason is the tuner. The VCR tuner is useless with digital except for recognizing channel 3. The digital converter is a single tuner item so it only receives one station at a time.
Oct 17, 2008 | Emerson EWV603 VHS VCR
Converter box
The cable that goes into the TV sould come from the VCR output to TV plug.
The antenna input to the VCR should come from the antenna or DTV converter box.
The signal passes through or loops through the VCR.
If you hve a manual the connections are on pages 14 an 15.
Let me know if there are any problems and a time you might be hooking this up.
You can download a manual here:
http://www.funai-corp.com/6pdf/om/MWR20V6.pdf
Oct 03, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
May 13, 2008 | Televison & Video
Philips Magnavox DVD/VCR Dual Player Logo
156 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
