Question about HP OfficeJet 6310 All-in-One Printer (Printer/Scanner/Copier/Fax) w/USB Printer Cable , Retail
Can I print via my wireless network with HP OfficeJet 6310xi?
We have 2 laptop PC's (OS: Windows XP) connected to our home wireless network (Router: DLink DIR-655). Our HP OfficeJet 6310xi is connected via wire to Computer A. Computer B routinely prints off of the 6310xi through the wireless network. However, I've not found a way to scan a document from the 6310xi to Computer B (that is, through the wireless network). Can it be done...and, if so, how? Thank you.
  • JDTec
    JDTec May 11, 2010
    Since your printer does not have wireless capabilities, it will not allow you to scan wirelessly. And even is you purchase a print server, it will not work.I dealt with this situation till I finally gave up due to fustration.
    Best bet is to purchase a wireless printer.
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Posted on Feb 20, 2009
  • 3 Answers
You may need to open a port on your main computer and from their you need to go into the control
panel wireless net work you also need a memory stick once you have opened the wireless net work
follow the instruction their will be a box make sure you put router name in the box
I HOPE THIS HELP
SHORTY
Posted on Jan 15, 2009
What do I need to make my printer wireless?
You need 1) a wireless router with a USB port that supports the HP OfficeJet printer. 2) The software for your router to run a printer on the USB port. Obviously, you will need a USB A/B male end cable.Note: the scan features of the all-in-one may not work unless the printer is directly connected to the computer. Bi-directional communication is required for scanning and the router software may not support this completely.
Check the list of supported printers closely for older routers. I have a Cisco Linksys E4200 v.2. This router supports all the HP printers that I use.
If this is a new installation of the printer, first install the printer on the computer. If you have Windows 7, just connect the printer to the USB port on the laptop. This will install the OS drivers for the printer. (For Windows XP, go to the HP site and get the full software.)
Next install the wireless router between your modem and computer and set that up. (If you have DHCP (dynamic address allocation), it should be automatic. Otherwise follow the directions.) Next install the router software (for my router, it was Cisco Connect).
My next step was to launch the Cisco Connect program and connect the printer directly to the USB port on the router. In Cisco Connect, choose add a printer and find the printer connected to the router. Print a test page. (At times, I've had to reset the port that the printer is on in the Windows Control Panel Printer Properties. (For the Cisco Connect, the printer is on the DOT4 port.)
Other routers will be set up somewhat differently.
Another option is to have the printer connected to a desktop and then make it a shared printer with the wireless router communicating between the laptop and the desktop. This makes the desktop the print server, so it needs to be on when you want to print. If you have several computers with Windows, this can fairly easy to set up. Make sure that the computers are in the same Workgroup (XP) or Homegroup (Win7). Enable sharing and you are done.
I hope this helps.
(who has a OJ 7000 (with ethernet port) and a LJ1320 (USB) connected to the router. Three computers talk to these printers with the laptop on the wireless network. On an older router that didn't support the printers, the laptop was the server for a previous OfficeJet and one of the desktops was the server for the LaserJet.)
Aug 27, 2012 | HP OfficeJet 6110 All-In-One InkJet...
I have HP Officejet 6500 connected via USB to office desktop. I also need print from vista laptops on the same wireless network as the desktop. How do you do it ?
Hi, I just completed this same query this week.
to set up my remote network i followed promts from windows and then had to run my windows xp startup disc on my vista laptop.
After that was complete i had to install the hp printer setup cd onto my vista laptop and connect the hp printer to my router using the ethernet cable. I followed the prompts on the vista as the cd continued to install. then at the end of it all it showed i had correctly installed the printer via wireless and asked me to do a practice print which i did and all seems fine.
I can now print from my vista laptop and my windows xp desktop. I hope this helps
Jun 12, 2011 | HP Officejet 6500 AllInOne InkJet Printer
Print from nokia E63 through WIFI
Try connecting your printer directly to the wifi router/switch in a shared network configuration. Then go to your router settings, find the local ip address add this as the 'host'. Your settings should be as follows:
Driver : HP Mobile Printing
Bearer: Socket/HP Jetdirect
Access Piont: My Home Wifi (kaba)
Host : ip address of you printer
user : Blank ( tried my windows username,no use)
port : 9100
Printer Model: Officejet Printers
You will have to reconfigure your drivers on your pc as well. Mine installed as a wireless shared printer even though the printer is not wireless but I have it connected to my wifi switch for sharing and it worked fine.
Good luck
Damien_1977
Jan 07, 2010 | Polaroid PoGo Digital Photo Printer
Can't get the printer to print while connected to a router
Hi! I will be glad to assist you in this issue. This is the link that will help you to fix the issue:
1. Installing the Product Software in Windows XP and Vista for a Wireless Network Connection (Using an Access Point)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01736948&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
2. Installing the Product Software in Windows XP for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01708573&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
3. Installing the Product Software in Windows Vista for a Wired (Ethernet) Network Connection
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01710137&tmp_task=setupCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
4. Wireless & Network Issues Link:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=33412&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512010
Oct 25, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Computers not sensing scanner via LAN
Scanning over network usually requires software to connect. First go to the drivers page as below. Windows Vista | Windows XP, download the latest drivers (the Full Feature one) as well as the firmware update for the OfficeJet. Plus the "Update" files that's dated newer than the Drivers.
Upgrade the firmware (this will reset all custom settings in the OfficeJet like IP address) with a USB connection.
Run the full feature installer and if there is an option for Networked OfficeJet, then tick it. Also you may need to change/disable firewall for the installer to pick up the networked OfficeJet.
Scanning over the network usually connects with a customized TCP port. And most likely the Windows "Scanners and Cameras" will not pick up network scanners unless it's been defined manually (installer can do this part).
Jun 15, 2009 | HP Officejet Pro L7650 Printer
Laptop Cannot Find Home Wireless Network
Try logging into the router with your desktop hard-wired and find the 25-digit passcode and use that to log on to the wireless network with the laptop. If not, then check if connection is good by hard-wiring the router to the laptop. Let me know what happens or if you have solved the problem.
Mar 22, 2009 | HP Pavilion a1320n (882780261747) PC...
My HP Officejet Pro L7580 prints one page and then stops
TRY WITH WHETHER THE PRINTER CONNECTED PROPERLY AND UPDATE IS NOT PROPER
Nov 18, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Can connect with usb stick on one PC and through inbuilt wireless on a laptop to the main router but not a new one
becos of you using three different os one is xp,other one is vista and other on is xpsp3 all the driver is different so how can he connect it.
Sep 06, 2008 | NetGear WG111 802.11g/b Wireless Adapter
Open Questions:
See all HP OfficeJet 6310 All-in-One Printer Questions
747 people viewed this question
Ben Johnson
