Question about Dishwashers
Does anyone know where to locate the dranage pipe?
    Champion:
  • 244 Answers
Follow hose back from sink drain or disposal to pump,
Posted on Jan 15, 2009
Is M280 radio defective, causing battery to drain?
Just remove fuse to radio to see if this circuit is the problem. You can pull fuses one at a time and use voltmeter to see which are drawing current. Could be bad diodes in alternator which can be tested at parts store.
Jun 09, 2015 | 2006 Hyundai Tucson
My whirlpool washing m/c 1400rpm awo/r 5406 will not complete the wash cycle it washes until it gets to spln and drain then the service light comes on (spanner)washer stops working but water still flo
locate the dranage water pump, screw it ou nd clean or check on the filter cuup,,always situated next to the water pump below,,u can trace the pump along with the outlet
drainage tube
Jan 26, 2015 | Whirlpool Washing Machines
Whirlpool ADP 4300, drainage problems. 4 flashes indicating that water is not draining. I have made sure there is no blockage and cleaned all the filters, even reset the program. What should I do next
Hi some times you will find that there is dirt in the pump itself that pumps water out there should be a screw cap on the front of the pump ,open that and clean it out ,After this take the outlet pipe and
lower it into a bucket and try again . this is just to see if there is more dirt coming out ,if so clean it again .
Then while it is pumping out lift the pipe to the same hight as the dranage outlet to see if its still pumping at that hight .hope this helps
Jan 18, 2013 | Dishwashers
Washed a load of floor rugs now washer will not drain
sorry but one rug is ample for any machine,but the load weight alone is far to much on the machine,i have been in a testing factory and seen the things people put in machines and it would shock you,but back to your presant problem?basicly the whole dranage system is full of heavy dirt and needs cleaned badly.Try putting two dishwasher tablets through machine and see what happens but i must say i wouldnt have high hopes,i would think lower dranage pipes are going to be cleaned.if you want my help come back to me.adrian,,,,,,,
Aug 21, 2010 | GE Profile WPRE6100G Top Load Washer
Oxygen Sensor
http://www.autozone.com/autozone/catalog/parts/partsShelf.jsp?displayName=Oxygen+Sensor&currentPage=1&categoryDisplayName=Exhaust&navValue=16100117&itemId=117-0&parentId=61-0
This link will take you to a site that will show you what the sensor looks like and it's cost.Your sensor is located in the exhaust pipe by the catalytic converter.This is under the car,screwed directly into the pipe just behind the converter.Hope this helps?
Dec 30, 2009 | 1998 Volkswagen Beetle
Can't find O2 Sensor, before converter on 3.1 Ltr Pontiac G AM GT
start on engine to exhaust pipe and you will find it, could be at exhaust in back of engine.
Sep 26, 2009 | 1995 Pontiac Grand Am
Maf sensor
the maf is located on a black plastic pipe 50mmdia beside the air filter (the air filter is located in a black plastic box 300mmx150mm approx)the maf is held in with two screws
May 04, 2009 | Volvo S40 Cars & Trucks
Help! I just recently purchased a '93 Honda Prelude and as I was driving it home from work today a pipe fell down on my feet! It's a plastic moulded black pipe that has the code 77421-SSO-0000 on it, I...
hi there i am willing to bet that the pipe is for the defroster or the air vent on the drivers side. you have to look up under the dash and try and see if you can locate the air vents this can be a pain in the you know were. all you got to do to locate were it came from is turn on your heat or ac and feel under the dash and you will feel the air flow and then you know atleast were the end goes now the hard part might be getting this back up there and on
hope this helps
Please leave me a rating
Thank you
Apr 21, 2009 | 1993 Honda Prelude
Parts needed
contact Shriro located in NSW
Dec 15, 2008 | Gaggia Classic Espresso Machine
Dishwashers Logo
44 people viewed this question
Top Dishwashers Experts
