Question about Cooler Master (RS-380PMSR/P) (RS380PMSRP) 380-Watt Power Supply
My computer wont turn on
I'm using the coolermaster model [RS-380-PMSR / RS-380-PMSP] 380W. my computer wont turn on after the first attempt to power it up, but after some succesive pushing of the power button and leaving it for about 10 minutes before pushing the power button again it starts working
  • Tim Babcock
    Tim Babcock May 11, 2010
    Do you see any diagnostic lights on your motherboard after plugging in the power supply?
    If so are they green?
  • 21 Answers
Sound like 'classic' failing capacitor symptoms to me... RMA the power supply if you're able to, start scraping together some cash for either a rebuild (replace capacitors) if you can't OR purchase a NEW PSU
Once you get the system running... I would recommend you leave it turned on 24/7 as this will keep the failing capacitors at a static temperature (instead of the heating/cooling cycle) thus milking the last bit off life out of it while you secure a replacement unit.
Posted on Jan 26, 2009
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
CAC-T05-UW .what are the brand ,model and features of the power supply compatible with it
This type of power supply is best one:
The eXtreme Power Plus RS-460-PMSP-A3 from Cooler Master pushes out 460W of power to handle your system's thirst for juice. It is compliant with the newest Intel ATX 12V v2.3 specifications so it is a great choice for both replacements and new builds.
There are plenty of connectors for all your system add-ons including 5 Molex and 3 SATA. There is also a PCIe connector for your advanced video card. The +12V output duties are divided between two 18A rails for plenty of balanced power.
hope it helps, if so do rate
Dec 01, 2010 | Cooler Master CAC-T05-UW ATX Mid-Tower...
Why did my coolermaster 550w stop working?
Because last tuesday was after the 25th day in the month meaning all electrical items fail intermittantly, and so the 4th 50A capacitor blew (to the left of the inverted power coil)
All joking aside, it could be any number of reasons why it stopped working, but the definitive test is to use a power supply tester (available cheaply on ebay or for £9.99 in Maplins)
Nov 01, 2010 | Cooler Master Real Power 550W SLI...
Will the Nvidia 9800GT work with this the PSU CoolerMaster RS-500-PCAR-A3?
Yes, that power supply is sufficient to run the Zotac geforce 9800GT the power supply has a 6pin connector and should supply sufficient power to the card.
Aug 16, 2010 | Nvidia Zotac GeForce 9800GT Amp Edition...
How to check if my power supply is already not ''at the limit''?
1 or 2 extra hdds and ram does not require much extra power and your coolmaster should do the job. But if you intend to use a newer graphic card you should check the requirenments for wattage at your new card manufacturer product specification webpage. I am pretty sure that almost all newer graphic cards require at least 500 watt to run without problem. My advise is to buy at least a 550 watt psu although i don't know what is your hardware. Try to post your hardware specs and calculate for each component (cpu wattage+graphics wattage +etc) your power supply need to be over 50 wattage. Hope that helped!
Mar 22, 2010 | Cooler Master (RS-430-PMSR/P) (RS430PMSRP)...
Cooler makes noise,when it rotates.please help.
Stop beating up the tower before you damage the harddisk! If the case/PSU is out of warranty, take the PSU out and get the fan replaced. You can do it yourself, just observe the arrow direction on the fan (usually the round label should point out) and wire colors (the fan should blow out). Observe also all the precautions since the capacitors inside can hold a significant charge.
Nov 10, 2009 | Cooler Master Extreme 430 RS-430-PMSR...
Amp and sub connection
Too many problems, lol. One at a time. I lost you in your post, run by me again but one amp at a time.
Jan 08, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Cooler Master (RS-380PMSR/P) (RS380PMSRP) 380-Watt Power Supply Logo
218 people viewed this question
Top Cooler Master Computers & Internet Experts
Computer Links
Avishek Samaddar
Avishek Samaddar
Chris Larocque
Are you a Cooler Master Computer and Internet Expert? Answer questions, earn points and help others
