Question about Dell 2300MP Multimedia Projector
No image appears on statup also all buttons are flashing. Checked lamp which is OK Anu idea as why or what is causing this to happen?
How do you know the lamp is OK if no image appears? If it is in fact okay, be sure that the cables are properly attached (s-video in s-video, composite video in composite video) Lastly be sure the focus ring has not come loose and is distorting an image to nothingness.
Posted on Jun 15, 2007
SOURCE:
I have a Dell 2300MP DLP projector. It lights up for about a minute then the light goes out. Both the Temp and Lamp indicators are glowing after the light goes out. The fan is working. Will just replacing...
Looks like there is power supply problem as well as the lamp.
1 Clean all filters
2 Check out power supply (usually a few capasitors need to be replaced)
3 Wuld be a good idea to check the lamp in wokring projector, but if the "Lamp" light is constantly on it is more likely a faulty lamp as well.
Mar 01, 2011 | Dell 2300MP Multimedia Projector
Dell 2300mp
Replacing the lamp module requires special considerations:
  1. Turn off the projector.
  2. Wait 30 minutes for the projector to cool down and then unplug it.
  3. On the bottom of the projector, loosen the two screws on the lamp cover and then remove the cover.
  4. Loosen the two screws on the lamp module and pull out the module.
  5. Insert the new lamp module and tighten the two screws.
  6. Install the cover and tighten the two screws.
  7. Turn on the projector. If the lamp does not turn on after the warm-up period, try reinstalling the lamp again.
  8. Press enter on the projector or on the remote control to open the on-screen menu.
  9. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Setup and then press the right (c00589412.gif ) arrow.
  10. Press the up (c00589410.gif ) or down (c00589411.gif ) arrow to select Reset lamp hours and then press enter .
Jun 18, 2008 | Dell 2300MP Multimedia Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Dell 2300mp projector, colors bad
try reseating the vga cable. Try removing the cable, the green tint should disappear meaning that the color or lack of one of the primary colors blue/red/green were missing due to bad connection. or maybe you have a bad vga cable.
Feb 26, 2009 | Dell 2300MP Multimedia Projector
High definition
When i press the power button red lamp indicator on
Feb 10, 2009 | Dell 2300MP Multimedia Projector
Dell 2400 MP projector lamp problem
could be a heat, fan - sensor issue or a power supply issue. Regards Kevin Andreassend http://www.iceav.co.nz iceavtech@gmail.com
Feb 03, 2009 | Dell 2300MP Multimedia Projector
Dell 2300MP Projector Lamp - "Orange Light"
I've heard it could be the ballast, check with Dell for replacements
-- Deft
Aug 21, 2008 | Dell 3200MP Multimedia Projector
check this out...
http://www.ihatedell.net/forum/phpBB2/viewtopic,p,36316.html
have almost the same problem. lamp light turned on-->replaced the bulb, now when you turn it on tryies to boot and then the lamp light is on again (but the bulb is brand new).... and no light at all coming out of thing... I guess dell just don't know how to built projectors right way.... and theirs tech support guys are.... they just don't know about projectors more then manual
Jun 20, 2008 | Dell 2300MP Multimedia Projector
Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Dan
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Dell 2300MP
resync button,i think,but seems too easy...
Apr 30, 2008 | Dell 2300MP Multimedia Projector
Dell 2300MP Multimedia Projector Logo
139 people viewed this question
Top Dell Office Equipment & Supplies Experts
David Patricia James
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
