Question about D-Link DSL-G604T Wireless Router
Virtual server keeps resetting
Can open a port for something easy enough by 'adding rule' in the virtual server part of the router; however whenever the computer is switched off, the rule becomes no longer applied, requiring me to go back into the router and reapply it. Additionally, whenever the router is reset/switched off the rule dissappears completely and must be remade.
Any ideas? The model is a DSL-G604Tv2
U should overwrite or refresh by firmware v2 ,<tool> <system>and find firmwareV2.00B01T01.TH.20060809
Posted on Mar 30, 2009
Connect two tigerswitch 6724AL2 via fiber port
How do I open ports in the Virtual Server? pix.gif pix.gif pix.gif You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows.
  1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter.
  2. Click on Login, Advanced Setup, NAT, Virtual Server.
  3. Enter the port details and enable it as follows:
Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx To access the application, you can open up the ports specific to the application in the special application, which is present in the router management screen as follows:
  2. Click on Login, Advanced Setup, NAT, Special Application.
Trigger Port Trigger Type Public Port Public Type Enabled 3724 TCP 3724 TCP Y 6112 TCP 6112 TCP Y 6881 TCP 6881-6999 TCP Y
* The port numbers given are just an example. You need to open the ports depending on the application you are using and should get the information from the application provider.
Jan 05, 2011 | SMC TigerSwitch SMC8612T
How do i change my NAT to open on my tenda W307R
Im only a couple years late, but i spent an hour on my computer last night to figure it out. Enter your ip adress in the top bar thingy. Enter your username and password. You should now see something with the selections "System Status, Setup Wizard,etc" on the side. Click on Virtual Server. Under Virtual server, you should see something called "DMZ Settings". In there, enter the ip adress of the computer/console you want to open the NAT. Click enable, the hit apply. Your Done.
Nov 26, 2010 | Port Designs Tenda W307R-103421 Router
Had a different router everything was working fine, until i replaced my router to a dlink dsl 2640u , wireless router. i can open all sites but sites beginning with https cant be opened. it says web page...
I suspect that you have port forwarding rule (virtual server) on port 443 (https) on your router. Try to remove rule or just reset router to factory settings. I have the same router and this problem did not happen. You can also install Router Commander program to boost up router performance.
Aug 29, 2010 | D-Link 802.11g Wireless Router WBR-1310...
Have a linksys router tring to get adlink print
Did the dlink print server come with an installation disk? If so, you probably need to run that. It will help you set up a virtual printer port that you can then choose when adding a printer. For seting up two printers, you'll have 2 different virtual printer ports. For example SCB77031_P1 and SCB77031_P2.
If you need more help, please let me know what model linksys router and dlink print server
Aug 23, 2009 | Linksys Computers & Internet
Error "virtual server add error" failed. stats: 1
I had this error. There was an old rule for an old device that was no loonger connected. If a device that has a rule is not connected, no information will show up telling you there is a rule. But it already exists and is hidden. The rule will only show up when the device is connected. But the rule is active wether or not the device is connected.
The only .I found to fix this is to reset the router to defualt settings, this will remove the old device and it's tules from memotry.
Jun 05, 2009 | Actiontec GT704WG Wireless Router...
You need to forward the ports used by the application to the server running the application in the Virtual Server, which is present in the router's management screen, as follows. 1. Open your web browser, type in the router's IP address (standard: 'http://192.168.2.1') and press enter. 2. Click on Login, Advanced Setup, NAT, Virtual Server. 3. Enter the port details and enable it as follows: Private IP Private Port Type Public Port 192.168.2.x xxx TCP xxx 192.168.2.x xxx UDP xxx
Feb 19, 2006 | SMC Barricade 7004
Feb 19, 2006 | SMC Barricade 7004 Router
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Nortel Contivity VPN client?
Nortel Contivity will work with the your D-Link router, however its functionality depends on the authentication type (AH will not work), NAT compatibilty mode, and disabling keep alives on the server. Contact your Network Administrator to find out how your VPN is configured. Step 1 Verify that you are using the latest version of firmware on your router. Step 2 Login to the Web Management for your router by entering its IP address (192.168.0.1) in your web browser. The default username is admin, and the password is blank. Step 3 Click the Advanced Tab to access the Virtual Server Settings. There is a list of pre-defined Virtual Server Rules towards the bottom of the page. Find the IPSec Rule. Click the pen and paper icon to edit its settings. Enable the rule, enter the IP address of the computer attempting to connect to the VPN in the Private IP field, then Apply the changes. Step 4 Create a new Virtual Server entry. Name the Virtual Server, "NortelVPN". Enter the IP address of the computer attempting to connect to the VPN in the Private IP field. For the Protocol Type, select Both. Enter 9550 for both the Public and Private Ports. Set the Schedule to always, then Apply the settings. Step 5 Access the Tools Page, then click the Misc button. Disable IPSec Pass-through, then click Apply. If the VPN Server is properly configured to work with clients behind NAT routers you should be able to connect to the VPN.
D-Link DSL-G604T Wireless Router Logo
377 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
