Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
About every other day the freezer though now set to coldest stops freezing, ice melts in storage bin, water leeks down through to the inside of the door where the back of the door water/ice dispenser is located and a huge "ice flow" on the back of the door forms where the water from the melting ice is hitting the cold interior of the door behind the water/ice dispenser on the front of the door...  Is there a freezing or cooling  unit in the door water dispenser? It seems like the only cold generated in the freezer is the inside of the door.  What is going on here?  Thanks alot for any thoughts!
    Problem Solver:
  • 18 Answers
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Posted on Jan 22, 2009
Amana #srd2555w bought from a friend in working condition. 3 yrs old brought home on its side. vacumed coils working 3 days then stopped cooling in fridge followed by ice build up and not working in...
You have a defrost problem. 3 parts: Timer (or "adaptive defrost control"), defrost heater and def. termination thermostat.Find the timer, it shoud be nehind the bottom front grille to the right on Amana (if you see a blck box under there with a sticker on it, it's the ADC model) turn the timer CW until it clicks. Take the back off the bottom of the freezer and listen. After 5-10 minutes if you hear the sound of the sound of water hitting a hot grill. If you hear this the heater and thermo are working and the problem is the timer/ADC. No hiss? Unplug fridge. Check thermo and heater for continuity. Replace the one that's open. If the heater's open, replace the thermo too: Maybe it didn't open soon emouhg and caused heater failure.
Sep 25, 2009 | Amana SXD524VW Side by Side Refrigerator
Hi, My Amana Refirg is about 30 years old-refrig on bottom freezer w/ice maker on top. The ice maker was skipping and would not stop by raising the arm. Consequently is ceased, now however the freezer is...
do you see alot of frost on the rear panel of the frzer if so it has failed to defrost and repair is req or do a manual defrost until a tech can get to you if no frost sorry sounds like you have a weak tired compressor or leak of freon and being 30 yrs old it is not cost effective to repair this item....
Aug 19, 2009 | Amana Refrigerators
Amana fridge ice maker not working
need to check water valve. probally need to replace valve. not letting water through. if valve is ok then ice maker module is bad
Jun 21, 2009 | Amana Refrigerators
Ice maker freezing up
The problem is in the water valve.
The water supply line going to the Ref is connected to a water valve. This valve is not shutting off completely which causes water to drip into the ice maker. This dripping will freeze and eventually completely block the fill tube in the freezer.
Aug 23, 2008 | Whirlpool ED2FHSS Side by Side...
Help, no water but have ice out of door on amana side by side.
The freezer temperature dial is set too cold and it is causing the water to freeze in the tube right where it enters the freezer section.If you turn the temperature selector one or two numbers warmer for the freezer it will help.
You will also have to turn the box off and let the freezer thaw real good so that the line will thaw. Once this has been done, it should work fine.
Jun 08, 2008 | Amana SXD524VW Side by Side Refrigerator
Amana 8 yr old side-by-side refridgerator/freezer
sound like you said a sealed system problem if compressor is running check the black coil under ref by the fan and see if it is warm if not you have lost freon just trash it then if it is see if fan in freezer is running if so pull back cover in freezer and see if coil starts to freeze if you have a ice block on coil then it is a defrost problem good luck
Dec 04, 2007 | Amana AFD2535DES French Door Refrigerator
My freezer is not keeping food frozen
defrost system is malfunctioning causing build up of ice. remove back panel of freezer, check for ice build up. if so, defrost carefulle with a hairdryer. also check drain is not blocked by ice. if it is, use hot water to get rid of it. (takes time)
Apr 25, 2007 | GE GSH25KGR Side by Side Refrigerator
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
140 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
