Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Blue screen no signal
Ws65813 mitsubishi. Worked great untill we moved. After we moved it, we could tur it on and it would play for about 20 mins and then blue screen with an error message stating loss of signal. all tv menus still worked fine. Now only blue screen with no signal message. all menus still fine
    Sergeant:
  • 233 Answers
You need to replace the surface mounted voltage regulator IC (small black square chip with a metal tab on one end, and two legs on the other end.) it is on the main board, right behind the signal input board. It's a BA09FP regulator IC, you can purchase this on mouser.com
it requires a bit of disassembly, but it is relatively easy to do. it is component number IC9C25. It could be bad, or just have bad connections . This IC supplies 9 volts to the terminal board. Try resolding it first.
Posted on Jan 15, 2009
I just bought this tv ws-55613 from a friend, when I looked at it i hooked up a dvd player and it worked great.after igot it home, i hooked it dish network. It worked fine until i started to play around...
This is 2003 model and does have a hard reset. It will return set to as it was when new in box, on air band on channel three, most likely you did something with remote that changed something.
I am in California and can tell you how to with the set on with the Mitsubishi remote enter the OPTION MENU AND RESET IT.
DO YOU WANT THIS INFORMATION?
A VERY HELPFUL RATING IN RESPONSE TO THIS SOLUTION WILL TELL YOU HOW TO GET INTO THE OPTION MENU.
SD TECH (in San Diego)
Aug 22, 2010 | Mitsubishi WS-55613 55" Rear Projection...
The lamp went out and i change it but the lamp light is srill on and the tv come ongos to a blue screen about 3-5 min. then gos off
blue screen usually is signal related. it will shut down after a few minutes if it doesnt detect a signal.
Mar 16, 2010 | Mitsubishi WD-62528 62" LCD HDTV
I have a Mitsubishi WT-42311. Last week the
where you saw blue it sounds like your blue crt is shorting out could be just the video amp so
i would suggest you have a tech look at it for and estimate
Nov 24, 2009 | Mitsubishi WT-42311 42" Rear Projection...
Blue gun jumped to right, and convergence adjustment ineffective
Your blue convergence amplifier is out and needs to be replaced.
Jul 05, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Mistubishi Convergence/video display problem
also check resistor values on the chips and resolder the tuner as this can cause problems as they heat up , then replace any electrolitic capacitors in the video circuts selector ic
i will be back to see what you get
electech
Oct 26, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
Mitsubishi WS-65807 + PS3 1080i Screen goes blank when bright white displayed
Go to PS3 / Display settings. Set superbright OFF, even if you don't have HDMI. Set Cross Color Reduction to OFF. Set Display to only one resolution, not all of them as you probably have it now. Set it ot the highest possible resolution and uncheck all other boxes. The 480i is always on by default. The issue, which was very annoying, was fixed for me. I have a mitsubishi 65 inch RP that is pretty bright on daytime/sunlight scenes, so I never thought it was the PS3, but only whet the PS3 was used did this occur. I scanned this site via google to find that nobody else appeared to have resolved this. So after some changes and testing this solution worked for me. Enjoy! - Dave Walz
P.S. I think the only real fix was to set just one display resolution, but I am now watching a movie and am not going to stop it to find out. :) That's for whomever follows this posting to find out for themselves. Either way, this is working great.
Apr 17, 2008 | Televison & Video
Ws65813
Check threads for DM repair or ctechnicians.com
Jan 04, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
247 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
