Question about Refrigerators
I have ice forming in the bottom of my freezer section of my GE Profile side by side refridgerator.
    Problem Solver:
  • 5 Answers
Probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Posted on Jan 15, 2009
  • Lou Cook Jan 15, 2009
    probably have a clogged drain at the rear base of the freezer unit check at the very bottom of your freezer at the back look and see if the drain is covered with ice..
Freezer forming ice stalagtite under ice tray
Sounds like the ice maker is allowing too much water in to the tray. There is an adjustment screw under the front cover of the ice maker. A 1/8 turn at a time counter clockwise will shorten the time the water delivery solenoid is open. It is possible that something foreign is keeping the solenoid valve to stay open too long, so it should be inspected too.
Jul 28, 2017 | GE Profile PSS26PSTSS Stainless Steel...
How to remove samsung imc701 icemaker from refridgerator
Take out the ice bin, remove the side panel with a screwdriver, press down the lever on the front middle top of ice maker and slide out the icemaker, unplug the wiring on the side, you're done.
Jul 26, 2011 | GE Profile Energy Star? PFSS6SMXSS...
GE Profile Refrigerator freezer not working right & ice in refrig
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Why is ice continuing to form at the bottom of our GE frig?
these units have a defrost drain that gets plugged.
you need to remove the ice from the freezer section and try to use a "turkey baster" to force water into the drain hole. it may be frozen and need to run hot water to get water to flow thru the drain.
sometimes you have to remove the drain from the back underside of the unit to clear the line. try the hot water inside first and if you cant clear the drain, then go to the back and remove the restriction from the drain line.
Jan 08, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side By Side not cooling on refridgerator side.
Look on the back panel inside the freezer for ice beginning to show. Most times when this happens the fresh food section is the first to notice. Your refrigerator has a control board on the back. If not defrosting the air flow to the fresh food section is greatly reduced. Let me know, Sea Breeze
Jul 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
SNOW FORMING IN FREEZER
Could be a number of things. Is the fan running in the freezer section, are the door gaskets sealing completely, even on the bottom of the doors? Could be a defrost issure where the thermotat is allowing it to over heat during defrost and the the cooling cycle starts after defrost and forms the ice an snow from the moisture in the unit.
Dec 30, 2017 | GE Profile 21.6 cu. ft. Side-by-Side...
Ice build up in bottom of refridgerator, loud fan noise
check gaskets for air leaks or blocked drain in freezer section
Jun 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Where is the drain pipe located in the side by side profile ge
in the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
157 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
