Question about Compaq Presario R3000 Notebook
Compaq presario r3000 amd athlon laptop cuts off after 10 minutes
I just installed a 250 gig hard drive and 2 gigs memory. the laptop never cut off before but when formatting the had drive partition it shuts down after 10 minutes everytime. what can i do to prevent this. I cannot install windows XP on it when it continues to do this.
  • 36 Answers
From my experience this might be one of two things...
if it's shutting down while you're installing windows, i'm thinking you might have a problem with the motherboard channel for your CD drive. i saw this happen to a computer at work - we couldn't install windows because it cut off halfway through and blue screened on us.
it might also be a case of a bad hard drive, if you have any testing utility like drive fitness test i'd give that a shot. it sounds like a new one, but they're bad out of the box sometimes.
hope this helps
Posted on Jan 15, 2009
Will a compaq Presario R3000 take one 2 G memory stick? I am trying to upgrade the memory on my partner's laptop. Can 1 stick of memory, 2GB, be used instead of 2 1 Gigs?
Hi Bronzen...
HP website for you laptop...
Please take time to rate me
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=125&prodSeriesId=384511&prodTypeId=321957&prodSeriesId=384511&objectID=c00208189
According to the HP website: 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB) Memory Max 1280MB DDR SDRAM (1 x 256MB, 1 x 1024MB
Sep 15, 2011 | Compaq Presario R3000 Notebook
Help Upgrading Processor
You'll find the information you seek at both the processor company and the motherboard company. As for remounting it in a Compaq case you may run into some issues of the On/Off Switch, power lead, reset button ect...matching up. You might be suprised at how inexpensive a new computer case is. I've seen some as low as $25. Your power supply can be removed and it will fit in your new case. You may just have a easier go of it. Good luck...please leave a rating, thank you kindly
Apr 25, 2009 | Computers & Internet
I have a Compaq presario V2000. Right now I have 60gig internal hard drive. Is there a max internal hardrive I should purchase? I can buy up to 250 gigs? How much would you recommend I purhcase?
Usually, the more storage the better. You can go up to 260 gig total with a primary 100 gig drive and a secondary 160 gig drive. Note that with the extra drive, the unit will use more power so think about that first.
Mar 28, 2009 | HP Compaq Presario V2000 Notebook
RAM memory in a Presario computer
No, it does not matter what size ram modules you have installed, aslong as they are supported by the laptop.
You can have 128MB on one slot and 1024MB on another for example, but these days its more common to have sizes like 1024MB and 2048MB. As long as the size and speed, type is supported it will work.
Thank you,
I will fix it!!
Nov 14, 2008 | R.A.M. Computers COMPAQ PRESARIO ATHLON...
Slooooooooooooooooow pc
the memory installed is not compatable with your laptop. try and get the proper memory for it. good luck!
Aug 28, 2008 | Computers & Internet
Slow pc
Hello juliet_34x,
Whats also important to perform when you up your memory to 2 gig is to adjust your Paging File as well. At 2 gig of primary memory, you will need to adjust the Paging File to 3000 (2 GB X 1.5) and Maximum size to 4092. In addition, if your computer was performing slow before the memory upgrade, you should perform disk cleanup and defrag (this will help alot).
Hope this helps and good luck.
Aug 25, 2008 | Computers & Internet
Install hard-drive
Sata drives don't have an option to be master/slave like IDE drives, b/c the Sata cable is per device. If the computer's not pulling up the sata drive, open device manager (right click  my computer, properties, hardware tab, device manager) and look for a yellow question mark. You'll have to install drivers for it more than likely.
May 16, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Ram memory
Okay, I have a stupid question, the more powerful the chip the hotter it runs. It could be the second slot will not work with a 1 gig because of heat issues and ventilation?
I have the same problem, with 2 one gig chips. I am going to try to replace the easy access slot with a 1/2 gig chip. I'll let you know.
Cheers,
Paul
Mar 31, 2008 | HP Pavilion zd7000 zx5000 zv5000 presario...
Compaq Presario R3000 Notebook Logo
243 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
