Question about Nokia N95 Cellular Phone
My pc cannot detect my N95
Once i connect my N95 to the pc i can only acces my memory card...
First u tell me how much cost n 95 clone. do u think it is ok to buy.
Posted on Jan 15, 2009
I have a problem with my nokia n95,i accidentally deleted my photos,videos and other files.i keep on downloading free software connected to my cellphones brand but i still cant recover my photos because...
Nokia N95 stores your pictures and videos on a memory card automatically.Therefore,you can recover your deleted pictures and videos from memory card with data recovery software.I have succeed to recover deleted pictures from SD card with Tenorshare.It can recover data after deeply scanning your memory card to look for lost data you accidentally deleted. But once your deleted pictures and videos were overwritten by new ones,they are gone for good.
Anyway,download a trial version and scan your memory card for free to check out whether your deleted pictures and videos can be recovered. http://www.any-data-recovery.com/index.htm
May 25, 2011 | Cell Phones
I have a problem about my phone N95. when i insert my memory card to my phone it appears that "memory card corrupted" .. and another scenario is that when i connect my phone to the computer.. the...
make sure all filles must be trancefer to memory first >>>then take out the memory >>start to reformat the cell phone make sure the memory card is not conenected to the phone after finish reformating return the memory card start the volume sething
Jan 19, 2011 | Nokia N95 Cellular Phone
Won't boot. Get following message:"Phone start-up failed. Contact retailer."
Your phones software or may be firm ware is deleted you should reinstall it.Do following:
  1. Connect your cell to your PC with DATA cable.
  2. If you do not have NOKIA PC suite then you must download it first. CLICK TO DOWNLOAD PC SUITE FOR NOKIA N95.
  3. Update your phones software.
  4. Backing up device data
    Before updating, remember to backup your device's memory on a memory card or Nokia PC Suite.
    To backup data to a memory card:
    • Select Tools > Memory from the main menu
    • Select Options > Backup phone mem.
    To restore the data after updating:
    • Select Options > Restore from card
Click here to DOWNLOAD N95 SOFTWARE!!!
Thank You!And good luck!!!
Dec 06, 2009 | Nokia N95 Cellular Phone
My mini SD memory card is write protected how i remove?
on the side from the sd card are litel handel move this to write (compleet acces) the card try it in the pc or card reader/writer if you have acces then it wil work then take out the sd card adapter and put mini sd card into the phone
Oct 22, 2009 | Nokia N95 Cellular Phone
N95 firmware glitch
if you are having software problems here is a guide i prepared to fix them.
There are 3 methods to format the phone
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! IMPORTANT: back up your phone and memory card first! ||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
First: if the phone menus work there is a; go to menu -> tools -> settings -> general -> factory restore. note: the defualt code is 12345
Seconed method requires you to enter these into the dial number area. Nokia Code : *#7370# : NOKIA Format phone (Soft Reset)
Nokia Code : *#7780# : NOKIA Factory Reset (Hard Reset)
Found these in the N95USERS fourm. Note: the defualt code is 12345
Third: is a button combination the needs to be done during the phone powering on
Hold down. 3, * and Green Call button While holding this combination press the power button once to start the phone Note: this does not require any codes; if this works the phone will prompt you to be set up again
None of these methods format the memory card
There are two methods to format the memory card
First: Go to menu -> tools -> utillites -> memory -> options -> format mass storage
Seconed: Connect your phone to your PC via the supplied USB cable. Then select Mass Storage mode on the phone. Once you PC has installed the Mass Storage device you can format the card from My Computer. Note: assuming Microsoft Windows XP or VISTA.
if none of these methods help your phone is fualty and will require to be reatuned to nokia or taken to a local phone tech for repair
Billman87
Jan 02, 2009 | Nokia N95 Cellular Phone
MEMORY CARD PROBLEM
try www.download.com and pc world.com., they offer all types of freeware program.
Oct 17, 2008 | Nokia N95 Cellular Phone
Memory cards and downloading anything from the interner
JORAM, I AM GUESSING THAT YOU HAVE A COMPATIBILITY PROBLEM WITH THE MEMORY CARD. ARE YOU SURE THIS MEMORY CARD IS COMPATIBLE WITH YOUR NOKIA N95? AND SINCE YOUR COMPUTER WON'T RECOGNIZE THE USB DRIVER, HAVE YOU TRIED TO OBTAIN AN UPDATED DRIVER? GO INTO PROPERTIES ON THE USB DRIVE AND GO TO THE DRIVER TAB AND THEN TO " UPDATE DRIVER " AND SEE IF THERE IS A NEW DRIVER FOR YOUR COMPUTER. TRY THESE, CHECK NOKIA FOR THE MEMORY CARD TO BE SURE IT WILL WORK WITH YOUR PHONE AND TRY TO UPDATE THE USB DRIVER. GOOD LUCK! HOPE THIS HELPS.
Sep 15, 2008 | Microsoft Windows 98 for PC
Memory card not acc
u switch off the phone... n remove ur card and then format it again in pc using memory card reader....then again insert ur card and use it....then first it'l detect n u can use....if the card dosen detect wen u connect to pc then ask ur retailer for servicing or replacement...
ne other prob's do tell me..N plz do rate me
cya
Apr 10, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Memory Card
hi there try to use another memory card maybe its damage, but if its still the same go to service center maybe the switch of the memory card socket doesn't trigger that is why your memory card did not detected. ok...
peace!
Dec 02, 2007 | Nokia N95 Cellular Phone
Format N95
Billman87
Nov 16, 2007 | Nokia N95 Cellular Phone
Nokia N95 Cellular Phone Logo
66 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
