Question about LG DLE5977 Electric Dryer
Power cord LG dryer spins but wont heat. I took the power cord off to use on a different dryer, but now i cant remember what color goes where. it has four wires, white, red, green, and black.
  • 21 Answers
My LG DLEX2910V dryer runs on and the drum spins but it doesn't heat up. It's only 3 months old and I have checked the vent and the power connections.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | LG DLEX2901V Dryer
REPLACE POWER CORD WITH FOUR WIRE
black far left
red far right
white middle
green goes to ground
Oct 03, 2009 | Maytag Neptune MDE6700A Electric Dryer
Plug problem
On a three wire configuration, the ground and the negative are tied together at the center position, using the dryer ground strap. Following is a description of the difference between three and four wire. Hope it helps you.
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom.
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Oct 01, 2009 | Whirlpool LER4634J Electric Dryer
I have a new 4 prong plug to replace a old 3 prong on dryer
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one on top/left is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown on the bottom/right.
Sep 15, 2009 | Westinghouse WWS833ES Super Capacity Top...
Need to replace the power cord
This is actually one of the easiest repairs to make on most dryers.
Unplug the dryer from the wall of course.
At the point where the dryer cord enters the dryer itself there is usually a plate. One screw should hold this plate in place. Remove the screw and pull the plate out (it should only be held in by a couple of tabs). The cord is attached to the power supply with three (or four) terminals. Back the screws out and slide the cord out. Make careful note as to which color goes to which terminal. Usually the black (or red) color goes to the gold screw and the white goes to the silver screw. The green screw holds the ground wire in place which is also usually a green cord.
Once you have done this step then loosen the screws that hold the cord in place on the plate. This fitting should open as you loosen the screws and the cord should pull out easily. Then thread the new cord through the fitting and reverse the process. Just remember to thread the cord through BEFORE you connect the wires so that you don't have to undo your work!
Hope this helps!
May 25, 2009 | Whirlpool Dryers
GE Dryer not producing heat
First, replace the door switch. Second, check the wiring of the new cord. It should be as follows:
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Third, if you still have no heat, make sure there is strong air flow out the vent outside the house when the dryer is running. If all that is good, check for 240 volts to dryer. (dryers can run the motor on 120, but need 240 to heat). Comment back (including model number) if you have further questions.
May 22, 2009 | LG DLE7177 Dryer
Hi, I hooked up my LG DLE5955W dryer and it powers up fine but I have no heat. The outlet I had for my old dryer was different than the one required for the LG. I went to home depot and got the correc
The following link explains how to properly wire a three or four prong 220VAC appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Read through the link provided, and make sure you have the power cord wired correctly at the terminal block in the back of the dryer. NOTE: If this is a new installation, you are required to be using a four-prong outlet with 4-prong power cord. If you have any questions, please let me know. I hope this helps solve your problem.
May 03, 2009 | LG DLE5955 Dryer
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
Powers on wont heat lg dle2532w
better to unplug the unit for an hour.
Mar 23, 2009 | LG DLE2532W Electric Dryer
LG DLE5977 Electric Dryer Logo
185 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
