Question about Nintendo Wii Console
Wii board not letting you step on
The wii board will not let you step on because every time it says "please, step off and press a." when you step off it says that the wii weights anywhere between 12-14 pounds...
help anyone?
  • 51 Answers
You will need a new Wii board unfortunately. The Wii board is not designed to be jumped on, nor an excessive amount of weight be placed on it, as it damages the springs inside the board.
If it is a new board, the chances are it is faulty. Take it back to the store you purchased it from and get it replaced.
Posted on Jan 16, 2009
My wii fit plus won t let me do basic or advanced steps
The Basic Step workout should be unlocked from the very beginning. You unlocked Advanced Step by completing Basic Step several times.
If you Basic Step option is unavailable from the start, I would recommend creating a new Wii/Mii Profile and testing it with a new game save to see if what you were experiencing is a software bug.
Please let me know if I can assist you further.
Regards,
KYTechnology
Mar 01, 2011 | Nintendo Wii Fit - Balance Board + Game...
New crown compatible wii fitness board will not sync with wii console. board only blinks a few times then switches off
Have new crown compatible fitness board, new batteries inserted, inserted Wii fitness disc, choose training, then trial, choose hula hoop game, used remote press A to start.
Screen says place me on a flat floor and press POWER button before stepping onto me
Followed the instructions power button flashes blue, as do the four corners then the lights go out - then nothing happening, still have the same message place flat on floor etc....
Have also tried the Wii Balance Board Check - followed all instructions last one says please turn on power. Pressed button flashes blue as do four corners then they go out
Am I doing something wrong or Is this a faulty board ?
Thanks
Sep 27, 2010 | Video Game Consoles & Games
What do you do when your wii balance board keeps saying please step off me and press A
Hit there
Hi there.
You may want to reseat the sensors. I have written a great tip with video about this.
Let me know what happens.
Thank you for using Fixya!
May 11, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps telling me to step off and press (A) even though i am not stood on it
iv got the same problem too, iv resync it and nothing, wiped the wii clean and started again and nothing (mine went down just b 4 xmas and 'santa' got my boy the wii fit plus and he ant been able 2 play it yep) PLEASE PLEASE PLEASE some1 help
Jan 29, 2010 | Nintendo Wii Fit - Balance Board + Game...
My wii fit board keeps saying..please step off me and press A...this is when im not even on it..
the wii keeps saying step of me and press a when im not on it can anyone help its drivin my mad! please help
Nov 10, 2009 | Nintendo Wii Fit - Balance Board + Game...
Balance board says please step off me and press A
Have this problem as well, what works for me is stepping off the board, lifting it off the ground until it begins to reset and then setting it down, obviously a problem with the corner sensors sticking.
Aug 31, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Wii board keeps telling me to press A
most likely a bad board or cable. There is a short somewhere
Apr 23, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
"Step Off Me and Press A" message while not on wii board
When you get this message, lift the board off the ground, press A, and wait until you get to the confirmation screen before placing the board back on the ground. You may have to try a few times to get the timing right. I have no idea why it thinks someone is on the board, but this workaround has solved the problem for us. Good luck.
Jan 04, 2009 | Nintendo Wii Fit for Wii
Power
    Try these steps!
  1. Insert a Wii Balance Board compatible game disc in the Wii console.
  2. Use the Wii Remote to select the Disc Channel from the Wii Menu, then select "Start" to begin the game. Press the A Button to bypass the wrist strap screen.
  3. Open the small SD Card slot cover on the front of the Wii console.
  4. Remove the Battery Cover on the bottom of the Wii Balance Board.
  5. Press and release the SYNC button on the Wii Balance Board. The blue light on the board will start blinking.
  6. Press and release the red SYNC button on the Wii console while the blue light on the board is still blinking.
  7. The blue light will stop blinking and stay on steady once the syncronization is complete.
Sep 09, 2008 | Nintendo Wii Fit for Wii
Wii fit
are you able to get any of your controllers to connect? if not it could be a issue with your sensor bar. please provide a bit more info
but try this first
Synchronizing the Wii Balance Board with your Wii Console
IMPORTANT: To operate correctly, the Wii Balance Board must be synchronized with the Wii console using Standard Mode Synchronization. Follow the steps below to synchronize the board to the console.
  • This procedure must be followed for each Wii Balance Board compatible Game Disc.
  • These synchronization settings will be saved even if the console is turned off.
  • This procedure can be completed only if a compatible Game Disc is running in the console.
  1. Press the EJECT Button on the front of the Wii console and remove any
    game disc if necessary. Insert a Wii Balance Board compatible Game Disc.
  2. Use the Wii Remote to select the Disc Channel on the Wii Menu screen and select START.
  3. Open the SD Card slot cover on the front of the Wii console.
    NOTE: Close the SD Card slot cover when you are finished with the synchronization procedure.
    NOTE: Replace the Battery Cover when you are finished with the aynchronization procedure.
  5. Press the SYNCHRO Button (SYNC.) on the Wii Balance Board. The Power LED on the board will start blinking (for up to about 20 seconds).
Press the SYNCHRO Button (SYNC.) on the console while the Power LED on the board is blinking.
  1. IMPORTANT: Do not press and hold the SYNCHRO Button on the Wii console down for more than 10 seconds. This will delete all of the Standard Mode synchronization information for all Wii Remotes that you use with that console.
  2. The Power LED will stop blinking and light steadily once the synchronization is
    complete. You are now ready to play the Wii Balance Board compatible Game Disc. Please refer to the instruction booklet for the Game Disc you are using for further information on gameplay.
  • Only one Wii Balance Board can be synchronized to a Wii console at a time. Up to a total of 10 Wii Remotes and accessories can be synchronized to a console at any time with the Standard Mode procedure. If additional synchronizations are made, the oldest existing ones will be overwritten.
  • The Wii Balance Board can only be synchronized to one console at a time using the Standard Mode procedure. If you change the console you are using the board with, you will have to repeat the synchronization procedure each time.
  • The Wii Balance Board uses the Player 4 (P4) connection. If a Wii Remote is actively using P4, that remote will be disconnected while the board is being used.
Aug 01, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
121 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
