Question about Pioneer VSX-915 Receiver
Pioneer VSX 915
Hi, I purchased this unit 2 years ago and have had a problem free run, over the last couple of days however i have had a problem whereas when I turn up the volume to say -30 it comes up with an overload message on the screen and then automatically shuts down. I have checked all of the wiring thoroughly and cant seem to find any faults. Can you suggest anythinng Regards Lee
  • Lee Robson Jun 16, 2007
    Appreciate your help, seems to have solved the problem, disconnected all speakers, reconnected one by one and sure enough one seemed to make it overload, removed and re-ran the relevant wiring and it's all go.
    Thanks again !
    Lee
    President:
  • 3,130 Answers
Disconnect the speaker leads and see if this stops happening. If it does, connect up the speakers till the problem pops up, and that speaker that makes the problem happen is most likely bad. If the problems still happens with no speakers attached, then there is a problem in the audio output amp, and is going to need service , Good Luck
Posted on Jun 15, 2007
  • Larry  Dillon
    Larry Dillon Jun 16, 2007
    Glad to hear we could assist you! Please do not hesiyate to come back for more assistance!
Pioneer manual repair
You have probably blown an internal fuse.
You may find more information here:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/218219098VSX815OperatingInstructions.pdf
If you are inexperienced in electronics repair,
you should take your unit to the nearest Pioneer service center.
Jul 21, 2014 | Pioneer VSX-815-K Receiver
Pioneer model VSX-3300, I had
here you can see faulty capasitors
Hard to say what may be the problem.
Jun 07, 2008 | Pioneer Audio Players & Recorders
Pioneer vsx 915 blue light flashing
Time for a repair shop to look, clearly the amp is down, it has failed. Have a qualified tech look at and get a repair estimate.
Dec 15, 2012 | Pioneer VSX-915 Receiver
I have a 2 year old Pioneer VSX-819H-K that only recognized the remote signal from about 2 feet away. Worked fine last night. Changed out the remote batteries three times, then programed a Cox...
hi,
You have to order for the IR receiver module for the system. Also check inside the frond panel of the system is there is any durst accumulated in frond of the IR receiver unit.
ok
May 07, 2011 | Pioneer VSX819HK 5 Channels Receiver
I need instruction manual for pioneer amp vsx-416 please
www.pioneerusa.com then support. I could not find VSX-416. Depending on where you purchased the unit, it may be the same as another similar model #. You can browse thru the models and pdf them for free. Hope this helps
Aug 17, 2009 | Pioneer A/V Ampli tuner 5.1 VSX-416-K...
Overloads all the time under 40db.
Hi Glen. The thing with these new units is that they are so fussy when it comes to frequency range on the speakers. The frequency has to be within the range that the amplifier specifies, or you'll have problems. I suggest that you check your manual to see what the required frequency shuold be and take it from there. I have one myself and love Pioneer
Aug 02, 2009 | Pioneer VSX-D509S Receiver
Cannot fix the sound
Take it back this receiver is out dated by at least 5 years (mine is over 5 years old) Purchase a newer one......
Jan 17, 2009 | Pioneer VSX-D412 Receiver
Pioneer VSX 915 powe off
Had a power surge last night and got the same problem. Unit wont power on and has a blinking blue light on standby button. I found the solution from the service manual for a similar model.
Hold down ENTER and ADVANCED SURROUND buttons.
This resets the DC overvoltage sensor and bingo the unit comes back to life again.
Jun 18, 2008 | Pioneer VSX-915 Receiver
VSX-D498 Overload
if you have an EQ hooked up it will not work correctly with dolby digital playback and will dammage the reciever.
sorry, just got here , but I have the same unit and have had it for 5+ years and it still works great ! but if you want any device to last unplug it when you are not going to use it for a while.
Dec 22, 2007 | Pioneer VSX-D498 Receiver
Pioneer VSX-915 Receiver Logo
198 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
