Question about GE Advantium 120 Convection/Microwave Oven
Hi! Our GE Adventium 120 oven stoped working at all.
Microwave oven like is dead. I think it is problem with fuse, but i don't know how to find it.
Model #SKA1001HSS 03 manufactured July 2005
Thank you
Ed
  • edgirshik Jan 18, 2009
    Thank you.
    I would appreciated if you give me the location of the fuse. I have enough qualification and tools to fix this problem. Please again tell me the location of the fuse in the Advantium 120 Oven.
    Thank you
    Edward
  • edgirshik Jan 19, 2009
    I have checked it several time all okey. I have insert a probe and a lamp in the plug. All okey
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, on most microwave ovens, the fuse is inside the unit. To be able to replace this, the outer cabinet has to be removed (undo the side screws). If you would trace the patch of the power cord, it would normally lead you to the fuse similar to the image below.
The ratings are stenciled on the metal part of the fuse and they are readily available from most hardware stores, Sear or even the friendly neighborhood electronics shops.
A few words of caution:
  • pls make sure the unit is unplug before attempting to even open the unit;
  • if the fuse is blackened, it is an indicator that some other component(s) maybe defective;
  • pls replace with the same rating/type of fuse.
Check and perform preliminary visual or necessary inspection. Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 18, 2009
  • 10,515 Answers
The genuine link to purchase ge parts :)
http://www.partselect.com/repair.aspx?appliance=range-stove-oven&part=Fuse-Testing
if u are unable to find the part, there is a number on upper LHS...call that and get
the part at ur doorstep within few dayz.
Take care.
    President:
  • 2,110 Answers
Check for a blown fuse first its 20amp 120volt. Be sure and get more than one because it you have a shorted diode it will blow it.
  • GE Master
  • 13,433 Answers
If your microwave oven doesn't seem to work at all, check these:
Fuses
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
  • Ekse Jan 18, 2009
    I haven't found a repair manual for your model.
    First remove the outer cabinet of the unit, which is usually held in place
    with a few screws. Once the outer cabinet is removed, follow the power
    cord into the unit. It will take you to the fuse holder, where the fuse
    sits. The fuse holder is located two or three inches into the unit, and
    may be attached to a power board.
  • Ekse Jan 19, 2009
    If the fuse is not the problem check the door switch.
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
Hi how r u?? my microwave just stoped working,there isnot light,there is not fan,,nothing ,,is dead so I would liket o know if this microwaves have a fuse??
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 07, 2011 | Magic Chef MCD990W Microwave Oven
My Advantium suddenly stopped working while using it. Acts as if it is unplugged. I checked the electric circuit and surgeprotector they are okay. It acts as if it blew a fuse, but I don.t know where...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 02, 2011 | GE Advantium 120 Convection/Microwave Oven
G.E. ADVANTIUM 120 JUST WENT DEAD NO POWER AT ALL.
Bill,
I have the same unit. It just happened to me. DId you find a resolution?
I was using it on the oven mode and it just stopped working. It's completely dead.
Thanks
Bob
Apr 11, 2010 | GE Advantium 120 Convection/Microwave Oven
GE Advantium - No power at all - PSB2201NSS01
Does the unit have power?If not check the back and see if ou can take off. Most unit have fuse back there.
Mar 13, 2009 | GE Advantium 120 Convection/Microwave Oven
Ge XL spacesaver Microwave blowing fuses
I had the same problem.
Took it in to the local repair guy and he found the transformer was blown.
Cost $120 including tax
Jan 15, 2009 | GE JVM1630 Microwave Oven
G.E. convection oven fan stoped working. The fan turns freely with no resistance.
Does it have 110 volts on it? If so its bad.
If not then look for a bad relay.
Jan 14, 2009 | GE Advantium 120 Convection/Microwave Oven
F3 error code GE 120 Adventium Oven Model SCA 1000 HWW 02
F3 means you have a shorted switch on the key assembly circuit board.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me
directly (and please remind me of your model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 25, 2008 | GE Microwave Ovens
GE Advantium 120 Convection/Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
