Question about D-Link DES 1024R Plus (DES-1024R+/5) Networking Switch
Help Indian Guru...no connection
All of a sudden my switch has all its lights ON. Everything the power, the 100Mbps, the Link/Act all of them but none of my computers are getting any connection. It just shows network cable unplugged. How do I trouble shoot. Help me quickly please....
    President:
  • 1,314 Answers
Have you tried unplugging the modem for two minutes then plugging it back in?
Posted on Jun 15, 2007
INTELLINET+523301+power+light+is+yellow
Try the connection directly to your pc.
If works possible solutions are :
1-The device is fry
2-Update the firmware
3-call your ISP
Feb 04, 2014 | Intellinet Network Solutions Intellinet...
I need the master password
If the switch has not been configured leave the username and password blank here is link to dlink support which has the manual and everything you need to know to configure and reset it.
Apr 30, 2011 | D-Link Dlink DES-3028P Switch 24-port...
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Head light and beck light not on
Check fuse, then check for power to & from headlight switch, if no power out suspect continuity across switch.
Also check for squashed wires & bad connections.
The usual place that wires corrode + brake is where the main loom goes around the headstock as they move when handlebars are turned, so check for continuity along relevant wires.
Please mark this as very helpful (if it has been!!)
You could help me back by letting me know the fork stanchion diameter for Indian RD350 HT model 1987, or just the fork seal sizes. (I've never asked for favour back on this site, but I just cannot get info on Indian made bikes here in UK)
Ride safe
Bike-Doc
Apr 23, 2010 | 2005 Bajaj Pulsar 150
One light is out on my linksys usb200m
It depends on which light is OFF: Below are the LED indicators:
100/ACT Green. The LED lights up when there is a connection to a 100Mbps network. It flashes when the computer is transmitting or receiving data at 100Mbps.
F/H Green. The LED lights up when the Adapter is operating in fullduplex mode. The LED is off when the Adapter is operating in half-duplex mode.
10/ACT Green. The LED lights up when there is a connection to a 10Mbps network. It flashes when the computer is transmitting or receiving data at 10Mbps.
Dec 04, 2009 | Linksys USB200M USB 2.0 Network Adapter
I connected an ethernet cable to the DES-1024D switch, but the link/act LED didn't light
Is the switch powered up?
is the Ethernet cable connected to a working/powered/enabled NIC?
Jun 10, 2009 | D-Link DES-1024D Express EtherNetwork...
Link/act LED of DES-1024D switch
The ethernet cable is probably damaged. If it is not... is the switch plugged in? Does it power on? Is the other end of the ethernet cable plugged into a live host?
Jun 08, 2009 | D-Link DES-1024D Express EtherNetwork...
Reset speed from 10Mbps on 100Mbps (D-Link DE-1824i)
Tony,  I was looking at the specs and found these lines :- Choices of 12 and 24 10BASE-T ports per hub
1 100BASE-TX port (for connection to 100BASE-TX hubs) Which is saying that the user/pc ports are fixed 10Mps and there is one 100Mbps uplink port to connect two hubs together.
http://www.dlink-intl.com/Products/Hubs/DE1824.htm
Apr 13, 2009 | D-Link DE 1824i (DE-1824I) Networking Hub
Help no connection
Check the cabling. Could possibly be a broken pair in the cable. Make sure all ends are not damaged.
Jun 15, 2007 | D-Link DES 1024R Plus (DES-1024R+/5)...
D-Link DES 1024R Plus (DES-1024R+/5) Networking Switch Logo
145 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
