Question about Traxxas T Maxx 3.3 Monster Truck
Cant get it out of reverse
Im thinking its the remote or transmssion but if it is the remote how do i get it out of reverse
    Novelist:
  • 99 Answers
There are a few things you can check besides the transmitter (remote). First, check all the other functions like steering and throttle/brake.
If they are working fine, try recharging the receiver (Rx) battery pack and putting fresh batteries in the transmitter (Tx).
Then, check to see if you can pull the linkage out by hand. If you can move the servo by hand and not with the Tx open the Rx box (with the antenna sticking out) and check to make sure none of the servo lead wires came loose.
If you can't move it by hand, it is most likely the dog gear or shift fork inside the transmission.
If the servo lead is tight, you can move it by hand, and it still won't move, check to see if you have a solid green light on the Rx box and a blue light that when you roll the truck (engine off) it should blink off and on. Make sure you have the Tx on also.
If you have a red light and no green or blue light, the Tx is off, low on battery power, or one of the frequency crystals is loose or damaged (replace if the latter).
If the green light is on but flashing, the Rx batteries are running low. If the blue light will not flash when you roll it foreward slowly, there may be a problem with the sensor that goes to the transmission.
There are many solutions to a simple problem but if you are still having trouble try these methods and tell me your results. If you are in the Missouri area I am very skilled in fixing these trucks and would be happy to take a look. I can fix most any problems and get your truck running better than new, tuned for racing and maximum power.
P.S. these are solutions for a t-maxx with a traxxas opti-drive system. If you have a different type of vehicle, tell me so I can find the most specific solution for your exact vehicle.
Posted on Feb 26, 2009
My caravan fails to find reverse unless it it warm
get the electronics checked and get the transmission a full diagnosis. it could be mechanical failure because when metal heats, it expands and it could be that some solenoids arent working properly until theyve expanded
Oct 18, 2012 | 1993 Dodge Caravan
Im putting a used transmission in a 1994 explorer do i have to flash the computer
If you are using the correct replacement transmssion you will not need to flash the computer
Dec 14, 2011 | 1994 Ford Explorer Limited
My car will not start unless I push the shifter allt he way up into PARK
sounds to me like you need to have shifter cable or park neutral position switch adjusted. The car is thinking that you are in "reverse" and it will not start. When you push the shifter forward it turns off the signal telling the car that it is in reverse and it will start, because you are putting pressure on it making it think that it is in "park"
Jul 12, 2011 | 2009 Nissan Versa
I have a 98 sunfire and my tansmission isnt shifting properly. it started a few days ago and today i couldnt get it to move at all for labout 5 minutes. im thinking its my transmssion fluid but i put a...
I will venture to say that if the fluid level is on full then it is time for a filter change. You check the tranny fluid by setting the emergency brake, then sticking it in neutral and starting the car. Go see how it looks that way and let me know. I am not saying you didn't know how to check it. I am double checing with you. LOL Raz
Apr 19, 2010 | 1998 Pontiac Sunfire
I'm going to buy an audi a6 1,8 2000, wat do u think
THE ONLY REAL REPORTED FAILURES ARE THE AUTOMATIC TRANSMSSION FAILING.
Nov 11, 2009 | 2000 Audi A6
I just installed a clutch in my 96 saab 900s 5speed transmssion with a 2.3 l nonturbo and also a clutch cable and now I cant get it to go into reverse or 5th gear . Anyone have a clue ?
Loosen shift coupler where you disconnected from rod.Remove shift boot at front there is a hole put an allen or dowell in it to lock the shifter on trans side where shift rod exits tranny theres another hole for a pin. Line these up and tighten coupler and that should do it.
Jun 30, 2009 | 1993 Saab 900
Reverse lights not working on 1993 Ford Ranger
Not sure what transmssion you have but basically it goes from fuse on P/O wire to either the MLP switch on automatic or just a backup lamp switch on manual and leaves the switch on BK/PK wire to the bulbs. Should be easy to trace with a 12v test light.
Feb 05, 2009 | 2006 Ford F-150
Traxxas T Maxx 3.3 Monster Truck Logo
195 people viewed this question
Top Traxxas Toys Experts
Michael Brisco
Level 1 Expert
John mullen
gbob59
Are you a Traxxas Toy Expert? Answer questions, earn points and help others
