Question about Shredder Office Equipment & Supplies
Cross cut shredder no longer stops after paper is shredded.
It is a executive machines eps 150 IX purchased at Staples. About a year old. It sounds like it comes to an abrupt stop when I hit the power switch to stop it as that is the only way to stop it now. No longer automatic. Normally I left it on and when I inserted paper, it started and stopped when it was shredded. Now when I turn on power, it just stays on
Thanks
Gordon
4 Suggested Answers
JayBlair
  • 328 Answers
SOURCE: when on
Make sure there is no paper blocking the sensors. Otherwise you may have a bad sensor or switch.
Posted on Jun 05, 2009
FixinFax
  • 3085 Answers
SOURCE: have same staples cross t 826x shredder.....doesn't shut off, BUT
Thanks for taking the time to leave a good tip.
Posted on Aug 10, 2009
SOURCE: staples spl-710sh paper shredder stopped shredding
This exact thing has happened to my unit as well. Ive disassembled it to discover that 5-7 teeth on the gear that the motor drives have been stripped off. Unless the gear can be replaced (which is probably not worth the expense), then the unit is toast. Sorry. Good luck.
Posted on Nov 01, 2009
My Executive Machines EPS 1200X shredder works in reverse, but does not shred.
there should be a forward/ reverse switch that is used to unjam paper being shredded. check that
if it is automatic then check for paper stuck in the shredder causing the reverse action.
May 12, 2015 | Shredder Office Equipment & Supplies
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
Can not feed paper
First try moving the switch manually to reverse. The machine should start. This may cause some paper to appear in the slot where you place the paper to be shredded. If it doesn't start, your problem may be more serious or complex and you should get in touch with the Staples store where you purchased it.
It may be that the paper you are trying to use is too lightweight. Try inserting a piece of cardboard (SLOWLY SO AS NOT TO LET THE BLADES CATCH THE CARDBOARD - LETTING IT CATCH THE CARDBOARD MAY BE BEYOND THE UNIT'S CAPACITY). If this starts the shredder, quickly remove the cardboard. If it continues to run (cycle), you may have had some paper blocking it.
Hopefully this has done the trick and everything now works. If not, talk to the Staples store where you bought it.
Jan 08, 2014 | Staples Cross-Cut Shredder
I just bought the Omnitech 10 Sheet Cross Cut Shredder. Is it safe to shred papers with staples in them?
I don't have that model but have an 8 page cheapo shredder. It takes CDs, credit cards and staples with no whining.
Oct 23, 2013 | Omnitech 12 Sheet Cross Cut Shredder
Executive Machines EPS-1200X Shredder has power but papers are stuck and there is no sound from motor
You will need to clear the jammed paper using tweezers from between the rollers. Make sure the sensor arm in the middle of feed opening is not stuck and moves up and down freely. If not you will need to give it a good soak with lubricant to allow any stuck paper to soften and loosen. Once cleaning procedure done unit will be good as new
Oct 13, 2013 | Staples Executive EPS711X Shredder
How do you remove the top to see the gears in a Royal 16CDX cross cut paper shredder. The overload message is displayed, and I don't know how to get it unjammed.
a possible solution is to UNPLUG the unit, reach in from underneath and start pulling stuck paper out. On mine (different model) I can remover the paper receptacle bin and reach up to remove stuck paper. this usually is caused by overloaded bin pushing shredded paper back up to cutters because it is overfull......BE SURE TO UNPLUG FIRST !!!!!
Nov 17, 2012 | Royal 160MX Also called 16CDX Cross-Cut...
ROYAL 150 MX WILL ONLY TAKE 2 SHEETS
Have you ever "oiled" the machine.
ALL cross-cut shredders need to be oiled to help clear out the paper dust and debris generated during the shredding process.
Pour some shredder oil across the cutting shafts while it is running and occassionaly put some oil onto a sheet of paper as you shred it.
May 09, 2011 | Royal 150MX Cross-Cut Shredder
When we put paper in our shredder, even just 1 sheet, it sounds real sluggish like it's losing power, then it almost shuts off and the trouble light comes. It's plugged in. Is there a fuse or something...
Have you ever oiled the machine.?????
Cross cut shredders need to be lubricated due to the amounts of small paper and dust generated.
Get some "shredder oil" run the machine in reverse and pour some of the oil onto the cutting blades...then when you shred paper put some oil onto a sheet of paper prior to putting it in the shredder. How often do you oil it??? depends how much shredding you do.
Nov 20, 2010 | Royal 1280MX Shredder
I purchased a Royal Shredder, Mod. VF1700MX, Ser. No. 080245302 on Feb. 25, 2009. It was sent back for repair, under warranty about a year ago. I never shred more than 5 sheets at a time.It now cuts out on...
Have you ever "oiled " the machine...99% of cross cut shredders have to be oiled... get some shredder oil and squirt it onto the cutting blades where you put the paper in...this should be done with a certain frequency dependant on the amount of shredding that you do.
Nov 02, 2010 | Royal Office Equipment & Supplies
When on
Jun 04, 2009 | Office Equipment & Supplies
106 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
