Running Windows 7 computer begins to boot up showing Windows logo then screen goes black and displays OVERSIZE Mode recommend 1280 X 1024. I switched monitors and resolution is at 1280 x 1024 and cannot be set any higher.
SOURCE: Oversize Message
dear,
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
regards,
dont forget to rate
SOURCE: I have this monitor and just bought a new
You may try the following steps:
Boot the computer in safe mode.
While booting press the F8 key and on the Windows Advance boot screen, select safe mode and press enter.
Once you are on the logon screen, select Administrator account.
Click on Start and rightl click on My computer, then click properties
Go to hardware tab and click on Device manager.
In the device manager look for Display adapter, Click on the + sign, right click on the listed devices and uninstall.
Now you should be able to boot the computer in normal mode.
Please let me know if you need any further assistance.
If you find this solution helpful, please do not forget to leave your feedback and ratings.
Thank you for choosing Fixya.
SOURCE: I installed an ATI Radeon HD4650 video graphics
Need to proper installation for that video card. I hope you have the driver for that operating system.
SOURCE: I am unable to change the screen resolution. My
Hi.
The solution depends on your graphic card. There are graphic adapters that do not support less than 1280 x 1024. In that case you will really need to replace the monitor.
Try setting the screen resolution from safe mode (see: Change your screen resolution)
If the resolution is restored to 1280x1024 after you set it manually, then you will need to replace the monitor because it is not compatible with the computer. There is no way out as that is the way the technology market works nowadays. Upgrading equipment is a must, not an option.
Regards.
Ginko
