Question about Dell Inspiron 8600 Notebook
8600 inspiron fell wont boot
Fell off bed. will start to the window asking safe mode or other options. in safe mode gets to one of the driver(?) lines and stops. in other modes windows tries to start but hangs up before it loads.
  • baxleywm Jan 15, 2009
    reseat memory modules did not work. perhaps it is the hard drive. probably take to a tech. thanks though!
  • Dell Master
  • 4,806 Answers
Hi there
The shock from the drop may have displaced the memory modules and the video drivers could be failing, take them/it out and re-seat them/it, then try to boot the pc again. If this does not work the hard drive has took the brunt of the shock and you have to run the recovery cd or partition. I must warn you however, that you could loose data if you have to perform a recovery.
Good luck and let us know how you get on.
Posted on Jan 15, 2009
PC fell onto floor and won't boot properly
Insert your original OS disc and try to perform a repair. If it is Windows you will need your OS license number.
Most likely a file was writing when the pc was dropped and is now corrupted.
Nov 26, 2017 | Computers & Internet
The windows logo comes up with the bar that moves across screen when it loads. then my screen goes black.
This could be either of two problems; the Windows installation itself or a display problem. Watch the screen from a shallow angle to see if you can discern nay 'ghost' images. If you can, then it is likely that either the back-light tube (a small fluorescent) or the inverter that produces the high voltage for it has failed. The inverter is normally on a narrow board with only a few components on it that may be mounted in either the display section or in the laptop's base.
If you can't detect any 'ghosting,' then it will be necessary to reinstall Windows to refresh the software. Try starting in the 'Safe mode' which may still load if only the display drivers are damaged.
Apr 20, 2011 | Dell Inspiron 8600 Notebook
My acer aspire one kav60 fell and gives the options to start using safe mode,,safe mode with networking,,last known settings that workedq,, ect but restarts once it gets to the windows xp splash screen...
Try to restart the system using " last known good configuration " option.
If the problem persist you may have to restore the system to earlier restore point by starting the system in safe mode.
hope this will help.
With regards:
Kartikey.
Apr 14, 2011 | Acer Aspire One PC Notebook
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
My dell inspiron 2200 wont start up..Well it starts up but then it sais "Windows start up has failed." and it gives me options to start up in safe mode with command promt and safe mode with networking...
Boot your PC with the windows OS disk and choose to repair your computer when asked. Run the chkdsk program in DOS on the recover mode to correct disk errors.
On completion, restart your computer normally and check it it works.
If it does not work, you may need to format your pc & reinstall windows again.
Aug 02, 2010 | Dell Inspiron 2200 Notebook
Windows XP will not start on Inspiron 1300. Get blue screen with the following codes. 0x00000024 (0X001902FE, 0XF88F53D4, OXF88F50D0, 0X828AE805)
So many computer face this blue screen fetal errors on windows.
This error comes usually when there is problem in software or driver compatibility issue with hardware or operating system.
Also this error comes when there is bed indexing unit in hard drive.
You can solve this errors with following 2 methods.
(1)When you power up the computer press F8 key then enter in safe mode.
Then if you are able to enter in safe mode then uninstall driver or software which you installed recently and face this error.
(2)If you are not able to enter in safe mode Then you need to fix error on hard drive.For that you need windows disk or recovery disk.
Boot your computer with that disk
For that when you power up the computer press F1 or F2 "del" key to enter in bios.
Then go to boot menu and set frist boot device as your cd or dvd rom.
Then save settings and exit bios.
Insert windows disk in cd /dvd rom.
Then it boot with that disk.Then you get this message "Press any key to boot from cd.."
Then press any key.
Then follow the procedure then enter in recovery console mode then type in prompt "chkdsk /r"
Then type "y"
Then it fix error on hard drive.
Then check if again you are not able to enter in windows then boot again and this time choose "R" option for repair previous windwos " then it repairs old windows then it loads again old windows.
Dec 18, 2009 | Dell Inspiron 1300 Notebook
XP wont load in safe mode
MAY BE DUE TO LOT OF VIRUSES. DISMOUNT YOUR HARDDISK FROM YOUR SYSTEM AND SCAN IT FOR VIRUSES IN ANOTHER SYSTEM WHICH HAS THE LATEST UPDATE OF A POWERFULL ANTIVIRUS SUCH AS KASPERSKY....
Sep 23, 2009 | Microsoft Windows XP Professional With...
My HP Notebook first showed a black screen and then after a hard shutdown and restart it only shows a black screen with colored lines. It seems that it is starting up even though I can't see the screen.
Try this,Start in VGA mode.Once started,update your video drivers
To use a Safe Boot option, follow these steps:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Safe Boot options loadTOCNode(2, 'moreinformation');
  • Safe Mode (SAFEBOOT_OPTION=Minimal): This option uses a minimal set of device drivers and services to start Windows.
  • Safe Mode with Networking (SAFEBOOT_OPTION=Network): This option uses a minimal set of device drivers and services to start Windows together with the drivers that you must have to load networking.
  • Safe Mode with Command Prompt (SAFEBOOT_OPTION=Minimal(AlternateShell)): This option is the same as Safe mode, except that Cmd.exe starts instead of Windows Explorer.
  • Enable VGA Mode: This option starts Windows in 640 x 480 mode by using the current video driver (not Vga.sys). This mode is useful if the display is configured for a setting that the monitor cannot display.
Please rate this a fixa
Feb 01, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
My computer is not booting up.
Try this,Start in VGA mode.Once started,update your video drivers and do a virus scan
Jan 15, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
8600 inspiron laptop
Unless you can see the little safe mode text in all 4 corners then it sounds like the computer IS in regular windows, but the video card drivers are gone. Try re-installing the video card drivers from Dell for that particular video card (there are several possibilities) and see if that helps. It is possible the video card is going bad, but usually re-installing the video drivers works.
This could be a sign of other problems too- start with the video drivers and see if that helps. If it does not- I'm guessing the operating system is corrupt, virused, or the video card is going bad.
Jun 29, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 8600 Notebook Logo
65 people viewed this question
Alun Cox
