Question about HP LaseJet 4350dtn Laser Printer
Getting an display in the printer.
Hi, I am using an HP Printer 4350 in the display panel I get a message saying as ?Perform maintenance configuration". What should i do for this?
    Scholar:
  • 121 Answers
If you have the manual there is probably a section about this. It does sound like some parts may be wearing out and the printer is asking for new ones. Check out this link: http://www.printertechs.com/tech/maintcount.php A snip from the info there: If the display panel on your HP laserjet reads "perform printer maintenance", "perform user maintenance", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count. For example the laserjet 4000 has a 200,000 page maintenance interval. Once you reach 200,000 pages the error message appears and you need to reset the maintenance count to zero to make the message go away.
Posted on Jun 15, 2007
HOW I WILL GO IN SERVICE MODE OF A PRINTER
Clearing the Maintenance Count and Service Message: HP LaserJets servicepin.jpg
If the display panel on your HP LaserJet reads "Perform Printer Maintenance", "Perform User Maintenance", "Maintenance Kit Low", "Maintenance Kit Very Low", or anything along those lines it means your printer needs a preventative maintenance kit, which includes a fuser and various rollers. Once you have installed the maintenance kit the message will only go away if you clear the maintenance count.
Oct 31, 2014 | Ricoh Aficio SP C410DN Laser Printer
How to reset the meter counter after replacing the fuser assembly on hp8150 laserjet printer.
Here is the step by step guide to resetting that message.
Reset the "Pages Since Last Maintenance by using this procedure:
  1. Turn off the printer.
  2. Hold down the left side of the ITEM and VALUE keys at the same time.
  3. Turn on the printer.
  4. Wait for RESET MAINT\\COUNT to display, and then release the keys.
  5. Allow the printer to initialize normally. The display will read "READY ".
Turn off the "PERFORM PRINTER MAINTENANCE message by following these steps:
  1. Press the MENU key until the display reads CONFIGURATION MENU .
  2. Press the ITEM key until the display reads MAINTENANCE MESSAGE=ON .
  3. Press the -VALUE+ key once. The display should read MAINTENANCE MESSAGE=OFF .
  4. Press the SELECT key to put an asterisk by the setting and save it.
Mar 18, 2013 | HP LaserJet 8150 Printer
Perform printer maintenance message
You need to follow the instructions given in the LaserJet 4300 User Guide which can be found at http://h20000.www2.hp.com/bizsupport/TechSupport/CoreRedirect.jsp?redirectReason=DocIndexPDF&prodSeriesId=84041&targetPage=http%3A%2F%2Fbizsupport1.austin.hp.com%2Fbc%2Fdocs%2Fsupport%2FSupportManual%2Fbpl12546%2Fbpl12546.pdf - go to page 93 of the PDF which describes how to "Perform preventative maintenance". . . The message you are seeing occurs after 200,000 pages have been printed and may require you to purchase and install a new printer maintenance kit to solve the problem.
Dec 22, 2011 | HP LaserJet 4300 Printer
Regularly getting error code 50.9 on a HP color laserjet 3550 printer
Hey Joe,
This is what the HP Website has to say about it:
50.X FUSER ERROR Description A fuser error has occurred. Action
  1. Turn the printer off.
  2. Verify the fuser is properly installed and fully seated.
  4. If the message persists, contact HP Support.
BUT! you can try performing a cold reset, and maybe this would help:
500, 3550, 3700, 4600, 4650, 5500, 5550, 8500, 8550, 9500) use the instructions below. 1. Turn the printer on.
2. When the memory starts counting on the control panel, press and hold the green SELECT button. Continue to hold green SELECT button until all three Control Panel LED's are illuminated and on solid.
3. Release the green SELECT button.
4. The control panel will display SELECT LANGUAGE.
5. Press the DOWN ARROW button until control panel displays COLD RESET.
6. Press green SELECT button. The printer will perform a cold reset and then continue its power-on sequence.
Feb 07, 2011 | HP Color LaserJet 3500 Printer
Cartridges won't align
The HP printer can perform an print cartridge cleaning procedure even after the alignment message has displayed. Follow these steps to perform an print cartridge cleaning procedure at the front panel:
1.On the front panel, press the Menu or Setup button (depending on the model).
1.Press the right arrow button (>) until Maintenance or Tools is displayed, and then press the OK or Enter button (depending on the model).
1.The Clean Print Cartridges message should display on the front panel. Press Enter or OK to begin the cartridge cleaning process.
A page will be printed during the cleaning process with all of the colors on it. If any of the colors (including black) are missing, faded, or streaked on the alignment page, there is a ink cartridge problem.
If you go to HP website you can find more detailed information about alignment. Here is the link.
Dec 07, 2010 | HP PSC 950 All-In-One InkJet Printer
LaserJet 4350 Printer: HP 4350 printer, 49.2F9D service error...
1st thing to do is upgrade the firmware. Go to hp.com and look for the software and drivers. Drill down to the firmware and read the instructions.
May 16, 2010 | HP LaserJet 4350 Printer
I need to purchas one maintenance kit for HP 5100 laserjet printer. what contents should be there in manitenance kit. I got no authorised information about this on hp site
To ensure optimum print quality, the printer will prompt you to perform printer maintenance every 150,000 pages. When the PERFORM PRINTER MAINTENANCE message appears on the control panel, you will need to purchase a printer maintenance kit and install the new parts. To check the number of pages the printer has printed, print a configuration page.
To print a configuration page:
1 Press [Menu] until INFORMATION MENU appears.
2 Press [Item] until PRINT CONFIGURATION appears.
3 Press [Select] to print the configuration page.
To order the printer maintenance kit, contact an HP authorized service or support provider. (See the telephone support flyer included with the printer.)
The kit includes:
fuser assembly
transfer roller
feed rollers
necessary instructions
For more information on installing the printer maintenance kit, see the instructions that accompany it.
Sep 07, 2009 | HP LaserJet 5100 Printer
My hp 4250 printer makes multiple config sheets,,its set to the default of 1 copy (s)
Please perform Cold Reset and then upgrade the firwmare of the printer
HP LaserJet 4250 and 4350 Series Printers - Performing a Cold Reset NOTE: The Jetdirect LAN (such as the IP address of the printer) settings will be reset to defaults by this operation. Record LAN settings before resetting the printer. Reconfigure LAN settings after the reset if you are using a LAN connection). To avoid resetting the LAN settings disable the embedded Jetdirect before performing a Cold Reset by choosing the Disable LAN option from the choices available when you get to step 5 below. Note that after choosing to disable the LAN it is necessary to reboot the printer and then choose to perform the Cold Reset . During the power up sequence only one operation can be performed at a time. In this case, first disable the LAN, then reboot the printer and perform the Cold Reset followed by another reboot to reenable the LAN.
To perform a cold reset:
  1. Turn the printer power off.
  2. Power on the printer and watch for the memory count to begin.
  3. Hold down the SELECT (Checkmark) button, when you see the memory count begin.
  4. Continue holding down the SELECT (Checkmark) button until all three printer control-panel lights flash once and then remain on. This might take up to 10 seconds.
  5. After the message SELECT LANGUAGE appears on the display, press the UP ARROW button or the DOWN ARROW button until COLD RESET appears on the display
  6. Press the SELECT (Checkmark) button. The printer performs a cold reset and then continues its power-on sequence.
  7. Check all I/O settings and reset any user-set printer configuration values. NOTE: Before the I/O (LAN) settings can be reset to their correct values the embedded Jetdirect must first be renabled to make those options visible and available on the control panel of the printer. Renable it in the control panel settings then reset them to their correct values.
Link to download firmware:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&prodNameId=412158&swEnvOID=54&swLang=8&mode=2&taskId=135&swItem=lj-25065-14
Steps to upgrade:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=412144&swItem=lj-25065-14&prodNameId=412158&swEnvOID=54&swLang=8&taskId=135&mode=4&idx=3
Rgds,
Nikhil
Jul 21, 2009 | HP LaserJet 4250n Printer
PERFORMING MAINTENANCE ON HP LASER JET 4050
I do recommend a maint. kit ( p/n # C4118A). to clear the maint. messsage, turn the printer on while holding down the left item and left -value key, when you see reset maint. let go of the keys..
Mar 29, 2009 | HP OfficeJet J4580 All-In-One Laser...
HP LaseJet 4350dtn Laser Printer Logo
193 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
