Question about Philips Magnavox DVD/VCR Dual Player
What channel do I set my tv to to watgh a dvd
Phillips vcr/dvd player model # dvp3340v/17
  • larrypeckham Jan 15, 2009
    yellow, white, red top to bottom same as vrc/dvd (emerson tv)
    Scholar:
  • 73 Answers
Mostlt likey 3 or 4.
Please explain how you have it connected so that I can be sure.
What input (connections on back of television) do you have it connected to on the television?
Or if you could explain the colors of your wires.
Posted on Jan 15, 2009
  • Billy Hines
    Billy Hines Jan 15, 2009
    Ok if you have use this connection style you have connected to a different input that what your cable/or over the air signal goes to. because of this the channel does matter.
    You need to the change the input/source on the television using the remote. the button to so this will say source or input. Simply turn on DVD player and play any media then press the Source button on the remote until you see the DVD output, The red, white and yellow connections on the back of the TV should say Video1 or Input 1 (or something similar)
    Please respond if you need additional help.
  • Billy Hines
    I meant the channel does NOT matter in the first prargraph.
RECORDING
This model DVP3340V is only a DVD player/VCR. You can record to the VCR but not on the DVD.
Apr 19, 2008 | Philips DVP3340V
Setting up DVD/VCR
Depends how you have connected to the TV.
You will need to set your TV to the relevant socket you have connected the DVD/VCR into.
S-Video, Component , composite etc
These will be EXT 1 , EXT 2 or AV 1, AV 2 etc.
Feb 18, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR/DVD player DVP3340V/17
Are you using the cable connectors to go into the VCR, and then from the VCR to the TV?
If so, turn the VCR on. Put the TV on channel 3 or 4 (depending on which one you have it set to. If you are unsure, try both channels one at a time) Press the VCR/DVD button so the display on the VCR says VCR (not DVD). Now, you should be able to change the channel with your VCR remote control. If not, you have a problem with your cables. Make sure your cable from the wall goes to RF IN on your VCR. The RF Out on the VCR should go to your TV ANT In or TV RF In.
If you have successfully gotten your TV to display the TV station shown on the front of your VCR, then all you have to do is put in a tape, select the channel you want to record and press the record button.
If you want to watch another channel while you're recording, press the TV/VCR button on the VCR remote, then use your TV remote to change channels.
When you want to stop recording, press the stop button, put the TV back onto channel 3 or 4 (depending on what you have it set to) and press the TV/VCR button on your VCR again. From here you can rewind and view your recording.
Jan 18, 2008 | Toshiba SD-V394 DVD Player/VCR
Dvd/vcr player is hooked up but not playing...
Yes. You definitely need to set your TV on a specific channel - GAME, in your case. Check your TV manual how to get to that GAME channel.
Jan 12, 2008 | Philips DVP3340V
DVP3340V/17 DVD/VCR
Well fbyrd95 goodluck. I have checked out the pages they offer for help. You will need to purchase a cable/satellite box to get the channels routed through the vcr. I received one of these for christmas. It is the sorriest excuse for a vcr/dvd combo I have ever seen. If this is bought as a dvd/vcr combo then I would assume that vcr means that it will record. I do not have the receipt or it would be returned. I will never purchase a philips product.
Jan 03, 2008 | Philips DVP3340V
NO PICTURE OR SOUND ON THE TV
I'm not sure if you've done this yet, but this might work.. goodluck to you... let me know if it helps
Dec 31, 2007 | Philips DVP3340V
DVP334V cant connect to my LCD TV
  1. Connect the video cable to the players VIDEO (CVBS) OUT (yellow) jack and to the TV's VIDEO IN jack.
  2. Connect the audio cable to the players 'AUDIO LEFT' (white) and 'RIGHT' (red) output and the TV's 'AUDIO LEFT/RIGHT' input jacks.
  3. After it is hooked up, you will need to select the TV’s video input channel that corresponds to the jacks connecting the player to the TV.
    • Press STANDBY-ON to turn on the player.
    • Turn ON the TV.
      Note: Video Input selection varies for different brands/models of TVs. Consult the user manual or manufacturer or your TV if none of the below is successful.
      • Press channel 2 on your TV. Then press the channel down button to locate the video input channel. (This channel is usually located between the lowest and highest TV channels.)
        OR
      • For some TVs, there may be a button on the TV’s remote control that accesses the video input channel labeled SOURCE, AV or SELECT.
        OR
      • Select the Video Input Channel from the TV’s on-screen menu system.
Composite Video Connection. (Example Only)
051104165152_4352.jpg Attachments
    No attachment available.
Dec 25, 2007 | Philips DVP3340V
Need help
Press VCR source, switch to the correct channel and press the RECORD button.
Oct 31, 2007 | Philips DVP3340V
Philips Magnavox DVD/VCR Dual Player Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
