Question about LG WM-2277HW Front Load Washer
LG Frontload Washer Top Removal
Anyone know just how to get the top off a frontloader?
    New Friend:
  • 88 Answers
Take the 4 philips screws out the back of the top panel then push the panel back. good luck .
Posted on Jan 15, 2009
GE frontload washer doesn't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 12, 2011 | GE WSXH208A Front Load Washer
MY LG FRONTLOAD WASHING MACHINE WAS OUT OF BALANCE AND DANCING ALL OVER THE FLOOR NOW THE RUBBER SKIRT AROUND THE DOOR IS DEFORMED AND TWISTED. HELP!!!
The washer tub spring has popped off it's mounting. You will need to remove the top panel and reconnect the support spring back on to the metal frame.
Jun 26, 2011 | Washing Machines
My washer sounds like it's dying, but the dryer is fine. Can this be unstacked so all I have to do is buy a new washer?
Welcome to FixYa.
To answer your question, as long as it is indeed a frontload washer with the dryer on top, yes they can be replaced individually.
The model number provided is only partial, therefore I can`t verify the unit is frontload or an Kenmore integrated "laundry center" built by frigidaire.
You can reply with a model number, but as I alluded to if it is frontload, no problem.
Good luck going forward. Thank`s for choosing FixYa. Let me know if you require further assistance.
Macmarkus :)
Aug 25, 2010 | Kenmore 43142 Front Load Washer
Hello. My frontload LG Washer started leaking
I have the same problem I think. During the wash cycle, water sometimes starts spraying/leaking from the detergent dispenser drawer. This orignally only happened during a 'NORMAL' wash and when I ran a 'SPEED WASH' it was ok. Now all of a sudden it's doing it during the 'SPEED WASH' also. I though it might be the water pressure so I turned down the flow going to the washer but that doesn't seem to help. If I knew how the detergent system worked maybe it would be easier to solve this problem.
Nov 11, 2009 | LG WM2277H Front Load Washer
Do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
How do you remove top of new washer so dryer will sit on top?
There should be 2 screws at the rear of the top section. Remove those screws and pull the top backward and it should come off.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Lg frontload wash
I removed the top panel of washer(4 screws and slide). Then found the small 1/4" hose that goes from drum to drain hose to be pluged with goo. I cleaned inside of hose and washer worked fine.
Dec 30, 2008 | LG WM-2277HW Front Load Washer
Broken Washing Machine
frontload or top load frontload,,remove debris from inside pump,, top load , coupler problebly broken,
Oct 11, 2008 | Kenmore Elite HE4 Electric Dryer
Te error on LG frontload washer
ARE YOU SURE IT'S CODE IS TE AND NOT DE
DE IS PROBLEM WITH DOOR LOCK . TAKE THE WIRE OF THE DOOR SEAL AT FRONT . PUT YOUR HAND IN BY DOOR LOCK POSSIBLE THE PLUG HAS COME OF THE DOOR LOCK, IF NOT THE LOCK NEEDS REPLACING.
SWITCH APPLIANCE OF FIRST. GOOD LUCK
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Maytag frontload washer door is leaking
Yes you can do it. the door boot has come off the tub opening. first you will have to push on the door boot (gray rubber)on. There is a grove that slides into the metal opening in the washer. make sure the the door boot (gray rubber)lays flat against the outer opening. then with the spring at the bottom . start at the top put the wire in the rubber grove. until you get the the spring then pull down on the spring and tuck it into the grove.. I hope this helped [lease let me know if you get it... krazytech
Sep 13, 2007 | Washing Machines
LG WM-2277HW Front Load Washer Logo
182 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
