Question about Nokia 3220
No signal my phone does have signal when i'm at home but when go outside the signal gets back and a few minutes it displays check connection setting what i would do whith this shit guys?
  • 28 Answers
Re: no signal
Ask you friend who use same line with you.enter you house and see what happen.
Posted on Jun 18, 2007
0 characters
3 Points
Will not stay connected to home wifi
Open your wifi on the phone and press and hold the wifi network that you want to connect to then click (modify) re-enter the security code for the wifi network again and then connect. If that does not work then the wifi signal is weak and you'll need to get closer to your router.
Another thing is to choose United States for your Wifi Region in the wifi advanced settings menu.
-- uncheck (avoid poor connections)
-- check scanning always available
-- Wifi Region Code (select United States)
I hope that helps will-not-stay-connected-home-wifi-5x01jctu1hti52f1zciidmg3-3-0.png
Mar 19, 2014 | Samsung GALAXY S4
My phone does noes not connect to 4g when I leave my home
Is your mobile phone service active? Do you have minutes on your phone? Some phones will connect to your home internet service. This saves broadband minutes. If your phone is set up to use your home internet modem, then you need to tell it to use broadband. At&t will help you learn about your phone and tell you where to get a guide. You can go back to your store, or contact them on line at
Aug 18, 2013 | LG Nitro 4g Lte Hd At&t Smartphone 8mp...
How to switch from offline to online
Offline mode only appears if the mobile phone is not getting the signal from its service provider.
*make sure that the sim is properly connected*reseat the sim card from the mobile phone*check account status for signal and connection availability*power cycle mobile phone
1. turn off mobile phone2. remove phone battery3. remove memory card4. remove sim card5. wait for 2 minutes before plugging back anything6. after 2 minutes, plug back battery7. insert memory card properly8. insert sim card properly s well, make sure that the sim is not dirty as well9. turn on mobile phone10. check the signal bar, it should be with signal this time and not offline
*after power cycling, phone should be working properly now unless the sim card is really faulty. you check if its faulty by calling your mobile service provider*
Dec 10, 2011 | Nokia E75 Cell Phone
I am having serious problems with dropped calls on my iphone
Unfortunately, this has plagued the AT&T iPhone since the original model came out. It's most likely a dead zone causing the issue (I have the sameissue from time to time). You can also get a Micro Cell from AT&T, it's basically just an access point that allows you to pick up a cellular signal at home or work (where ever you set it up).
To eliminate any hardware issues, make sure you're on the latest build of the OS (4.3.3 for the AT&T iPhone 4) - I noticed you're still on 4.3.2. If you don't have a case, I suggest the Apple bumper or any case that covers the metal bezel on your phone, that will help as well.
Also, you can "reboot" your phone. To do this, hold down the metal sleep button on the upper-right corner of your phone until the "slide to power off" slider is displayed, then power off the phone. Wait a few minutes and turn it back on.
Hope this helps!
Jun 23, 2011 | Cell Phones
No signal bars on my iphone 3gs 16 gb
first try turning airplane mode on for a few minutes, then back off. its found on the first page of the settings menu near the top. It will cut the link to the cellular network completely, then rebuild it from scratch. I'd say give it at least a few minutes of down time.
if that doesn't work, try a hard reset. hold the power button on top along with the home button until the phone turns off and reboots, then let go and look for service.
if that doesn't work, update your iphone to the latest software. New software frequently contains updates to the software responsible for connecting with the cellular towers.
if no luck thus far, you're destined for the genius bar I'm afraid. good luck
Feb 17, 2011 | Apple iPhone 3GS Black (16 GB)
How to get internet after whiping a blackberry 8330
go to settings, options, advanced options, host routing table, press the menu key and select register now. If it says it will send when data is available then go back to home screen and select manager connections, mobile network options, and switch data to "on". If data is already on then pull your battery while the phone is on and leave out for 5 full minutes. Then replace battery. Your phone may be froze for a few minutes while it is receiving all the data service books.
Feb 04, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
May 28, 2009 | Nokia 3230 Cellular Phone
the problem on it is the crystal IC on the display,, replace it
Apr 04, 2009 | Nokia 3230 Cellular Phone
No signal and problems connecting to the internet
try this.. go to settings then network followed by network setup.. there change settings as follows--- band:automatic, type:automatic, speed:medium... once you do this just restart your phone.. this may help you
May 09, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Nokia 3220 Logo
62 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
