Question about Refrigerators
I have a Roper refigerator. I cannot find the controls for the top freezer compartment. Can you identify the location for me. it is a RT188KXSQ00
  • 318 Answers
Your controls are inside the refrigerator section.the one on the left is for temperature and the right one is for freezer air control. both should be set at the mid point to get average temps in both sections. if you dont have proper temps, then check to see if your coils under the unit are clean and lint free.
if you clean the coils and still dont have good cooling, then you may have a seperated heat exchanger.
it happens alot on this model and it will cause the unit to be almost cold enough but ice cream and fruit type drinks wont freeze solid.
the heat exchanger is expensive to repair, 400-500 bucks and it might be time to look for a new unit.
Posted on Jan 15, 2009
Pan tray
The pan is located inside the removable grille at the bottom of your freezer
Jul 01, 2013 | Roper RT21AKXKQ Top Freezer Refrigerator
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Will not defrost . Is it a continuous run, 8 hour or 10 hour defrost?
Good day,
It's an 8 hour cumulative running time control. It runs when the compressor runs, and as well the defrost thermostat in the freezer compartment is closed. That's for the running mode, in the defrost mode it runs whether the defrost thermostat is open or closed, and as well whether the thermostat is on or off.
If it's a defrosting problem, it could well be the defrost thermostat, and in rare cases the main heater. They are both located behind the rear panel in the freezer compartment.
In order of frequency of failing,
1. Defrost thermostat
2. Timer
3. Main heater
4. Harness wiring plugs in the freezer compartment that connect these items.
Jun 23, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
I have a rooper top frezer refrigerator the refrigerator does not get cold because the ducts that connect to it freeze, I change the timer,check the heater,is good , change the defrost thermostat, but...
it seems to me that you have a clogged drain, that is located in the freezer compartment behind the panel. make sure that is not clogged. that will cause the issue you are having.
Oct 21, 2009 | Roper RT18HDXKQ Top Freezer Refrigerator
Refigerator temp is rising Lower freezer compartment seems to be fine
Check rear wall of freezer by feel for frost. Frost indicates likely problem in the defrost system. Defrost heater (in freezer), defrost thermostat (in freezer) or 1 of Defrost timer or Defrost control (Circuit board) generally located in Refrigerator compartment but may be inside rear of outer case.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Model and brand is always helpful when requesting information.
Aug 22, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
