While modifying name of one contact message was displayed - Database corrupted. On restarting the Mobile - only first NOKIA screen is displayed and no further progress
Amin Thakur
Hello My Dear:
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
SOURCE: mobile startup failed . contact the retailer
hi,
Your phone's memory card must be infected with virus or has some fault. Please remove the memory card and try to start the phone again. If it goes through, please back up the data in your memory card and format it. In most cases, this procedure solves the "Phone start up failed. Contact the retailer" error.
I'd advice you to format your phones internal memory as well, it will flush out any errors present. save your "phonebook" data somewhere and Make sure your phone's battery is fully charged if not plug the charger in and proceed. NB: interrupting this process might render your phone useless. So, be careful.
To format press *#7370# it will prompt you for security code, enter it and the phone will reboot. Your phone will be reset to "factory settings."
SOURCE: Caller ID display
hello
Check which memory is used by your phone(sim/phone) this can cause a problem like yours
AYADI
SOURCE: Plz!Generate master security code
Master code: 1331646626
this code is to be entered when you are trying to master reset the phone.....
Your phone need to be reflash but seeing that may cost you as much as a new 1112 so just buy a new one
SOURCE: my mobile nokia 3110c not working theme.every i`m
Your phone momroy is full ! U have not set the theme in mobile ! You have remove or delete the same items ! Then u have set the theme in mobile !
SOURCE: Nokia 6720 message icon keeps flashing
It can also indicate you have messages on your SIM that are not yet copied to your phone.
Go to messages -> Options -> SIM Messages and delete or copy these messages and the blinking icon should dissapear.
